Author Topic: blade cylinder 4 1984 240a timberjack  (Read 756 times)
Offline MICKEY108
« on: April 01, 2012, 09:15:09 PM »
i took 4 bolts off cover how do u get the packing out looks like a snap ring holding it in but counldnt get it out hoping someone can help thanks
Offline snowstorm
Re: blade cylinder 4 1984 240a timberjack
« Reply #1 on: April 01, 2012, 09:24:50 PM »
never did a tj one. tho it sounds about like the way jd did it. push the gland in take the snap ring out
Offline PAFaller
    • Berndtson Timber Management
« Reply #2 on: April 01, 2012, 09:58:01 PM »
You got it right, but it will still be tight. Take that snap ring out and either put pressure to it to get it out or try compressed air. The small seal on the rod usually goes bad and causes the leak, same with the steering cylinder. Thats why you may be seeing a leak but it will still be *DanG tight to get the booger apart. I did the steering cylinder in the woods this past winter, and just had the blade ones done at the shop while it was apart. Feel free to PM me if you ever have a question, there isn't much in mine I haven't gone through in 2 years I have owned it, but I enjoy the simplicity of it and felt it was a worthwhile investment
It ain't easy...
Offline OntarioAl
« Reply #3 on: April 01, 2012, 10:51:04 PM »
Mickey108
Just as PAfaller and Snowstorm advised you have to drive the gland back to get enough clearance to take the snap ring out.
I make a simple puller using 3/8 all thread (4 to 5 " long), 2 pieces of 1" x 1/4" x 6" flat bar.
Thread the 2 pieces of all thread into opposite holes on the gland pass them through the holes in the keeper plate spand the cylinder with the flat bar on edge. Tighten the nuts 1/2 turn and alternate and the gland will pull up flush with the top of the cylinder.  Grab the rod at this time and it should come out with a little wiggling.
It works for me
I hope this helps
Al
Al Raman
Offline MICKEY108
« Reply #4 on: April 01, 2012, 11:22:50 PM »
thanks 4 all the help
where to get a manual for a 1984 240a timberjack
Started by shawn stellner on Forestry and Logging
Last post March 21, 2014, 12:54:31 PM
by giant splinter
1984 timberjack 240a brake problems
Started by MICKEY108 on Forestry and Logging
Last post March 04, 2020, 08:11:38 PM
by David-L
Door for 1984 or 85 Timberjack 240A (DOOR FOUND)
Started by Rob-IL on Wanted
Last post August 24, 2010, 05:56:07 PM
by Rob-IL
1986 timberjack 240a master cylinder
Started by timberjack 240a on Forestry and Logging
Last post December 24, 2012, 11:25:52 PM
by timberjack 240a
