We have contest winners!
Thanks for posting the pics of the project. Looks like it has turned out quite well. Now, for a video....
Let me know if I got this right...You set the "thickness" from the bottom of the guide bearing minus the track depth, and then make passes back and forth until the bearing bottoms out and makes a complete run along the track.Right?Rooster
I watched all 3 videos. I applaud what you have done. You've made a beam planer pretty cheaply. I assume the track is from your Chainsaw mill. You could do larger beams also by spacing up your planer feet.
Here's my question. You made the first pass on the beam flattening one side. Then you flipped it over 180 degrees to the opposite face. Assuming the planer is parallel to your bed, why would you have to raise or lower one end of the beam?? If you just planed that side after flipping it, both of those opposite faces should come out parallel, correct? I thought the adjustment was going to be to initially align the beam best for the first face, or to square the adjacent face(90 degrees) to the first pass?
Additionally, One thing that would help you to square and adjacent face to the first face you did, would be to bolt some 90 degree blocks to your bed so that when you push the first planed face up against them, and clamped the beam to them, you could then easily plane the adjacent face without needing to measure. This is how band mills like the woodmizer work. Your planer is a smaller (and much lower cost) version of the woodmizer MP100 planer.
Rooster I'm not sure I'm following you. On my bench planer, it has a rule that indicates the thickness as you move the planer up and down. Honestly I hardly use this rule. It's just a ball park to me. You can only take about 1/16th off in a pass approximately. I make passes and measure the stock itself till I'm satisfied with the thickness. I would guess that's how you'd do these 6X6's, but let's see.
Started by Rooster on The Wisconsin Barn Preservation Program
Started by weimedog on The Outdoor Board
Started by Piston on General Woodworking
Started by richhiway on Sawmills and Milling
