Author Topic: Belsaw m14  (Read 4354 times)
Offline Mark K
Belsaw m14
« on: June 10, 2012, 03:44:58 PM »
I bought a Belsaw m14 at an auction yesterday. Wasn't expecting to by a mill when I went but the price was good. Has roughly 30' of frame and track, pto driven with a 40" insert tooth blade. All wooden framed which is in real good shape. I have a couple questions. What size logs will this handle? Im mainly cutting hemlock and some pine. How much HP does it take to run? I have three tractors, farmall super m, farmall bn, and a Massey harris 30. Which would be my best bet for running it? I know the bn wouldnt do it but I use my farmall super m to move logs. I was hoping to use the massey. The previous owner used a little Allis Chalmers. He ran the mill for a couple years and had to sell it because of injury.
Husky 372's-385's,576, 2100
Treefarmer C7D
Franklin 405
Belsaw m-14 sawmill
Offline thurlow
Re: Belsaw m14
« Reply #1 on: June 10, 2012, 04:11:02 PM »
When F-B was in business, they usta publish a quarterly magazine and would run stories of people pulling their mill with a Super C Farm-a-little or something similar.  The manual says my mill with a 46 inch blade (2 headblock/10 ft carriage will handle a 24 inch by 14 ft log;  I've occasionally sawed 30 inch by 16 or 17 footers,  but each time I've done it, I've sworn never again...............
Here's to us and those like us; DanG few of us left!
Offline snowshoveler
  • Knotty Knot Sawmill
Re: Belsaw m14
« Reply #2 on: June 10, 2012, 04:19:52 PM »
My mill runs a 38 inch blade and I have a vintage cat power unit belted up to it..50 horsepower.
As for logs I have a lot of them 20 and 24 inches.
Its work for sure but can be done, you will get real good using a chainsaw to help you. I use a little 338xp husky
top handle. Very light and fits the job very nice.
You run 1 log throught that mill and you will forget all about any thing else you might have had for a hobby.
 Good luck and post us some pics of the mill and tractors.
Regards Chris
International T5 dozer
JD M tractor
MF skidloader
Jonsered chainmill
Vintage Belsaw
Offline Mark K
Re: Belsaw m14
« Reply #3 on: June 10, 2012, 04:41:50 PM »
Thanks for the fast replies. I will definitely post some pics as I go. Its all apart sitting on my trailer, oiled and covered up right now. I have a 20x50' pad that im going to put it on where a barn once stood. My goal is to get it set up by mid summer and a roof over it before the winter. It's going to be a learning experience. I had a woodmizer lt40 manual before that I owned as a partnership with a family member. I dont want to go into detail but I got the raw end of the deal. Im not looking to turn this into a production mill just want something to tinker with during spring breakup and when logging is slow. I do have a six cylinder power plant off of an IH combine. Has the clutch, pulleys and all but would have to make the mill belt drive. Plus I think it will hog gas!
Treefarmer C7D
Franklin 405
Belsaw m-14 sawmill
Offline captain_crunch
Re: Belsaw m14
« Reply #4 on: June 11, 2012, 01:18:02 AM »
48 pto hp will do this
Offline bandmiller2
Re: Belsaw m14
« Reply #5 on: June 11, 2012, 07:13:39 AM »
Congrats Mark,There are volumes written here on Belsaws.You will be surprised how large a log you can whittle down with that 40" saw.Just be carefull turning and flopping down heavy logs/cants on your carriage,best to build the turners Belsaw reccomends.Unless the bits are real good I would start off with new ones and a freash hammering job. Frank C.
Offline thurlow
Re: Belsaw m14
« Reply #6 on: June 11, 2012, 09:48:40 AM »
Dang, that's pretty;  what kind of wood do it be?  Looks like frasassas, but I've never seen one that big.
Offline Mark K
Re: Belsaw m14
« Reply #7 on: June 11, 2012, 03:45:43 PM »
The man that originally owned it is going to help me fine tune it once I get the rough setup done. Blade has a new set of bits in it and came with a box of bits and the tool. He has the sharpener for it and a sawdust blower. I'll have to look it up and see what the turner looks like.
Treefarmer C7D
Franklin 405
Belsaw m-14 sawmill
New here, got a Belsaw
Started by glendaler on Sawmills and Milling
Last post May 13, 2018, 05:36:46 PM
by glendaler
belsaw
Started by kmdfarm on Wanted
Last post November 09, 2019, 08:49:12 PM
by Remle
New guy with a Belsaw M14
Started by Chop Shop on Sawmills and Milling
Last post March 22, 2014, 11:16:12 PM
by Little Jim
Belsaw m-14
Started by loggah on Sawmills and Milling
Last post January 06, 2013, 08:35:44 AM
by loggah
