Author Topic: wood-mizer lt70 vs timberking 2400  (Read 2987 times)
Offline missouriboy
« on: June 14, 2012, 01:55:13 PM »
I am going to get a mill and edger and a resaw. I need a mill that can cut pallet lumber and cants and need to do it with a high output. Which one of these beast has the highest output. I just need some numbers
Offline Bibbyman
    • Warden Sawmill
Re: wood-mizer lt70 vs timberking 2400
« Reply #1 on: June 14, 2012, 03:15:30 PM »
I'd double or triple up on the resaw and cut back on the mill.
I don't know if there are any TK 2400s in the field.  I've never saw one outside TK development lab.  Anyone have one?  Anyone seen one?
Sawing since '94
Offline Misfit
  • Alrighty then!
« Reply #2 on: June 14, 2012, 04:26:32 PM »
There's a guy in southern BC, Bruce Baker, who owns a TK2400. There's a video of him on TK's website. (Not the same guy as Brucer who regularly posts on here)
I am neither a Philopolemic Blatherskite nor a Bloviating, Sialoquent Blatteroon.
"Say nuthin and saw wood."
Offline ladylake
« Reply #3 on: June 14, 2012, 06:47:06 PM »
 I'd guess there's some TK 2400 mills out there but with the TK 2000 not that far behind in log capacity  (36" easy) and priced at almost half as much it would be hard to justify a TK 2400. The 2400 would have a diesel, larger band wheels and a wider band.   Steve
Timberking B20 14000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Suffolk  setter Volvo MCT125c skid loader
Offline Bibbyman
    • Warden Sawmill
« Reply #4 on: June 14, 2012, 07:27:15 PM »
Will you be breaking down big logs?
If not, maybe a scrag mill and multi head resaw would be more productive.
Have you seen the WM small log system? Looks very productive but would be pricy.
Sawing since '94
Offline Migal
  • I'm new! But Old as Dirt!
« Reply #5 on: June 17, 2012, 09:09:01 PM »
LogMaster has some really sweet machines too  8) for large logs
Stihl learning and picked up my Log Master LM2 Cat 34hp 02 21 12! 230MF+ the toys that go with it! MS361 MS271 Stihl PB500 Echo 48" LogRite 16ft Bass Tracker Pro' Abua Garcia 5600 bait caster, Wood working equipment' Lake Lot never enough time! oh don't forget the fridge with ale! Loving Wife Rebeca
Offline Solomon
  • I finally figured out how to upload pictures!!!!
« Reply #6 on: August 08, 2012, 04:59:31 PM »
You might want to look at Logmaster mills.   Logmaster.com
Time and Money,  If you have the one, you rarely have the other.
The Path to Salvation is narrow, and the path to damnnation is wide.
Online bandmiller2
« Reply #7 on: August 09, 2012, 08:04:51 AM »
Missouri,their are some ripper deals on modern circular mills now,if your going to be stationary,they will outproduce any small band.  Frank C.
Wood-Mizer LT70 with 62 CAT review
Started by Bibbyman on Sawmills and Milling
Last post August 01, 2003, 01:09:07 PM
by Bibbyman
smiley
Wood-Mizer LT70 Demo
Started by MartyParsons on Shows, Events and Places to meet
Last post February 27, 2005, 08:54:05 PM
by MartyParsons
moved
MOVED: Wood-Mizer LT70 Demo
Last post February 27, 2005, 07:00:09 PM
by Jeff
Wide head LT70 Wood-Mizer
Last post June 07, 2013, 09:27:40 AM
by terrifictimbersllc
