Author Topic: Beginner Sawyer With Questions???  (Read 4414 times)
Offline JWright
  • Backyard Sawyer
« on: July 02, 2012, 11:10:02 PM »
I am curious as to the different variation ya'll use for blade lube/tar cutter. I was told by a more experienced sawyer to use liquid laundry detergent it's cheap readily available and that helps a lot. I have not had any issues yet cuts the tar like a charm. I'm just starting with my mill and mostly built it myself. I'm cutting pine for my personal projects but people are already askin for help or to by the lumber. I'm seriously thinking of part timing it to see if I can make a full time go of it. My idea is to let this mill and some other savings get me a good ole orange one or maybe a timber king. Just trying to get some input in different things now from people that have the experience here! I can see its hard work but I knew that before I built mine as I've been around mills before and helped out some for others. I still need a lot of equipment but I'm further alon than most thought I'd get. I've rigged a winch on an 8x8 post to load my logs and help turn em. I hope to get tractor, lift, or grapple of some kind here soon. This is the part where any body can help give suggestions or recommendations so I don't have to learn the hard way!!! I will add some photos of my small set up soon.
Offline JoeBrittany21
  • Started at 15 and still going.
Re: Beginner Sawyer With Questions???
« Reply #1 on: July 02, 2012, 11:13:50 PM »
Jwright,
I am a newbie, and I cant answer your questions. But I can tell you these guys on this site are fantastic when it comes to good info. Good Luck. Joe
Offline JWright
  • Backyard Sawyer
« Reply #2 on: July 03, 2012, 01:15:40 AM »
Yeah I've noticed that just scanning some post that's Why I joined and started asking. Maybe I'll stir some good comments/ advice.
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #3 on: July 03, 2012, 04:47:47 AM »
Hi JW, welcome to FF.  I and several others here use Cascade dishwashing gel in varying amounts in water.  Add enough to the water to keep the blade clean.  It works on pine, hickory, ash buildup.    I find it cheapest at Walmart and it isn't much of an expense.   If you use the search button and type in "blade lube" you'll find quite a bit of discussion with many options.
DJ Hoover, Terrific Timbers LLC,  Mystic CT Woodmizer Million Board Foot Club member. 2019 LT70 Super Wide,  LogRite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
Offline dgdrls
  • Learning the Art of Milling Logs
« Reply #4 on: July 03, 2012, 05:47:53 AM »
I just cut some Hickory and used a cap-full of Pinesol to the water in the lube tank.
worked well and the slabs are not stained,
DGDrls
Offline thecfarm
« Reply #5 on: July 03, 2012, 06:19:19 AM »
JWright,the blade lube is a good topic.It's right up there with grits.  ;D I only saw for mine own use. I use half diesel and half chainsaw oil,BUT only at a SLOW drip.like a drip every 2-3 seconds. Looking forward to the pictures. It great sawing. Good that you can build a mill.
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #6 on: July 03, 2012, 07:12:21 AM »
I do not cut as much pine as many others here do, but I use dishwashing soap and Pine-Sol.  I use about a quarter cup of Pine-Sol to 5 gallons of water, but that might be too much.  However, it works great.
Online Tom the Sawyer
  • Converting your logs to lumber at my home or yours
    • Tom the Sawyer Portable Sawmill Service
« Reply #7 on: July 03, 2012, 10:21:11 AM »
I started using Cascade or Dawn and it usually worked but I ran into some elm and a few pines where it couldn't touch it.  Matt @ TK suggested Zep Heavy Duty Citrus Degreaser at 6 oz. per gallon of water.  It has worked very well on everything I have sawn so far and blades seem to stay clean much longer.  It is about $11 per gallon at Home Depot.
07 TK B-20, Custom log arch, 20' trailer w/log loading arch, F350 flatbed dually dump.  Piggy-back forklift.  LS tractor w/FEL, Bobcat S250 w/grapple, Stihl 025C 16", Husky 372XP 24/30" bars, Grizzly 20" planer, Nyle L200M DH kiln.
If you call and my wife says, "He's sawin logs", I ain't snoring.
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
« Reply #8 on: July 03, 2012, 10:50:22 AM »
J, Every reply to your post is a good idea and they all work depnding on what you are sawing. I can only add that I keep a bottle of diesel fuel in a spray bottle. When I hear the blade start to chatter a little due to build up, I just spray my blade 2 or 3 times with diesel. You can hear the blade get quite as the build up goes away. But like the others have said, keep a good mixture in your lube tank and a spray of diesel on the side.  smiley_thumbsup
Offline WDH
« Reply #9 on: July 03, 2012, 09:01:21 PM »
David,
A little spray of diesel cures a lot of ills.  Your comment reminds me of my Dad.  Whenever I got cut when I was a kid, my Dad would always put a little diesel fuel on the cut.  He said that it would kill the infection :).  So, I have had a little diesel spray in my time  :-\.  We had a dog chasing a rabbit one day, and the rabbit ran between the upturned tines of a chisel plow.  The dog did not make it between the tines, and his head was split open.  My dad liberally applied diesel fuel.
The dog did not make it.  Well, at least it killed the infection before it got started  :).  Moral of the story:  Confine the diesel fuel spray to your saw blades.....
« Reply #10 on: July 03, 2012, 09:19:20 PM »
David,
WOW Danny....good story. I expect some of the old remides are true. I'm like you, if its good enough for my Dad....its good enough for me.
My Dad once had to drain the Diesel fuel from his old tractor. He had cut an old milk jug in two for the Diesel to drain in. There was about a half of a gallon of fuel in the jug that was cut off.  It set it down beside the well.
My dog had been out chasing bugs or whatever. It was hot and in the high 90's that day.
The dog ran up to the well, hot and thirsty and began lapping up that diesel like it was going out of style.
The dog made a strange looking face and took off running around the well house 8 times and fell over.
Poor Spot......he didn't die......HE JUST RAN OUT OF FUEL!  :D :D :D :D :D :D :D :D :D :D
Offline MHineman
« Reply #11 on: July 04, 2012, 02:20:28 PM »
  I've got WM LT40.  I call WM and they have different recommendations for different situations and species of wood.
  I generally use about 1 cup of dishsoap and 1 to 2 cups vegetable oil in 5 gallons water when sawing hardwoods.
  I use the same plus about 2 cups Pine-Sol when sawing utility poles.
  We don't have many conifers here large enough to saw.  I used the Pine-Sol when I did saw them and it seemed to work OK.
  I start out using little or no lube then turn on the lube as I start to get buildup on the blade.  Sometimes a little all the time works, but more often a surge of liquid works best to loosen and remove the gunk.
1999 WM LT40, 40 hp 4WD tractor, homemade forks, grapple, Walenstein FX90 skidding winch, Stihl 460 039 saws,  homebuilt kiln, ......
Offline Sixacresand
  • John and Nancy
« Reply #12 on: July 04, 2012, 10:49:28 PM »
My dad's remedy for every thing was terpentine or chewing tobacco, depending what ailed you.
I was using pinesol but  Lately I found the cheap dish washing soap from the dollar general works pretty good too.  i haven't tried diesel yet.   Don't ususally get blade buildup unless I get into some fat lighter pine.
On the WM LT10 the band runs on top of belts and that is where I get build up of sawdust between the blade and belts.  Seems like it should have some kind of scraper to keep it clean.
« Reply #13 on: July 04, 2012, 10:56:00 PM »
Each time I put on a new blade, I have a piece of sand paper that I use to just rub the build up ( of resin ) of the belts. It works quick and easy. I get clean belts and I'm back to sawing.
Offline Sixacresand
  • John and Nancy
« Reply #14 on: July 04, 2012, 11:11:36 PM »
Thanks for the tip, POSTONLT40HD
Offline JWright
  • Backyard Sawyer
« Reply #15 on: July 05, 2012, 12:14:02 AM »
Was a good tip there POSTONLT40HD!
Offline bandmiller2
« Reply #16 on: July 05, 2012, 06:51:37 AM »
Everything used for band lube is trying to approach the effectiveness of diesel fuel.If applied with a wick or very sparingly its cheap and effective.Theirs something inherently wrong with putting water on a steel cutting tool.Try different things and use what you like best. Frank C.
Offline trapper
« Reply #17 on: July 05, 2012, 10:05:31 AM »
Thanks for the tip, POSTONLT40HD.  Sounds like a better way than just my gloved hand.
Offline Dave VH
« Reply #18 on: July 06, 2012, 12:35:29 PM »
I usually only have time to mill when it's below freezing out.  a slow drip of diesel fuel works great for me.
I cut it twice and it's still too short
Offline Migal
  • I'm new! But Old as Dirt!
« Reply #19 on: July 07, 2012, 06:30:11 PM »
Im using off road diesle seems to be working so far.
Stihl learning and picked up my Log Master LM2 Cat 34hp 02 21 12! 230MF+ the toys that go with it! MS361 MS271 Stihl PB500 Echo 48" LogRite 16ft Bass Tracker Pro' Abua Garcia 5600 bait caster, Wood working equipment' Lake Lot never enough time! oh don't forget the fridge with ale! Loving Wife Rebeca
Advice for a beginner sawyer
Started by retogkoch on Sawmills and Milling
Last post June 05, 2018, 10:40:46 AM
by mike_belben
My Adventure in Sawmilling: Ongoing Story of a Beginner Sawyer
Started by Leigh Family Farm on Sawmills and Milling
Last post September 09, 2012, 06:38:04 PM
Beginner questions
Started by Rob in NC on Sawmills and Milling
Last post October 26, 2016, 09:11:07 PM
by Sixacresand
Beginner Questions
Started by BlaBla on Chainsaws
Last post November 28, 2004, 07:09:19 PM
by SasquatchMan
