Author Topic: Trouble shooting a Grand Cherokee  (Read 3880 times)
Offline Jeff
  • Fearless Leader
  • I know that I do not know.
    • THEE Forestry Forum
« on: July 18, 2012, 12:55:00 AM »
Today, my Son's significant other's 2004 jeep would not start. No crank. Battery was good. We pulled the starter off and bench tested it, it was good. Put the starter back on, and we could start it by jumping the solenoid. We shut it off and I started tracing back from the solenoid. No juice to the solenoid wire when trying to crank. So, I went looking in the fuse panel under the hood.  There is an ignition switch fuse block (40 amp fuse)   I pulled that fuse to test it. Seemed fine. I then checked the block where the fuse came out of. There is power there all the time.  I put the fuse back in, and now the jeep starts. Pulled the fuse again and tried to clean up the connection. Put the fuse back in again and it started. Shut the hood, called it good, Jeep won't start.  Pull the fuse, put it back in. Jeep starts. Shut it off, wont start.  I jumped the fuse with my test light, Jeep starts.  So. I switched the fuse out with another 40 amp.  Still does it.  Pull the fuse, put it back, vehicle starts, shut it off, won't start until you pull the fuse and put it back in.
So, what could I be missing?  It's like something gets reset when you pull the fuse.  There is a starter relay in that box as well. I switched that out with an identical relay from the fuel pump. No go. Still the same problem.
Any guesses?
Offline sandhills
Re: Trouble shooting a Grand Cherokee
« Reply #1 on: July 18, 2012, 01:27:16 AM »
Are you sure you have a good connection at both ends of the fuse?  I'd try to check that with a test light when it doesn't want to crank first (before pulling the fuse).
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
« Reply #2 on: July 18, 2012, 04:44:32 AM »
 say_what  This problem is way beyond me. Have you pulled all your hair out yet?
Offline sprucebunny
  • Gender: Female
« Reply #3 on: July 18, 2012, 07:03:37 AM »
Check that the grounds are all good.
( The topic title threw me.... like maybe you couldn't bring yourself to put it out of it's misery  :D )
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #4 on: July 18, 2012, 08:04:34 AM »
When it won't start, do you have power to both ends of the fuse/fuseholder?
Offline thecfarm
« Reply #5 on: July 18, 2012, 08:13:51 AM »
Could you run another wire,with a fuse,to it? Just for a while to see if that will do it?
Offline Roxie
  • Gender: Female
  • I'm your huckleberry
« Reply #6 on: July 18, 2012, 08:24:58 AM »
I'm with Sprucebunny!  Aim the gun right between the headlights.   :D
Save a farm today or starve tomorrow.
Offline Hilltop366
« Reply #7 on: July 18, 2012, 08:40:26 AM »
Sounds like a bad wire or a loose or corroded connection, usually it is the small wire(s) that go to the starter, it would be easier to find if it quit working.
Offline ely
« Reply #8 on: July 18, 2012, 08:43:48 AM »
if its got the exposed metal on the back of the fuse it makes it easy to check with a volt meter, it sounds like its one of those enclosed fuse blocks though,so no help there.
does it do this all the time or only when the jeep is up to operating temp.?
Offline Jeff
  • Fearless Leader
« Reply #9 on: July 18, 2012, 08:50:07 AM »
The jeep had been sitting all weekend here at the house, as the kids were here to visit and swim. Never a prior issue with it. Delana had to leave for work, and that is when we found it would not start, so nope, its a cold jeep although the heat index yesterday was 105  :D
The fuse panel on the jeep is completely enclosed in the back and all the wires run through sealed harnesses. what I found odd, is that the factory connection of the little light green wire going to the starter solenoid is a stake on connection.
Troubleshooting is supposed to be one word I guess. :D
Offline doctorb
  • Unofficial Team Physician
« Reply #10 on: July 18, 2012, 09:05:09 AM »
I figured that you either had a long-term, sentimental attachment to the Jeep or your gun was having a problem. :D ;D
Offline ely
« Reply #11 on: July 18, 2012, 09:11:43 AM »
used jeep? or did they buy it new?
Offline moosehunter
  • Every once in a while
    • Saw it Coming
« Reply #12 on: July 18, 2012, 09:16:58 AM »
Jeff,
 You have a fax #? I can send you diagnoses info.
Have you tried putting the shifter in N? Or move it around in P.
The Ignition switch on that vehicle has a high failure rate. Next time it won't start try turning the key while wiggling it.
mh
Higher than my expectations
Offline Patty
  • Gender: Female
« Reply #13 on: July 18, 2012, 09:20:21 AM »
Boy you sure can tell who the mechanics are on the forum.  :D
I read the title and thought, hmmmm, Jeff must be a really bad shot not to be able to hit a jeep!
Women are Angels.
And when someone breaks our wings....
We simply continue to fly ........
on a broomstick.....
We are flexible like that.
Offline slider
  • sawyer,trucker,tree service
« Reply #14 on: July 18, 2012, 09:37:11 AM »
Jeff just ran your problem by the crew at diesel shop.They said when you get it running start pulling relay's until it shuts off had the same problem on a vehicle and it was a relay.Could be in the ecm ,hope not.good luck
al glenn
Offline Jeff
  • Fearless Leader
« Reply #15 on: July 18, 2012, 09:57:28 AM »
Jeff,
mh
Mike, Fax number is the same as the house number. Just let me know the first 3 numbers of the sending number so we don't answer it and hit the fax button.  Yes, I've messed with the shifter as that was one of my first thoughts, the park neutral positioning switch. Doesn't seem to have any effect. We have also tried wiggling the key. Everything about the ignition switch seems to be normal.  Wiggling the stake on connection does not do anything. wiggling the ignition switch fuse doesn't do anything, but if you remove it, then plug it back in, the vehicle starts. Also, added info, if you shut it off and then try and start immediately, it will start. If you leave it off several seconds, it won't.
Offline whiskers
  • Over what hill? I don't remember any hill.
« Reply #16 on: July 18, 2012, 10:13:59 AM »
You could  place a starter button on a solenoid bypass for those times it wont crank with the key, or a toggle switch in the relay wire to allow it to reset.
many irons in the fire.........
Offline moosehunter
    • Saw it Coming
« Reply #17 on: July 18, 2012, 10:42:57 AM »
Jeff,
 Fax is on the way.
Something to remember with this vehicle (most modern vehicles) is that the ignition switch does not send a signal directly to the starter relay as it used to. The Ign. switch tells the computor that you want to start the engine, the computor tells the relay to start the engine.
 Use the wiring diagram and your test light, you should be able to isolate the problem.
Call me @ work if you are still having trouble.
mh
Offline sharp edge
  • Keep it stupid, simple!!!
« Reply #18 on: July 18, 2012, 11:34:51 AM »
Boss, when it doesn't start it doesn't turnover either?
SE
The stroke of a pen is mighter than the stroke of a sword, but we like pictures.
91' escort powered A-14 belsaw, JD 350-c cat with jamer and dray, 12" powermatic planer
Offline Jeff
  • Fearless Leader
« Reply #19 on: July 18, 2012, 12:25:47 PM »
I should have clarified that.  The starter will not engage in the problem.
Mike, we got only errors on the fax. It said there was a "power failure" what ever that meant. D may have a warranted on this vehicle yet, so before I dig any deeper, I'm going to wait to hear from her and Jeremy. It's parked behind my truck, but I'm sure my Chevy won't tolerate that if I need to go somewhere. :D
Need Help Trouble Shooting MS280 Chainsaw
Started by Chooch7788 on Chainsaws
Last post March 21, 2019, 12:48:17 PM
by Weekend_Sawyer
glow plug trouble shooting???
Started by shinnlinger on General Board
Last post November 18, 2010, 06:14:25 AM
by StorminN
1950's Circle Mill Trouble Shooting
Started by jemmy on Sawmills and Milling
Last post February 13, 2020, 07:46:15 PM
by moodnacreek
question
Help trouble-shooting my 2000 Ford Ranger please
Started by RynSmith on General Board
Last post May 26, 2013, 07:52:07 PM
by millwright
