Author Topic: diesel tank leaking  (Read 9159 times)
Offline slider
  • sawyer,trucker,tree service
diesel tank leaking
« on: July 24, 2012, 09:07:41 PM »
Have a diesel tank leaking .I'm not looking for reasons not to weld it just wondering if someone here has experience at this.If I don't feel comfortable with it i can farm it out.Just don't want to if I don't have to.I have a pressure washer one is heated if i need it.I would prefer not to fill it with water if i can do it safely another way.I can braze it,wire weld it or tig it.Thanks  al
al glenn
Offline LAZERDAN
Re: diesel tank leaking
« Reply #1 on: July 24, 2012, 10:55:25 PM »
NAPA has a very good epoxy fiberglass repair kit.  Fairly simple and quick, and has worked well for me.     Lazerdan
Offline giant splinter
  • Pacific Northwest
« Reply #2 on: July 25, 2012, 12:37:42 AM »
I have one experience with a fuel tank leaking and my mechanic asked me to rub a bar of soap into the crack in the tank. It stopped the leak till he got out to repair the tank, the leak was caused by vibration and he welded it up without removing the fuel. The soap was a good temporary fix and did stop the leak temporarily.
roll with it
Offline scsmith42
    • Whispering Pines Farm
« Reply #3 on: July 25, 2012, 09:17:31 AM »
Slider, I've welded diesel tanks on heavy equipment by flooding the tank with an intert gas (such as C02 from a MIG welder.
I calculated the amount of cubic feet in the tank, and then ran a hose from the regulator to the tank and let it run long enough until the tank was full and the air displaced.  While welding, I left the regulator running as well.
I've also used the water method, but the gas was cleaner.
Tom's 3638D Baker band mill
Offline slider
« Reply #4 on: July 25, 2012, 12:55:54 PM »
i dropped it off this morning .we cleaned it out first then they filled it with soapy water .they then put in a air line and on low pressure let it bubble all afternoon.this method is what they feel is safe.They were using a hose from a tailpipe of a running vehicle until they had one explode.
al glenn
Offline Bogue Chitto
« Reply #5 on: July 25, 2012, 01:23:16 PM »
That is what we did when I was on the fire dept.  Gas tank on a auto would be leaking so we would put bar soap in the leak. Worked well until it was fixed.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #6 on: July 26, 2012, 08:18:11 AM »
Vehicle exhaust piped into the tank will also make it safe to weld.
Offline CHARLIE
  • Don't wait 'til both feet are in hot water before you decide to put your best foot forward.
    • Coulee Region Woodturners
« Reply #7 on: July 26, 2012, 10:44:37 AM »
I'd use an epoxy. That stuff is strong.  Another old method to fix a pinhole leak is to screw a sheetmetal screw, with a little gasket, on it into the hole.
Charlie
Offline lumberjack48
  • 36 yrs ago, cutting Ash saw logs
« Reply #8 on: July 26, 2012, 01:19:47 PM »
I had a gas tank rust out on a pickup, it ended up being about a 4" hole in it. I fixed it with Liquid Steel and screen, worked perfect.
Offline beenthere
« Reply #9 on: July 26, 2012, 02:01:26 PM »
lumberjack
Quote
I had a gas take rust out on a pickup
I finally figured it out. ;)   8) ;D
MF135 Diesel Tractor --- Diesel leaking into crankcase
Started by Left Coast Chris on General Board
Last post May 25, 2008, 08:29:56 AM
by zopi
Leaking oil tank in a 345 husqvarna
Started by Mako Hall on Chainsaws
Last post March 09, 2018, 12:47:18 PM
by Mako Hall
leaking fuel tank on Husky 372
Started by WV_hillbilly on Chainsaws
Last post June 28, 2015, 11:23:31 PM
by WV_hillbilly
Husky 51 Gas Tank Vent Leaking
Started by kenskip1 on Chainsaws
Last post May 27, 2017, 08:17:11 PM
by kenskip1
