Author Topic: 064 advice  (Read 1025 times)
Offline HousewrightVA
064 advice
« on: August 21, 2012, 10:15:41 PM »
I need some tuning advice for my 064. The saw starts fine, it will idle and it will rev OK. As soon as it gets in the cut and there is a load on the motor at full throttle it will die. Release the throttle and it will idle . It was running so-so at half throttle with a load, but is getting worse. I replaced the fuel filter and air filter but no change. Before I just start changing parts til I find the problem, someone please share some wisdom.
Thanks for your help
skidsteer logger
Case 1840  440  580B
2016 LT40 Super
Offline JohnG28
Re: 064 advice
« Reply #1 on: August 21, 2012, 11:49:49 PM »
Have you pulled the muffler off and had a look at the p/c? Not usually a good sign if its getting worse and you haven't changed anything.
Offline Al_Smith
Re: 064 advice
« Reply #2 on: August 22, 2012, 08:57:35 AM »
The symptoms are a classic example of a carb that needs rebuilt .Over time plus the ethanol content of the gasoline the main diaphragm of the carb looses it's resiliancy  and is unable to supply enough fuel for full throttle conditions .
Easy enough fix ,just rebuild the carb .
Offline nmurph
Re: 064 advice
« Reply #3 on: August 22, 2012, 10:15:14 AM »
Cracks in the fuel line will do the same thing.
Re: 064 advice
« Reply #4 on: August 22, 2012, 12:55:12 PM »
The p/c are fine.
Al and Murph..pretty much what I was thinking.
Thank you
skidsteer logger
Case 1840  440  580B
2016 LT40 Super
Offline Al_Smith
Re: 064 advice
« Reply #5 on: August 22, 2012, 03:32:49 PM »
 :D I have rebuilt so many carbs that occasionly I get complacent .More than once I've failed to consider the fuel lines might have been bad .Oh well I kinda figure sooner or later the carb would need rebuilding so it came sooner than later .
Offline JohnG28
Re: 064 advice
« Reply #6 on: August 22, 2012, 10:13:48 PM »
Suppose I was thinking a little further ahead, instead of basics like fuel first. Got thinking rings maybe due to the saw being older.
Looking for advice
Started by jeremiahdixon on Sawmills and Milling
Last post May 03, 2012, 12:20:23 PM
by jeremiahdixon
New here looking for advice
Started by amgont75 on Sawmills and Milling
Last post February 10, 2019, 06:04:48 PM
by YellowHammer
Need Advice
Started by jackpine on General Board
Last post December 15, 2006, 09:23:21 AM
by scsmith42
Just need some advice...
Started by Typhoon on General Board
Last post January 24, 2004, 03:55:52 PM
by EZ
