Author Topic: Woodmizer LT35hd  (Read 3157 times)
Offline MReinemann
    • Reinemann Mill Works
Woodmizer LT35hd
« on: September 04, 2012, 07:26:45 PM »
Getting close to pulling the trigger on a new LT35HD with a debarker.  Just curious to see how you guys that have one have been making out with them and what to look out for etc...
-Matt
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
Re: Woodmizer LT35hd
« Reply #1 on: September 04, 2012, 07:44:20 PM »
Great choice and congrats! Pull the trigger....go ahead.....make my day!  :D
The main thing to look out for is "WHAT YOU DO NOT READ IN THE MANUEL"
When you get your new mill, send us some pics. Can't wait!
GO
Offline Delawhere Jack
  • I ought to know better.....
« Reply #2 on: September 04, 2012, 08:54:16 PM »
Going from your manual mill to a hydraulic will having you grinning like a fool for at LEAST 3-4 hours (several days in my case). I don't know who Manuel is David  :D.....but you should read the manual cover to cover first thing. It's also very helpful if the dealer gives you a little walk through on setup and operation (Thanks Marty).
You already know how to mill, you'll pickup the controls pretty quickly, and you won't be dog tired from wrestling big logs at the end of the day.
DO IT!  ;D
« Reply #3 on: September 04, 2012, 09:10:07 PM »
Looking at the specs on WM site for the LT35. It says std w/ 2  hyd. side supports and 2 manual, you'll probably want to add the two additional hyd. supports. Only $135 more. My 40 (1995) has two manual supports right in the middle, between two hyd supports. When I mill logs under 7', I've got to walk down and move them myself. Sometimes a nub on the log is sticking out, and I've got to use the cant hook to nudge the log over so that I can raise the support by hand. Long story short, I wish all of my stops (supports) were all hydraulic.
Offline Jim_Rogers
  • Keep your chisels sharp.
    • jrsawmill.com
« Reply #4 on: September 05, 2012, 07:41:57 AM »
I think they have an upgrade kit for that.....
Offline pineywoods
« Reply #5 on: September 05, 2012, 09:31:52 AM »
Bibbyman came up with a home made link to couple the 2 middle backstops to the end ones. There's a post in the sawmill section with pics.
Offline thecfarm
« Reply #6 on: September 05, 2012, 10:05:28 AM »
You will like it.
Offline Jim_Rogers
    • jrsawmill.com
« Reply #7 on: September 05, 2012, 10:38:00 AM »
Yes, I think I did see that. But I'm not sure if they copied him or if he copied them..... I thought his came out first but we'll have to ask him about that.....
Jim Rogers
Offline AdamT
« Reply #8 on: September 05, 2012, 12:10:37 PM »
I would double check on the debarker option. I looked at the 35 and thought I'd save some money, til I found out the debarker wasn't an option. That's when I went for the 40. This was 2 years ago and things may have changed though....
I love my hydraulic side supports. (all 4) I wonder why WM doesn't make them all hydraulic to begin with.
Good luck with your purchase! You'll have a blast milling!
2017 Wood-Mizer LT40HDD35-RA
2011 Wood-Mizer LT40 HD
It's better to have it and not need it then it is to need it and not have it
Offline Bibbyman
  • Pro-Sawyer Mary and Bibbyman
    • Warden Sawmill
« Reply #9 on: September 05, 2012, 12:45:36 PM »
Some mil owners had linked the tops of the manual back supports to the top of the power supports before I prototyped the link of the supports from below.
The design concept used on the Wood-Mizer 4 power back support is basically the same as I developed but they link from support to support with three connection rods. My desigh still uses the long factory rod that connects the first to last.   Then I connected the first to second and forth back to third.
I understand that's four power back supports are standard on the LT40 Super and an option on the standard hydraulic.
I also think that the conversion kit will only work on the latest generation mills.
Sawing since '94
Offline MReinemann
« Reply #10 on: September 05, 2012, 05:58:24 PM »
Woodmizer is going to through in the hydraulic supports.  The 35 does come with a debarker, I believe that they added that option about a year ago.
-Matt
woodmizer LT40HD vs. LT35HD
Started by mjancius on Sawmills and Milling
Last post April 30, 2015, 12:29:40 PM
by isawlogs
Woodmizer LT35HD Setworks
Started by WoodyMcSander on Sawmills and Milling
Last post July 05, 2019, 10:38:57 AM
by millwright
Woodmizer LT35HD Pulley
Started by Rhodemont on Sawmills and Milling
Last post January 15, 2018, 03:24:05 PM
by millwright
Woodmizer LT35HD inconsistent thickness end to end
Started by bhraymer on Sawmills and Milling
Last post October 23, 2018, 09:28:29 AM
by Stephen1
