Author Topic: hard to work with no wipers  (Read 3126 times)
Offline barbender
Re: hard to work with no wipers
« Reply #20 on: September 19, 2012, 11:18:51 PM »
Or, "Gee, it should work." ???
Offline Ken
« Reply #21 on: September 20, 2012, 04:26:38 AM »
snowstorm,
We had the exact same issue with our measuring system a few weeks back.  Changed the encoder a couple of times ( i was lucky enough to have spares) before finding out that there was a tiny break in the cable running from the HHM to the encoder.  Changed a $14 cable and all is good for now.
Offline snowstorm
« Reply #22 on: September 20, 2012, 05:55:31 AM »
the encoder came with a new cable. and the way its made you would have to take the encoder apart to change the cable. it plugs in on the inside of the cover
Offline snowstorm
« Reply #23 on: September 20, 2012, 05:32:26 PM »
i found the problem. i took the new encoder out and the shaft was about a 1\16" to long. it hit the drive motor for the tracks. in doing so it pushed the shaft on the encoder up a bit. making it turn hard not good. so i ground a little off pulled the shaft out where it belonged. put it back in. it dosent work must have broke something inside. so i call the keto pro and says that yes it is the right part number and was unaware of the shafts being to long. so he is sending a replacement. coming out of of quebec i dont expect to have it till midweek.
Offline snowstorm
« Reply #24 on: September 28, 2012, 08:21:57 PM »
the new encoder came whith the shaft shortened at no charge. put it in and everything works as it should.
Offline 1270d
« Reply #25 on: September 28, 2012, 08:29:43 PM »
Good to hear your up and running
Hard Work
Started by Magicman on Health and Safety
Last post June 04, 2013, 09:40:24 PM
by Magicman
LogRite R&D hard at work!
Started by Pete J on General Board
Last post October 11, 2005, 07:05:37 PM
by Teri
Why do retired guys work so hard?
Last post November 08, 2004, 07:14:21 PM
by Bruce_A
Spring Means Hard-work!
Started by Woodheat on General Board
Last post April 04, 2014, 09:47:45 PM
by Woodheat
