Dynamic Green Products Inc.
Author Topic: Sealed bearings or greasable bearings on blade guides  (Read 8171 times)
Offline Ga Mtn Man
  • Y'all can call me GMM
Re: Sealed bearings or greasable bearings on blade guides
« Reply #40 on: October 30, 2012, 07:56:29 PM »
From the manufacturer's website:
"The felt sealed ball bearing falls within the product category of deep groove ball bearings.  The characteristics of this group are wider inner or outer rings and the original production designs used a metal shield with a felt ring on one or both sides of the bearing.  However, most of the designs in production today have switched to a heavy duty rubber seal to replace the felt."
So probably not what WM is using.
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #41 on: October 30, 2012, 08:28:53 PM »
WM's bearings are regular over the counter sealed beatings.  The felt washers surely protect them from the soapy water lube mixture, etc.
Offline ladylake
« Reply #42 on: October 31, 2012, 07:51:36 AM »
 The felt washer sounds like a good plan, Larry send me a couple when you get them made.   Steve
Timberking B20 15000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Suffolk  setter Volvo MCT125c skid loader
Offline Cypressstump
  • I'm not so new now!
« Reply #43 on: October 31, 2012, 08:22:34 AM »
humm,. felt washer, good info !  did not know WM used them.
Stump
Timberking 1220 25hp w/extensions -hard mounted
Case 586E 6k forklift
2001 F350 4X4,Arctic Cat 500 4 wheeler wagon hauler
Makita 6401 34",4800 Echo 20"er, and a professional 18" Poulan PRO , gotta be a 'pro' cuz it says so rite there on tha' saw..
greasing sealed ball bearings
Started by coastlogger on Sawmills and Milling
Last post April 20, 2015, 06:50:56 AM
by ladylake
Bearings for roller guides
Started by ozarkgem on Sawmills and Milling
Last post September 04, 2018, 10:52:46 AM
by Pabene
New to me mill and a question about bandmill guides and bearings
Started by TKehl on Sawmills and Milling
Last post August 22, 2017, 12:30:55 PM
by Kbeitz
Blade guide bearings
Started by eamassey on Sawmills and Milling
Last post November 03, 2006, 11:15:32 PM
by Burlkraft
