Author Topic: Frozen Logs???  (Read 2676 times)
Offline Jeff_Green
  • Happy In Branson Missouri!!
Frozen Logs???
« on: January 02, 2002, 09:03:17 AM »
 >:( >:( How am I sopposed to cut these frozen logs?  They make my little 1 1/4 blade go everywhere but straight >:( >:(
Offline woodmills1
  • the truth shall set you free
Re: Frozen Logs???
« Reply #1 on: January 02, 2002, 10:19:23 AM »
try less set and less lead angle.  like 8 degrees and .015 hardwood  and 9 degrees .020 soft.  if you have blades set up for hard and soft already use the hard ones on soft wood.  a little less feed helps also.
Offline Ron Wenrich
Re: Frozen Logs???
« Reply #2 on: January 02, 2002, 03:30:29 PM »
I've always have had problems with logs that are partly frozen.  Sawdust packs on the side of the log and pushes the saw.  When the logs are totally frozen, I don't have a problem.  I'm running a circle mill, but I imagine the problem is the same.
Less lead is also run on circle mills for frozen logs.
Frozen logs
Started by Bruno of NH on Sawmills and Milling
Last post January 06, 2020, 10:51:37 PM
by gmmills
question
Frozen logs
Started by sdunston on Sawmills and Milling
Last post December 27, 2009, 05:13:07 AM
by ladylake
Frozen logs
Started by logmason on Chainsaws
Last post February 11, 2007, 10:32:01 PM
by MDP
FROZEN LOGS
Started by smwwoody on Sawmills and Milling
Last post November 23, 2002, 01:58:59 PM
by Fla._Deadheader
