Tally-I/O
Author Topic: Husky "automatic smart start" -- any good ????  (Read 2196 times)
Offline Bobcat_pa
« on: March 18, 2004, 04:01:33 PM »
I was traveling today and stopped at Husky dealer on the way home.  Got to pick up and look over a 357xp.  I have been interested in this model to provide me more power when working on something bigger than my 346xp was intended for, and it only weights in at 12.1 .  I noticed the end of the decompression value was replaced with a hose assembly that when back into the cover--"automatic smart start".   How long has this feature been on the mid to larger saws?    Is it reliable ?     Oh,  I know some of you are going to push the 372xp, but I think the 372xp is just a lttle more saw than I can handle safely, unless I put a shorter bar on.   Bob.
Offline jokers
  • Chainsaw Freak
Re: Husky "automatic smart start" -- any good ????
« Reply #1 on: March 18, 2004, 04:22:19 PM »
So far so good but a little too automatic for me until it`s proven a little longer.
Russ
« Reply #2 on: March 18, 2004, 05:53:08 PM »
What's it do?
Offline oldsaw-addict
« Reply #3 on: March 18, 2004, 07:35:50 PM »
Its an automatic decompression valve that you never have to touch to start the saw. I would rather have to push the button on it and know its working properly than trust it to work because its automatic. Just my .02 cents
Let there be saws for all mankind!
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #4 on: March 20, 2004, 02:48:33 PM »
I've used the decompressor on my 395 once or twice since I've had it and have never even touched the one on the 372.  It's been my experience that a saw starts harder if you use them.  An engine needs compression to run.  They will make a recoil last longer though ;D.  One winter I worked in a local mill pulling boards and the guys small saw that we were trimming the piles with broke.  They brought us out a 3120 to fish the job :o ::).  I quickly found that if you didn't use the decompressor the saw would start with less pulls.  It was trade off more easy pulls on the recoil of a big saw or less harder pulls.
Offline Woodhog
« Reply #5 on: March 20, 2004, 03:38:33 PM »
I have been using a 357 XP all winter cutting spruce logs, it has the auto compression feature you mentioned...
I have problems with my elbow (and most other joints) and this
feature really works nice..
The saw pulls so easy, just a slight snap and away she goes.
I find it is a real fast limbing saw, all winter it has never jammed while limbing.
I would never have another saw without decompression starting at my age, I think it makes for more safe starting as well.
Offline Bobcat_pa
« Reply #6 on: March 22, 2004, 05:29:34 AM »
Thanks Woodhog.   I am having righ hand/arm problems and too many pulls  results in a lot of pain.  Sounds like the 357xp will fit in nicely.   BOb
Offline tony_marks
« Reply #7 on: March 22, 2004, 05:50:18 AM »
  good gosh was every body drinking from the same spring as me. we all got joint, muscle problems. :D
Offline Hunter
  • Dolmar/ Efco/Redmax/ Silvey Grinder Sales
« Reply #8 on: March 23, 2004, 06:52:26 AM »
The 357 is a strong running saw and pretty light.
I had my decompression valve  switched to the manuel one, cause when the saw was modified, the automatic one would flutter in and out at high rpm's.
EHP ported my 357 and it will outrun a stock 372 hands down. I looked at it as a great investment. Light saw, with lots of power.
Hunter
Jmccomas@insight.rr.com
614-554-2169
Dolmar / Efco / Redmax / Silvey Grinders Sales
Offline TACOMATODD
« Reply #9 on: January 15, 2019, 06:11:23 AM »
I know this is an old thread, but is this "automatic decomp" thing still out there. I have not seen, but sounds interesting.
Trying harder everyday
Offline hamish
« Reply #10 on: January 15, 2019, 04:56:42 PM »
It was discontinued as it proved to be problematic and led to many air leaks.  A bulletin was put up to disable it and use a conventional decomp valve or just plug the cylinder.
Norwood ML26, Jonsered 2152, Husqvarna 353, 346,555,372,576
Fastway Automatic "Flip" Jack Foot
Started by Magicman on General Board
Last post November 13, 2018, 10:10:44 AM
by Bruno of NH
grin
Automatic "Love Letter" generator
Started by CHARLIE on General Board
Last post February 15, 2008, 12:09:07 AM
by sprucebunny
"Smart" phones and Adobe Flash Player
Started by Dave Shepard on Technical Support Topics
Last post June 22, 2013, 12:53:55 PM
by Warbird
wood heating and "smart thermostat"
Started by mf40diesel on Firewood and Wood Heating
Last post February 26, 2015, 09:13:17 AM
by mapleveneer
