CEDAR SET READY FOR MY CUSTOMER
Started by POSTON WIDEHEAD, October 20, 2012, 09:49:24 AM
0 Members and 6 Guests are viewing this topic.
POSTON WIDEHEAD
Cedar slab furniture.
5 foot bench and coffee table.
2 end tables.
All with live edge.
Legs made from Elm trees and accented with Muscadine vines.
8 coats of outdoor CABOT poly and buffed with car wax.
Thanks for your comments.
Mooseherder
fishpharmer
Poston, looks great, you will have some very happy customers.  Curious if all the cedar was milled from the same log/tree?
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
POSTON WIDEHEAD
Quote from: fishpharmer on October 20, 2012, 10:09:45 AM
Yes it was.
Axe Handle Hound
I like it!  You have quite the eye for rustic furniture.
Tree Feller
That's a good looking furniture set, David. You are quite artistic in your work.
Cody
Logmaster LM-1 Sawmill
Kioti CK 30 w/ FEL
Stihl MS-290 Chainsaw
48" Logrite Cant Hook
hackberry jake
Poston, those look great. That table has an extra large amount of sapwood, I like the contrast. You're ok in my book even if you are a panthers fan. ;D
Stephen1
Now that is a beautiful piece of work.
How did you join the elm...Tenon?
POSTON WIDEHEAD
Quote from: Stephen1 on October 20, 2012, 07:06:45 PM
I use 6 inch deck bolts. I pre drill the holes, fill the holes with Gorilla Glue and then run the bolts down tight. The bolt hole is then plugged and then sanded down flush. You can drop this set out of a plane and it'll stay together.  say_what Well......you know what I mean.  :)
jamesamd
All that is gold does not glitter,not all those that wander are lost.....
Okrafarmer
Very nice, Poston. So, how does the bark stay on over time?
Now selling Logrite tools!
POSTON WIDEHEAD
Quote from: Okrafarmer on October 20, 2012, 11:33:21 PM
The best way I have found to keep bark on is to fell the trees in the fall when there is not much water in the cambium. HOWEVER......there is water in the sapwood just under the bark.....so you have to be careful and not damage it.
Another thing, CEDAR (thee red part) has less water in it than any other woods I've used. As soon as I take a BIG cedar out of the woods for a bench, it goes directly to the mill.
I mill a 2 inch slab and hopefully the wood is prime enough for benches.
After I mill my slabs, I let them air under the shed for 24 hours or about.
Then I begin to work them. Because a slab is to wide for a table planer, I use a hand planer to get the saw marks off and then I will belt sand it down to a smooooth finish.
To get the bark to hold, I use outdoor Poly and SOAK the bark. In about 30 hours the bark in frozen into place.
The main thing is to keep the bark and wood out of the sun. Use live edge furniture in your home, covered patio, or any place where it will not get sun or rain on it. Doing this, the live edge will stay on.
Also a lot of people do not think about this. Your bench making starts when you first put the chainsaw in the the tree. Don't damage the bark. Don't drag your log with a tractor or do anything to skin it up. Try to keep everything intact.
As far as the Elm goes,  If you don't damage the bark, it'll be there forever if ya just keep it out of the sun and weather.
Dan_Shade
do you worry about the screws going into end grain loosening up over time?
lots of dull bands and chains
POSTON WIDEHEAD
Quote from: Dan_Shade on October 21, 2012, 09:36:17 AM
I did at one point Dan. I have some benches I built back to 2005. When I pre drill my holes for the long deck bolts, I try to fill the holes with Gorilla Glue. Then before screwing in the screw, I dip it in Gorilla Glue and run it in the wood. Any excess glue that oozes out, I clean it up.
So far the screws and glue have held just as tight as they were at installation.
fishpharmer
Bill Gaiche
Very nice. Don't you just love ERC? bg
isawlogs
   Marcel
giant splinter
Very nice work and a remarkably beautiful finish
roll with it
sawmillhand
Poston   thats some nice furniture there great job.
1990 woodmizer LT40 Hyd  2004 Ford F350 Flatbed. Plenty of tractors.
Wonderful!  I will be bringing an airplane over this Friday to conduct some dropping-from-the-air tests on your furniture  :D.
Have you had any problems with the dreaded powderpost beetles?  They vex me  :).
POSTON WIDEHEAD
Quote from: WDH on October 22, 2012, 10:38:46 PM
No Beetles yet.....that I can hear.  ;D
You may put my firniture on a plane but I don't think the plane will be able to get off the ground.  :D
Busy Beaver Lumber
David
Those benches are awesome and you surely have talent. Would love to have access to some nice cedar like that. Imagine how awesome I could make those benches look if we used the cnc and routed something like an eagle or mountain scene into the back
Fred
Woodmizer LT-10 10hp
6 x 10 dump trailer
Grizzly 6in Spiral Cut Joiner
Twister Firewood Bundler
Jet 10-20 Drum Sander
Jet Bandsaw
Save a tree...eat a beaver!
Dodgy Loner
That is some beautiful cedar, David. I wish I could give you all my knotty cedar for your rustic furniture, so's I could have your nice, clear cedar for my blanket chests! :D
hackberry jake
Dodgy, I didn't notice how clear that cedar was till you said that... Wow!
POSTON WIDEHEAD
Quote from: Busy Beaver Lumber on October 23, 2012, 08:17:07 AM
David
Fred
This is exactly what I had in mind Fred.  8)
