We have contest winners!
A few questions...I've previously read that one of the concerns about stress skins or Sips is the potential for shear (when the outer layer of wood sandwiched between the foam tears away) by the weight of the siding attached (especially something like cement board).
Vapor barrier, yes or no? Most of the diagrams show an interior vapor barrier, but I seem to remember one of the articles I was reading recommended not to use a vapor barrier with this system.
First of all, have you ever seen this happen?
A few questions...I've previously read that one of the concerns about stress skins or Sips is the potential for shear (when the outer layer of wood sandwiched between the foam tears away) by the weight of the siding attached (especially something like cement board).While studying the Larsen trusses on the links above, it looks like sometimes the trusses are partially supported by the foundation and sometimes they are shown cantilevered out in space. Of course, a horizontal truss is very strong (like an I-beam). However, when placed vertically, they just don't look very strong to me. I'm just wondering how strong is the siding plane held 12" out in air when it's attached to a grid held out by thin gussets? Is there a similar shear concern with this system?Vapor barrier, yes or no? Most of the diagrams show an interior vapor barrier, but I seem to remember one of the articles I was reading recommended not to use a vapor barrier with this system. Even though the articles say tightly packed cellulose remains tight, I think I'd always be concerned about the insulation settling with time. Also, any concern about rodents with loose cellulose in the walls (those little beasties seem to find a way)?
In 1990 The University of Colorado School of Architecture and Planning put two insulations materials, cellulose wall spray and fiberglass. They built two identical structures. One with R-10 fiberglass in the walls and R-30 in the ceilings. The second structure utilized cellulose wall spray in the walls and loose-fill cellulose in the ceilings with identical R-values as the first structure. Another the R-value for the insulation materials was identical, their performance was varied. The cellulose insulation required 26.4% less energy to heat than the structure insulated with fiberglass. So as you can see, cellulose insulation, which is made from almost 85% recycled newspaper, can be a more eco-friendly and money saving choice, even compared to fiberglass options with the same R value.
Started by outbackbrandon on Timber Framing/Log construction
Started by glgdiggs on Timber Framing/Log construction
Started by Madman_Mark on Timber Framing/Log construction
Started by swmn on Timber Framing/Log construction
