Author Topic: looking for some bar and chain help on my husky 576xp...  (Read 3676 times)
Offline cb6048
« on: December 15, 2012, 10:28:55 AM »
hi guys two questions
1. my friend gave me a brand new windsor speedtip 32" bar and chain combo only problem is it reads 63...404 on the bar and I have a 576xp that is setup for .375 .050 what do I need to do to use this bar and chain combo and is it worth the switch over?
2. I also have a 24" husky bar with several chains in .375 .058 what do I have to do to make this combo work on the same saw (576xp .375 .050)?
Great site thanks Pete
And still loving my cb6048 5 years no oil!
when hell freezes over I'll snowmobile there too
Offline shelbycharger400
  • m14/04 0
Re: looking for some bar and chain help on my husky 576xp...
« Reply #1 on: December 15, 2012, 10:40:29 AM »
the 32 in bAR with 404, change the saw sprocket.
.375 is .375, dosnt matter on gauge size, they all work with the same sprocket weather its pro spur or rim.   .050, .058 and .063 all work
I occasionally run a 32 in bar .375 with .063 on my jonsered, mostly I run a 16 in bar with .050, sometimes run a 20 in bar with .050.
I have a rim drive on it now.
Offline Cut4fun
« Reply #2 on: December 15, 2012, 11:21:29 AM »
Like he said above just slap on a rim sprocket in 404 onto your saw to run the 32". Swap back to run your 3/8 stuff. Take less then a min to swap rims back and forth.
or you could change the tip on the 404 bar to 3/8 and run 3/8 063.
Offline sawguy21
« Reply #3 on: December 15, 2012, 12:25:31 PM »
Check the fit on the saw, it may be a Stihl bar. That pitch and gauge was commonly used on big Stihls such as the MS880 and 090, the tail pattern is not the same as Husky.  As far as the 24"bar goes, as long as it has the large mount it will work just fine. You will need .058 chain but either gauge will work on the saw without modification.
Offline JohnG28
« Reply #4 on: December 15, 2012, 12:44:08 PM »
You may want to reador the below thread on .404 chains. User was trying a smaller bar in 404 on a Stihl 460 with poor results, may get the same issues with these saws being about same displacement.
Offline Cut4fun
« Reply #5 on: December 15, 2012, 01:11:07 PM »
I never even thought about the OP not knowing the difference in bar mounts  smiley_lit_bulb. Guess he better check that 32" bar for the type mount first.  candle_smiley
Offline cb6048
« Reply #6 on: December 15, 2012, 02:42:48 PM »
gee ya know all he runs is stihl I had better check the bar fit. His biggest saw is a 460 which is right on par for h.p. with my 576xp but this setup would be for intermittent use as I have acquired some rather large od logs for chunking up in the owb.
also I had the 24" husky .058 bar and .058 on my 576 and she really didn't seem right with that setup so I put the stock 20".050 and .050 chain and man it was like night and day cutting so I assumed the .058 was the wrong setup
Offline Cut4fun
« Reply #7 on: December 15, 2012, 02:56:05 PM »
050 058 didnt make the difference  ;). Maybe the chain cutter itself did and a 576 should pull that 24 all day long.
You can run a adapter to use stihl bars on your husky. Also can make your own.
I got pics of doing so but they wont paste here.
Offline sawguy21
« Reply #8 on: December 15, 2012, 07:45:43 PM »
I wonder if you had the small mount bar, if so the chain will not get oil.
  • m14/04 0
« Reply #9 on: December 15, 2012, 09:38:22 PM »
for the adapter for what its worth is easier just pickin one off ebay for 10-14 bux shipped .
Offline hamish
« Reply #10 on: December 15, 2012, 10:28:23 PM »
Small bar mount will not fit without being filed.
Norwood ML26, Jonsered 2152, Husqvarna 353, 346,555,372,576
Offline AdkStihl
    • J.Miller Photography
« Reply #11 on: December 16, 2012, 10:28:12 AM »
Even if you could get that bar to fit your 576.......32" .404 is too much for that saw in STOCK form IMO.
Offline cb6048
« Reply #12 on: December 16, 2012, 10:58:59 AM »
maybe save my dough on converting and invest in ,050 32" setup sounds best?
Offline lumberjack48
  • 36 yrs ago, cutting Ash saw logs
« Reply #13 on: December 16, 2012, 05:49:28 PM »
Baileys have this adapter, so you can use a Stihl bar on a Husky. A couple stove bolt square nuts can all so be used with a little filing.
Third generation logger, owner operator, 30 yrs felling experience with pole skidder. I got my neck broke back in 89, left me a quad. The wife kept the job going up to 96.
Offline JohnG28
« Reply #14 on: December 16, 2012, 08:21:02 PM »
I think going with 3/8" chain in that size is probably best option.
Offline cb6048
« Reply #15 on: December 17, 2012, 06:36:58 AM »
thanks all for the advice
pete
Husky 576xp??
Started by Maineloggerkid on Chainsaws
Last post March 25, 2009, 08:09:45 PM
by Maineloggerkid
Husky 576xp
Started by P15Belanger on Chainsaws
Last post August 05, 2010, 11:07:31 PM
by HolmenTree
HUSKY 576XP
Started by VLACOSSE on Chainsaws
Last post February 01, 2014, 07:35:28 PM
by celliott
Husky 576xp, AT vs. Non-AT
Started by barbender on Chainsaws
Last post March 05, 2018, 10:06:32 AM
by ButchC
