Author Topic: what is the easiest way to cut square ends on odd shaped limbs? now with pics  (Read 2848 times)
Offline limbrat
  • step back and look again
I have pocket screwed a couple of square edged boards together to make a 90. Then mount the limb in the 90 and with a miter gauge, cut square ends on smaller limbs on a table saw. With larger limbs i can make the first cut on the table saw then finish up with a hand saw.
With forks its harder i have mounted them to scraps of plywood and paralled the ends on a table saw you can angle the ends like that too.
I had one the other day that is a 5" limb with three limbs on the other end i added a fourth limb to make a pedestal base. i squared the big end on the table saw with a 90% jig then measured over from the miter slot and marked each limb with a square off the table and edge of the jig and a level to mark around the limb. after much scribbing and sanding i have a good base.
There has got to be a better way to make square ends with out a square edge.
ben
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
Re: what is the easiest way to cut square ends on irregular shaped limbs?
« Reply #1 on: December 16, 2012, 01:48:03 PM »
L Rat.....I'm trying to get into my head what you're doing. Do you have any pics to show us?
Thanks.
Offline Tree Feller
« Reply #2 on: December 16, 2012, 05:49:21 PM »
If you are cutting roundish ends, use a welder's wrap-a-round to scribe a line around the limb and then cut along the line freehand at the bandsaw.
Cody
Logmaster LM-1 Sawmill
Kioti CK 30 w/ FEL
Stihl MS-290 Chainsaw
48" Logrite Cant Hook
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #3 on: December 16, 2012, 07:24:42 PM »
Or use a reciprocating saw.
These Aspen "candles" were not badly out of whack, but were too irregular to satisfactorily use the table or miter saw.
Offline beenthere
« Reply #4 on: December 16, 2012, 07:33:38 PM »
Not knowing the length of the 'limbs', if they were short enought to chuck into a lathe, you could use a parting tool to cut square ends easily.
Offline limbrat
« Reply #5 on: December 17, 2012, 10:24:41 AM »
I can cut parallel ends on limbs like this by using a jig shaped like a piece of angle iron on the table saw.
cutting parallel ends on limbs like this.
  so that i can make stuff like this is so much harder. making the cut is not a problem i can clamp it up and cut it with a handsaw. marking the cut so that the ends are parallel is tough. any ideals?
ben
Offline Jemclimber
Once one end is cut you can flip it upside down and take a drywall square to mark the height of the cut on each of the legs.  That's how I've done bench legs that are too wide to flip and cut on the sawmill.
lt15
Offline Jim_Rogers
  • Keep your chisels sharp.
    • jrsawmill.com
If you get a laser level you could "shoot" a line onto each leg. Then move the level around the leg so you can trace the line all the way around the leg so you can then saw it off.
I think the laser levels I have are offset from the bottom of the level like 1" or so. Then you could saw back the ends to that line, or offset the level line again.
One way to get a straight line around something round is to use a piece of banding. Wrap it around the round thing and trace the line.
But it would have to be nearly perpendicular to the round thing. Not on a slope like those legs are.
So I guess the laser level is the best answer I can think of.
Jim Rogers
Offline pineywoods
That's a piece of cake if you have access to a bandmill or a swingmill. Clamp the table/stool upside down on the mill with the legs sticking up. One slow pass and all the legs are square and the same length. You might need to get a little creative with the clamping...See my post on a cherry chest build for more ideas...
Offline limbrat
Thank you gentlemen, all excellent ideals.
 I have a band mill but have had alot of trouble clamping tall stuff with a narrow base. i guess i could screw it to a scrap of plywood and them clamp that to the bed.
I really like the laser level, one of my son in laws does dry wall i will borrow one from him and give it a try before buying one.
Marking the length in a couple of places with a square then pulling the line around with a level works. But im not very good at it.
 Thank you sirs
ben
Offline jueston
laser level was my first thought too, i purchased mine for one specific task that just seemed a lot easier with a laser level, but since then i have found hundreds of uses for it.
Offline Rooster
  • Tools are extensions of ourselves... share a tool.
    • Photobucket image storage account
Build a large hand saw mitre box?
"We talk about creating millions of "shovel ready" jobs, for a society that doesn't really encourage anybody to pick up a shovel."
Mike Rowe
"Old barns are a reminder of when I was young,
       and new barns are a reminder that I am not so young."
                          Rooster
Offline Al_Smith
Interesting items .
cutting log ends to square
Started by michaelvp on Timber Framing/Log construction
Last post September 17, 2009, 02:06:48 PM
by Doug_D
Heart Shaped Wedding Sign - With Pics
Started by Busy Beaver Lumber on General Woodworking
Last post April 27, 2014, 08:30:39 PM
easiest way to delimb pulpwood?
Started by treefarmer87 on Forestry and Logging
Last post March 22, 2010, 01:44:55 AM
by Bobus2003
Easiest build for newbie
Started by Rob30 on Timber Framing/Log construction
Last post March 19, 2018, 08:34:14 AM
by Rob30
