Author Topic: Question about sawing  (Read 3731 times)
Offline GeneWengert-WoodDoc
Re: Question about sawing
« Reply #20 on: December 19, 2012, 01:46:38 AM »
Regarding strength, slope of grain (SOG) and sawing parallel to the bark or various other tapers.
The SOG greatly affects strength, so if the grain is straight in the tree and not spiral grain or a crooked log or near a knot, the least amount of SOG and highest strength will occur by full taper sawing (parallel to the bark). For handles, drum sticks, and other critical strength products, full taper sawing is a key.  Maybe it should be for table legs, chair legs, etc.
For beams, the strength of a beam used for design is roughly 1/6 of the strength of clear wood, so the SOG is part of this safety factor.  A few people will actually test each piece of wood and sell it based on its strength rather than have this 5/6 reduction.
So, if you full taper saw, you make a stronger product.  Of course, you need to tell the customer or else your higher quality will not be rewarded with a higher price.
Ok?
« Reply #21 on: December 19, 2012, 01:55:32 AM »
Regarding Chemicals for logs...
I cannot legally or ethically suggest a chemical that is not licensed or approved for use on wood.  The idea is that approved chemicals will have less environmental and human risk, especially long term.  They will not be stronger than needed.  Further, when the wood is used in an enclosed environment or when it is sanded or even scraps are burned, there will be no risk to humans or to the environment.  In fact, if the chemical is still on the wood in a fairly strong amount, the law requires you to notify the buyer and you need a license to sell treated wood.  What if the wood is used for a child's toy or for a table or,counter used to prepare food, etc.
The bottom line is that a responsible person will use approved chemicals on wood.  Unfortunately, these chemicals,cannot be made easily at home.  The old homemade chemicals we see in old literature are not safe.
Questions?
« Reply #22 on: December 19, 2012, 02:02:41 AM »
Regarding drying of tricky species, you will find a lot of info in DRYING HARDWOOD LUMBER.  It is out of print, but you can get it on line.  Special note...if you take the on line address for a PDF file to a copy place, then can copy it direct (clear pictures) and even bind it for maybe $25.  We also talk about such things at various dry kiln association meetings.
« Reply #23 on: December 19, 2012, 02:10:07 AM »
The best article on a very functional solar heated kiln is
http://pubs.ext.vt.edu/420/420-030/420-030.html
It is the so-called "Virginia Tech" kiln that I developed in 1978.  The article in the link is by Brian Bond who made some small improvements in the design.  It is inexpensive yet works very well.
« Reply #24 on: December 19, 2012, 02:16:01 AM »
Regarding the pith, which is the exact center and about the same diameter as a pencil, it is not even wood.  The next 15 rings around the pith are special wood so that the tree can easily bend in the wind, ice and snow, etc.  there are microscopic differences, which lead to lengthwise shrinkage of 3% or so while more mature wood has zero shrinkage, is much weaker than mature wood, is more likely to have compression and tension wood, is often full of knots, has steep SOG, etc.  in many products, we avoid this juvenile wood.
Offline Okrafarmer
  • Location: upcountry SC-- Sweetgum capital of the world!
  • Exiled from Sawdust Land--plotting a return
« Reply #25 on: December 19, 2012, 04:10:07 AM »
I think some of us on the Forum (and elsewhere) have gotten into the (bad?) habit of using the terms pith, heart, heartwood, and juvenile wood a little bit too interchangeably at times. We box the heart, but heartwood is a different thing. In some species, the heartwood is most of the wood, such as in black locust. On others, it is nonexistent or very small, such as in persimmon. In many species it seems we are trying to get under the sapwood to get the "good" heartwood, and yet we are trying to avoid the juvenile wood, which, like the sapwood, is poor wood. So in a log like cherry, for instance, we are trying to avoid both, which means it's hard to get a decent piece of lumber out of a 12" diameter log. Or even a 14" log. If we have to avoid the sapwood (often 20% or more of a cherry's diameter) and the juvenile wood (often 20-30% of a cherry's diameter), what do we have left, but narrow flooring boards? So I think what SCSmith is getting at in regards to the pith wood is-- in what species can you leave some of that inner juvenile wood in your lumber without harming anything? For example, walnut comes to mind as being a much more stable wood than, oh, persimmon, for instance. When milling a log, we are trying to include as much of the lumber volume as possible for sale. If we have to throw out large portions, such as the juvenile portion, it is harder to be profitable. So how do we incorporate the juvenile wood into our lumber sales program, when is it permissible to leave some of the juv wood in a board or slab, and what species are more forgiving about this than the others? Also, about the juvenile wood-- is it always exactly fifteen rings, is that more of an approximation, and are the outer rings within the juv wood stronger than the inner ones-- ie, is it a gradual strengthening the farther out you get, or is it more of a sharp demarcation?
No matter how conventional wisdom may fly in the face of radical thought, it's still the most popular type.
Reduced to Uber Driver and a broken MS290 Stihl
Genesis Hardwood Lumber
Offline Ianab
« Reply #26 on: December 19, 2012, 04:45:23 AM »
I'm pretty sure the 15 growth rings is a generalisation, probably about right for the common Nth American hardwood species? A 15 year old oak or cherry isn't going to yield any high quality lumber, no matter how you saw it.
But a 15 year old Radiata pine or Lyptus can be a decent saw log.  Sure that area immediately around the pith  is going to be unstable juvenile wood, and react as Dr Gene states. But with growth rings ~1" wide, you get out of that unstable wood pretty quick. Those fast growing trees also never actually get to form any sap wood, effectively it's all sapwood, so you don't have the sapwood issues.
Different (more stable) species will also let you sneak in closer to the pith before the wood becomes too unstable.  Working with local Monterey cypress and Port Orford cedar, if a board is completely free of that centre pith, it's generally OK. Leaving the pith in a board is generally going to cause issues.
But the comments about taper sawing (following the grain) where possible are certainly true. Leave the taper waste in that low grade centre pith area, and taking the straight grain clear boards from the outside of the log makes a lot of sense.
Offline Piston
  • ...Brick by brick my friends...brick by brick!
« Reply #27 on: December 19, 2012, 04:26:05 PM »
The article in Sawmilll and Woodlot about taper sawing has been my favorite article since I read it.  I've reread it numerous times and it is very well written.
-Matt
What the Lion is to the Cat the Mastiff is to the Dog, the noblest of the family; he stands alone, and all others sink before him. His courage does not exceed his temper and generosity, and in attachment he equals the kindest of his race.
« Reply #28 on: December 19, 2012, 07:36:00 PM »
Indeed, it is a gradual transition.  Certainly, 15 years is a generalization, but it a good rule of thumb.
I would suggest, and maybe we should start a new thread, that the way we become more profitable is by improved marketing and through valued added manufacturing.  The commodity called lumber needs more customization.  I am giving a keynote talk on January 17 about this and will post my talk...I could go on forever, and I know it works and have examples in the talk.
Offline Okrafarmer
« Reply #29 on: December 20, 2012, 08:46:22 AM »
A good many of the people who buy lumber from me are looking for customization of some type.
Online Stephen1
  • Where there is a will, there is a way!
    • muskoka Sawmill
« Reply #30 on: December 27, 2012, 02:59:52 PM »
Good post, so I am dropping in for a visit.
Sawing Question
Started by Tree Feller on Sawmills and Milling
Last post October 07, 2012, 10:32:49 PM
by Magicman
sawing question
Started by furltech on Sawmills and Milling
Last post August 13, 2014, 01:36:56 AM
by furltech
Sawing Question
Started by Coondog Sawyer on Sawmills and Milling
Last post February 27, 2014, 12:29:05 AM
by 5quarter
Another Sawing Question
Last post October 09, 2012, 12:51:06 PM
by qbilder
