Dynamic Green Products Inc.
Author Topic: Black Walnut  (Read 761 times)
Offline boatman
Black Walnut
« on: December 26, 2012, 11:09:02 AM »
A friend of mine has been given some 16'x10"x10" Black Walnut.  Clear, with checks.  They have been outside stacked and covered for years.
Other than the normal board foot value, what might these be worth?
The guy he got them from has enough to build a log home out of, then he changed his mind.
Offline Chuck White
  • Sawing Mobile since 2005
Re: Black Walnut
« Reply #1 on: December 26, 2012, 01:09:06 PM »
Whew!!!!!!!!!
Don't know how much it would be worth, "lots" I suppose!
~Chuck~
1995 Wood-Mizer LT40HDG25 Kohler - Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline boatman
Re: Black Walnut
« Reply #2 on: December 26, 2012, 01:14:38 PM »
Maybe.
I am just wondering if has a higher potential value as a 10x10 or as lumber.  I am not familiar with specialty markets.
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
Re: Black Walnut
« Reply #3 on: December 26, 2012, 02:59:34 PM »
Start researching markets in various parts of the country. Take pics and send emails to different outlets who sale Walnut.
Sounds like there's some money here.
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
Re: Black Walnut
« Reply #4 on: December 26, 2012, 03:07:19 PM »
The checks are going to reduce the amount of recoverable boards, but won't lessen the strength of the timber, unless there is severe grain runout.
Offline shelbycharger400
  • m14/04 0
Re: Black Walnut
« Reply #5 on: December 26, 2012, 03:56:03 PM »
look them over real well, and see if your able to save something, taking the best one first from the log, 2x 3x or 4x ,  or 1x stock, even if its shorts, you can recover something even from the worst logs.     Call a few local timber frame builders and see what they are worth and if he is interested to buy.  Photos are always good
Offline boatman
Re: Black Walnut
« Reply #6 on: December 26, 2012, 04:06:10 PM »
The wood is sitting on an Island and will cost @ $5000 just to move it to the dock.  Then no less than that to get it across the water.  Then two semi loads of expense to move it.........
He may be better off using the wood in his construction business on the Island.
he just told me it was in a Tobacco barn for 5 years then moved there and has been sitting outside, stacked and covered 9 more years.
The stacks that are 1 1/8" cleaned up nicely in the planer.  I think I posted pictures of the stuff last year when this "deal" started.  But there are covered stacks so not much to see.
Offline beenthere
Re: Black Walnut
« Reply #7 on: December 26, 2012, 04:49:38 PM »
Boatman
Is this the other thread you started?
http://www.forestryforum.com/board/index.php/topic,51872.msg747963.html#msg747963
Maybe can tie these together if admins will help, so the reader gets the bigger picture.
Are you looking for an investor?
Offline Stephen1
  • Where there is a will, there is a way!
    • muskoka Sawmill
Re: Black Walnut
« Reply #8 on: December 27, 2012, 11:55:46 AM »
That is a lot of money for something with no real end use. I would save some money by chaining the bundles and then floating them across to the mainland. As in the last thread it might just be usless.
thumbup
What's the best way to saw Black Walnut
Started by rbjones03 on Sawmills and Milling
Last post September 06, 2005, 12:00:04 AM
by Tom
Black Walnut(again)
Started by EZ on Sawmills and Milling
Last post August 31, 2003, 03:32:09 PM
by EZ
Black Walnut
Started by Weekend_Sawyer on Sawmills and Milling
Last post July 31, 2003, 05:59:07 PM
by ElectricAl
What's the best way to saw Black Walnut?
Started by Gilman on Sawmills and Milling
Last post August 23, 2004, 10:41:43 PM
by beenthere
