Dynamic Green Products Inc.
Author Topic: Brake Drum Forge...Rat-Rod style!  (Read 4571 times)
Offline Rooster
  • Tools are extensions of ourselves... share a tool.
    • Photobucket image storage account
« on: January 06, 2013, 12:32:24 AM »
I have a friend named Ted who is a fellow carpenter...but he is also a very good smithy (Changed to smith or blacksmith, per Dave S.  ;D).  He has made custom hold-down clamps for my timber-framed sawhorses, but more importantly...he has re-kindled my interest in "pounding hot iron".
So after doing a search on the FF on blacksmithing and forges, I learned that I could make my own forge made from a used brake drum...I did a Google search and found youtube videos and an informative forum called...
iforgeiron.com
I found out that guys use pieces and parts to make these forges for little or no money...so, here's my forge build.
I started out with a junk push  lawnmower and stripped off the blade and motor, saved the deck and the handle pieces.
I went down to the local auto mechanic and bought a used brake drums off of a truck for $2.
I bought 2" black pipe fitting for the airway and ash dump.
I flipped the mower deck upside-down and cut a larger opening so that the lip of the brake drum would keep it suspended without falling through.  I mounted the mower deck to an old portable table saw stand, and attached a pair of feed bin wheels using steel nail-stakes (for setting concrete forms) as axles.
I bought a 8" cast steel floor drain and added three bolts (to help keep it slightly elevated to allow more air) and used it in the bottom of the drum to allow the air to feed the fire without the charcoal falling down the pipe.
I am currently using a two speed hairdryer for my air source, but I might opt for an antique hand crank blower...if I can find one cheap.
I did notch the drum on opposite sides so that I can lay flat stock or rod across the fire, and I have a tractor exhaust cap (not pictured) on the lower pipe to control the air flow and ash dump.
Ted also recommended that I use fire brick to try and trap the heat and force it towards the center of the "fire-pit" to help conserve fuel and have better heats. The bricks are movable and really help.
Now I just have to figure out how to mount my post-vise to the side of it, and make some type of bracket to hang my tongs from.
Well, that's my portable "Rat-Rod" brake drum forge...stay tuned for future add-ons.
Rooster
"We talk about creating millions of "shovel ready" jobs, for a society that doesn't really encourage anybody to pick up a shovel."
Mike Rowe
"Old barns are a reminder of when I was young,
       and new barns are a reminder that I am not so young."
                          Rooster
Online ljohnsaw
Re: Brake Drum Forge...Rat-Rod style!
« Reply #1 on: January 06, 2013, 01:29:19 AM »
Awesome!  thats something i need to do
Offline beenthere
« Reply #2 on: January 06, 2013, 01:53:14 AM »
Nice build. Anxious to see how it works for you.
Offline Holmes
  • 1840 house
« Reply #3 on: January 06, 2013, 08:18:21 AM »
Interesting and very clever
Think like a farmer.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #4 on: January 06, 2013, 08:45:10 AM »
That is very innovative.  I love something outta nothing.   :)
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
« Reply #5 on: January 06, 2013, 09:04:40 AM »
Can't doing anything but smile when I see this......pretty good idea Rooster.  :)
Offline thecfarm
« Reply #6 on: January 06, 2013, 09:08:32 AM »
I'm staying tuned to see some iron projects come out of your forge.  ;D I have all that kicking around accept for the table saw top. But in my metal pile I could build a table.
Offline Burlkraft
  • Professional survivor......Still a wooodturner
« Reply #7 on: January 06, 2013, 10:57:50 AM »
That is awesome Rooster  8)
Why not just 1 pain free day?
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #8 on: January 06, 2013, 11:09:22 AM »
Very cool! Scrounging up whatever you have on hand and making something new out of it is an essential smithing skill. :) Oh, a smith is a blacksmith, a smithy is the building he works in. Wouldn't want your friend to get mad at you because he thought you think he looks like a small dimly lit building puffing coal smoke. :D
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #9 on: January 06, 2013, 11:20:41 AM »
Excellent post, Rooster.
Thanks for letting us share.
~Chuck~
Retired USAF 1989, Retired School Bus Driver 2012, now semi-retired Mobile Sawyer
1995 Wood-Mizer LT40HDG25 Kohler - Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline chevytaHOE5674
  • Forester
« Reply #10 on: January 06, 2013, 11:23:00 AM »
That's neat. I like making something from a bunch of nothing parts. This looks like something I may have to try.
Offline Larry
    • Copas Sawmill
« Reply #11 on: January 06, 2013, 12:16:29 PM »
I have one of those brake drum forges.  It works just fine for what I do.  Mind has a little flap damper in the pipe right below the grate to refine airflow a bit.
I like your grate...might copy that. :)
I pick up charcoal after burning slabs for fuel.
Offline Rooster
« Reply #12 on: January 06, 2013, 01:01:48 PM »
And...some more photos:
Here I used the upper handle for an adjustable long rest.
And these are two of the first projects...I learned that the best way to develop skills is to make tools for the forge, which then you can use to make more tools for the forge,...and so on, and so on...
Fire tender on the left and tongs on the right.
Rooster
Mike Rowe
                          Rooster
Offline thecfarm
« Reply #13 on: January 06, 2013, 01:07:45 PM »
Clever little guy,ain't ya.  ;D  Where's your anvil? I have bookmarked this. I'm a thinking again.  :D
Offline Rooster
« Reply #14 on: January 06, 2013, 01:27:47 PM »
Check out Post #65
http://www.forestryforum.com/board/index.php/topic,61933.60.html
Before:
After:
Thanks for all the responses and encouragement!!!  More to come!
Rooster
Mike Rowe
                          Rooster
Offline JohnW
« Reply #15 on: January 06, 2013, 02:50:43 PM »
You certainly have the knack, Rooster.  Don't mount your leg vise on the forge (and if that's not what you were thinking, kindly disregard this post).  Mount your leg vise near the forge.  You could use a log standing on end, exactly the right length, or if you're working on a dirt floor, sink a large post into the ground.  iforgeiron, probably has lots of information about mounting post vises, as you've probably noticed by now.
Offline thecfarm
« Reply #16 on: January 06, 2013, 02:55:53 PM »
Rooster,I forgot about that thread and I posted in it too.  ::)
Offline stumpy
  • I feel alot more like I do now than I did before
    • Rustic-woodfurniture/Stumpy's Wood Works
« Reply #17 on: January 06, 2013, 04:25:56 PM »
Hey Craig, I just found this thread.  Call me next time you're gonna "play" at the forge. I'd like to come over and watch/help 8)
Woodmizer LT30, NHL785 skidsteer, IH 444 tractor
Offline Rooster
« Reply #18 on: January 07, 2013, 11:45:29 AM »
Stumpy,
You are always welcome at my place!!!  I just got the wood stove in the house fired up last week, and I want to make some fire place tools for it.  I'll call you and let you know.
Thanks again to everyone for their comments and questions.
Rooster
Mike Rowe
                          Rooster
My Timberjack 230 Brake Drum was smoking today.
Started by Tillman on Forestry and Logging
Last post March 24, 2015, 12:43:28 PM
by Remle
question
Need help. Split taper bushing on LT40 band brake drum. Key or no key?
Started by Delawhere Jack on Sawmills and Milling
Last post May 02, 2017, 01:29:59 AM
by Kbeitz
HELP , STIHL 028AVE OLD STYLE CHAIN SPROCKET (not the drum type)
Started by mainewoodcuttah on Chainsaws
Last post July 08, 2008, 10:57:55 PM
by Captain
Pigeon Forge
Started by wls on Travel Guide
Last post October 12, 2009, 10:57:22 PM
by Jasperfield
