Author Topic: A steam condensor for a Shaver OWB  (Read 679 times)
Offline yellowrosefarm
« on: January 12, 2013, 06:38:13 PM »
For anyone that has a Shaver OWB with the open pipe on the side you know why I did this. For those who don't, I'll try to explain. To keep a Shaver full of water you have to open the water valve daily and let it run until water pours out of an open 1/2" pipe on the side. If the water is on the cold side, as it heats up and expands, it pushes out of the pipe. So, when I first got my stove I was going through a couple of gallons of water a day. Water was dripping out of it almost all the time. I knew there had to be some better way. So, I got a 3/4" sprayer strainer from tractor supply. drilled holes in the bowl and mounted it upside down. The wire mesh screen inside acts as a condensing unit. To check the level, I just unscrew the bowl and look inside. If there is standing water in the bottom, all is well. I only add a small amount of makeup water every 3-4 days now. I attached it to the pipe on the stove with a piece of 3/4" heater hose and some worm gear clamps.
Offline Holmes
  • 1840 house
Re: A steam condensor for a Shaver OWB
« Reply #1 on: January 13, 2013, 10:15:20 AM »
That is a very clever idea and a good way to solve an issue. 8) Well done
Think like a farmer.
Wierd condensor idea.
Started by Dave Shepard on Drying and Processing
Last post January 03, 2007, 11:03:59 PM
by Dave Shepard
Nyle L200 Condensor Coil leaking?
Started by WoodenHead on Drying and Processing
Last post September 03, 2014, 07:06:59 PM
by red oaks lumber
Shaver OWB
Started by sawmilllawyer on Firewood and Wood Heating
Last post December 04, 2008, 11:57:53 PM
by sawmilllawyer
Shaver brand OWB
Started by LeeB on Firewood and Wood Heating
Last post December 28, 2011, 06:25:02 PM
by TreeWinder
