Author Topic: Lt40 finally home/problems  (Read 3291 times)
Offline Bibbyman
  • Pro-Sawyer Mary and Bibbyman
    • Warden Sawmill
Re: Lt40 finally home/problems
« Reply #20 on: January 14, 2013, 09:36:14 AM »
Is your mill hydraulic or manual?   If manual, it will not have a contact strip.  If hydraulic, the strip is on the main rail opposite the hydraulic box.
Sawing since '94
Offline Ocklawahaboy
  • Learning as I go
« Reply #21 on: January 14, 2013, 09:41:49 AM »
Manual mill.
Thanks for the clarification.
Offline trapper
« Reply #22 on: January 15, 2013, 10:05:54 PM »
My mill also has the 3 place pulley Should be another on the other shaft the belt goes on.
Gives 3 different speed ranges.  Having only 16 horse I use the slowest range.
LT40 cutting problems!
Started by RWTF on Sawmills and Milling
Last post January 13, 2010, 03:35:11 AM
by customsawyer
lt40 hd alignment problems
Started by attwood on Sawmills and Milling
Last post May 08, 2014, 09:01:53 PM
by Dave Shepard
LT40 Slow moving problems
Started by PA_Walnut on Sawmills and Milling
Last post November 22, 2017, 06:14:44 AM
by PA_Walnut
LT40 Super hydraulic problems
Started by barbender on Sawmills and Milling
Last post May 28, 2014, 08:36:26 PM
by Peter Drouin
