Tally-I/O
Author Topic: How to measure bar length?  (Read 5552 times)
Offline Mark M
  • Wilton, ND
    • Some of My Pictures
« on: April 01, 2004, 08:13:50 AM »
So then, how do you measure the bar length? I got a used 019 and I need a new chain so I need to know how long the bar is. I know that 12" and 14" are common sizes for this saw but when I measure it the length is about 13" from the tip to where it comes out of the saw. So where do you measure to?
Offline redpowerd
Re: How to measure bar length?
« Reply #1 on: April 01, 2004, 08:30:50 AM »
it dont say on the bar? it may be in metric
NO FARMERS -- NO FOOD
northern adirondak yankee farmer
Offline redpowerd
« Reply #2 on: April 01, 2004, 08:34:37 AM »
oh, thats proly a 14"
Offline jokers
  • Chainsaw Freak
« Reply #3 on: April 01, 2004, 10:34:40 AM »
Mark,
It sounds like a 14"er without me going an measuring. It should be imprinted near the tail of the bar with the pitch, gauge, and number of drive links. How many DLs does the current chain have?
Russ
Offline oldsaw-addict
« Reply #4 on: April 01, 2004, 01:46:03 PM »
The bar is normally measured from the front of the case to the end of the bar, then you round off the number to the next nearest even number. I just count the drivelinks pitch and gauge of the chain that is already there and get another one just like it.
Let there be saws for all mankind!
Offline Rocky_J
« Reply #5 on: April 01, 2004, 02:39:27 PM »
A 14" chain will have 50-52 links. 16" chains are usually 55-57.
Offline Mark M
  • Wilton, ND
« Reply #6 on: April 01, 2004, 02:56:09 PM »
Thanks everyone, I'll take it off and see what I can tell. It is a Stihl bar but I didn't see the info I was looking for stamped on the bar. If nothing else I'll count the links.
Offline Tree_Frog
« Reply #7 on: April 01, 2004, 06:15:06 PM »
          Russ, Rocky and Oldsaw-Addit
 They must be tired  or short of time at this moment. They know the answer about saw bars or about saws altogeather I have been reading their reply on an other site they are very Good
Tree Frog
Offline Rocky_J
« Reply #8 on: April 01, 2004, 06:48:13 PM »
Actually, I just figured we had already put enough time and effort into this particular question. I gave him an accurate answer, and there are other good and accurate answers here. Also, when he walks into his Stihl dealer and slaps the old bar and chain on the counter, it will take the guy about 2 seconds to see what length it is. So further detailed analysis here is pretty much wasted time. Hopefully the dealer will also sell him a sprocket to go with the new bar and chain.
Kevin, I hope I don't sound too sarcastic here. Not intentional, but if I do then please edit as you see fit. I seem to have the social skills of a....... well, of a skwerl.  ;D
Offline Duane_Moore
  • the heck with edit it.
« Reply #9 on: April 01, 2004, 06:52:16 PM »
Mark. I do belive that if you measure from the first stud to the tip of a bar this will give you the length, go ahead guys give heck. Duh---Duane
village Idiot---   the cat fixers----  I am not a complete Idiot. some parts missing.
Offline Mark M
  • Wilton, ND
« Reply #10 on: April 01, 2004, 08:17:36 PM »
That's kinda what I was looking for Duane but I appreciate the other info too. I was trying to avoid taking it apart just right now.
Rocky, I don't know much about squirrels but there is another animal that comes to mind. ;)
Offline Rocky_J
« Reply #11 on: April 01, 2004, 08:41:16 PM »
Sorry Mark. Just mark a tooth with chalk or a marker and count from there, you can spin the chain on the bar by hand until you get back to your marked tooth.
But if it's been that long since you removed the side cover for service, you probably want to take the saw to your dealer and let him look at it. Just to make sure you don't have other damaged parts, such as the sprocket or chain catchers or AV mounts or....
Offline Mark M
  • Wilton, ND
« Reply #12 on: April 01, 2004, 08:54:34 PM »
Hi Rocky
I just bought it off eBay and the chain is pretty well worn down. I hadn't thought about checking the chain catcher so I'm glad you mentioned that. I'll llok at the other stuff too.
Offline Tree_Frog
« Reply #13 on: April 02, 2004, 05:16:41 AM »
 :P
 Rocky is telling you how to save money and whats is best for your saw .new sprocket-bar-chain work perfect togeather and last longer. Cheaper in long run---How do I know he and other members on an other site gave me the same advice .
    The young man  with the straw hat is correct  to  I been given this advice also
     You have been getting advice from some of the Best
   Tree Frog
Chain length, bar length, drive links, questions
Started by Jim_Rogers on Chainsaws
Last post May 21, 2013, 07:19:02 PM
by MEloggah
How to measure a log
Started by buzz on Ask The Forester
Last post February 04, 2004, 07:56:10 PM
by SwampDonkey
Measure set
Started by bandmiller2 on Sawmills and Milling
Last post August 22, 2011, 08:18:13 AM
by paul case
How to Measure
Started by summerjob on Sawmills and Milling
Last post September 22, 2005, 10:41:42 PM
by pigman
