Author Topic: ???Tanaka  2 stroke oil      (Read 3441 times)
Offline Flapjack
  • doin what I can, with what I got.
« on: April 01, 2004, 01:59:33 PM »
Hello all.........
This is my first post, and I would like to know if any of you,
had any first hand knoledge of    Tanaka   2 stroke oil. The bottle dosen't have any ratio / mixing information,it has a squeeze
chamber,and tells you to "mix a chamber full with a gallon of fuel,and that will take the guess work out of  mixing". Seems a little strange. But regardless of the instructions, is the oil any good?
                                      Thanks !
Offline oldsaw-addict
Re:  ???Tanaka 2 stroke oil
« Reply #1 on: April 01, 2004, 02:46:20 PM »
Welcome to the forum Flapjack!
How many ounces is the little chamber?
I'll give you the amount of oil to add to a gallon of gas to make a specific ratio.
32:1  4oz of oil added to 1 gallon of gas
40:1  3.2oz oil to 1 gal. gas
50:1 2.6oz oil to 1 gal gas
100:1 1.3 oz oil to 1 gal gas beware, 100:1 is not recommended for most 2 stroke engines, it has too little oil to really lubricate the bearings and engine and will normally result in a lean seizure.
50:1 is the most widely accepted ratio for regular oil
40:1 and 32:1 are widely used for synthetic oil such as Mobil MX2T or Maxima K2 full synthetic oil. I recommend full synthetic oil for 2 cycle engines, just make sure its 2 cycle full synthetic oil you're using in your fuel oil mix. it reduces plug fouling and carbon deposits in engines, and has less smoke so you can mix it at 32:1 and use it in saws made for 50:1 ratio mix without any problem
Let there be saws for all mankind!
Offline wiam
« Reply #2 on: April 01, 2004, 07:12:11 PM »
At work we use Tanaka oil in all two strokes, mixed per label.  Tanaka trimmers, Stihl chainsaws,  very old Lawnboy pushmowers and Tanaka pumps.  This seems to work well for us to have only one mix around  and all engines seem to run OK.
William
Offline Duane_Moore
  • the heck with edit it.
« Reply #3 on: April 01, 2004, 10:32:35 PM »
 8) 8)Welcome Flapjack, we glad to have here. Duh---Duane 8) 8)
village Idiot---   the cat fixers----  I am not a complete Idiot. some parts missing.
English walnut trees
Started by Left_Coast_Rich on Sawmills and Milling
Last post January 21, 2004, 03:50:53 PM
by D._Frederick
PTO circle mill  Good or Bad  ?
Started by WV_hillbilly on Sawmills and Milling
Last post January 08, 2005, 11:43:56 AM
by Buzz-sawyer
Wood-Mizer  4 deg  blades  ?
Started by Ohio_Bill on Sawmills and Milling
Last post January 11, 2003, 07:56:47 PM
by Bro. Noble
question
Nyle  -  -  Powered Vents or Not ???
Started by DR_Buck on Drying and Processing
Last post February 21, 2005, 01:27:34 PM
by Mike_Doolittle
