Dynamic Green Products Inc.
Author Topic: New wood stove  (Read 2389 times)
Offline Bill Gaiche
  • Home built bandsaw, Kioti DK4510. Sthil 211&361
New wood stove
« on: January 31, 2013, 10:01:46 PM »
It gets a little to cold down in the shop this time of year to do much of anything. So today I decided it was time to make a change and built me a new stove. Tomorrow I will put in service to see how it does. bg
Offline DanG
Re: New wood stove
« Reply #1 on: January 31, 2013, 10:12:37 PM »
The pic didn't show up, Bill. ???
Offline Bill Gaiche
Re: New wood stove
« Reply #2 on: January 31, 2013, 10:15:33 PM »
How about now. I got the cart before the horse when I posted it. bg
Offline DanG
Re: New wood stove
« Reply #3 on: January 31, 2013, 10:17:52 PM »
Mo' betta.  That's a DanG nice stove.  You'll prolly hafta open a winder now.
Offline beenthere
Re: New wood stove
« Reply #4 on: January 31, 2013, 10:19:37 PM »
Looks great, and clean workmanship.
Really neat artsy graphics above the loading door.  ;D
Offline thecfarm
Re: New wood stove
« Reply #5 on: January 31, 2013, 10:20:03 PM »
Good job on the welding.  ;D  May want to put a few pieces of 3/8 by whatever long on that door so it don't warp so bad.
Offline doctorb
  • Unofficial Team Physician
Re: New wood stove
« Reply #6 on: January 31, 2013, 10:22:10 PM »
I am very impressed and humbled.  I have no knowledge or skill to build that.  Nice job.
Offline Bill Gaiche
Re: New wood stove
« Reply #7 on: January 31, 2013, 10:34:52 PM »
You are probably right about adding some metal across the door. I started to but thought I would try it first and if needed I will add some. Thanks for the comments guys. bg
Offline Bill Gaiche
Re: New wood stove
« Reply #8 on: January 31, 2013, 10:45:56 PM »
Beenthere, a little welders helper (paint) will cover up all that messy stuff. bg
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
Re: New wood stove
« Reply #9 on: February 01, 2013, 08:32:06 AM »
I like the grain in the steel.  ;D
Good job. Get it smoking. Lots of cold days left.  smiley_thumbsup
Offline Hilltop366
Re: New wood stove
« Reply #10 on: February 01, 2013, 08:40:14 AM »
Nice job, It will be nice to get some heat in the workshop.
I hate to break it to ya but that stick is never going to hold up the grate once you start a fire in there! ;D
Offline drobertson
Re: New wood stove
« Reply #11 on: February 01, 2013, 09:05:35 AM »
Nicely done Bill, nothing like some good ole wood heat in a shop for sure,  I have built many wood stoves back in my early days,  they were a popular design, the only real difference was on the door opening, we went a bit shorter top to bottom, this allowed room for a diverter shelf above the door, this helps keep the smoke from flowing out to quick,  hopefully you won't have this problem,   david
Offline thecfarm
Re: New wood stove
« Reply #12 on: February 01, 2013, 09:24:57 AM »
A piece of metal will fix it up just fine.
Bill I hate to disagree with you,but paint won't make my welding look better.  :D I do Ok.I just never had someone really teach me and seems like I'm always working with metal that is rusted too.
Offline Al_Smith
Re: New wood stove
« Reply #13 on: February 01, 2013, 10:16:53 AM »
Nice big door but you may want to put a flapper inside over the top .Reason being when you stoke it it will blow a lot of smoke back at you .
I had to do that on a down drafter I built years ago but after the fact it was already in the house .
That thing has enough surface area it should put out the heat .
Offline thecfarm
Re: New wood stove
« Reply #14 on: February 01, 2013, 10:21:35 AM »
I was just thinking,one of my friends has an All Nighter with fire bricks along the sides and back. Has a peice of angle iron that the bricks go under. I helped him replace them many years ago.
Offline Al_Smith
Re: New wood stove
« Reply #15 on: February 01, 2013, 10:34:16 AM »
I have a Lopi glass front that also has bricked sides .
When I built the down drafter I bricked the bottom of the Vee where the fire goes through the coals and the other side was the angled grates the air goes through .The brick side theoretically would have been the hottest .The pot licker still got hot enough to made the sides red if you didn't watch it .I think if I would have stood one layer of brick along the side above the vee that probabley would have worked better .My oh my did that stove put out the heat .
Now on that door being on the draft side away from the flue I'm not so sure it would warp or not .
Offline r.man
Re: New wood stove
« Reply #16 on: February 01, 2013, 06:19:57 PM »
Nice stove Bill. Better than factory.
Offline lowpolyjoe
  • Hey
    • JeRM Software Page... Hobby projects
Re: New wood stove
« Reply #17 on: February 01, 2013, 07:40:06 PM »
Beauty!   What kind of welder you use?
Offline dave_dj1
Re: New wood stove
« Reply #18 on: February 01, 2013, 08:53:06 PM »
Looks nice but a couple of things I would do, weld some 1" flat stock around inside the door opening to help keep it straight and then do the same with the door so that it fits inside of the opening.
Then maybe you could use some rope gasket to help seal it off.
Let us know how it works.
Offline Bill Gaiche
Re: New wood stove
« Reply #19 on: February 01, 2013, 10:10:05 PM »
Today  Built a fire in it. Sure enough it smokes out the front top. Added 6 1/2" of metal across the top to make the opening smaller. It did help a lot but still have a little. When it gets some ashes to hold some hot coals I believe it will help.The opening is 19" wide x 10" tall now. I don't plan on using any brick in it because it is just for the shop. Brick may help but don't know how much. I am not sure what a smoke deflector would look like. Maybe you could help me out on that. You were right about the wood that I used to hold up the grates didn't last long. Good thing I put some weld on them. I use a Hobart 200amp gas welder. Plan on getting some kind of small fan to put above and behind the stove to push some of that heat around. The door did warp a little but the latch pulls it shut just fine. Thanks for your input, it always helps for the experienced to share there wealth of knowledge. bg
New stove but no wood
Started by alan gage on Firewood and Wood Heating
Last post November 06, 2019, 08:45:56 PM
by alan gage
Best wood stove for me?
Started by Wedgebanger on Firewood and Wood Heating
Last post December 18, 2019, 12:01:18 PM
by doc henderson
CB wood stove
Started by coxy on Firewood and Wood Heating
Last post September 30, 2016, 08:25:54 PM
by DDW_OR
New wood stove
Started by Jerryok1971 on Firewood and Wood Heating
Last post December 31, 2017, 08:17:54 AM
by Peter Drouin
