Author Topic: woodsplitter speed  (Read 1995 times)
Offline r.man
woodsplitter speed
« on: February 09, 2013, 09:42:00 PM »
I think I am going to try to rent out my woodsplitter. My preferred market would be for people making a video showing how fast their splitter is compared to another machine. Originally I thought that my splitter would be a good choice to make another machine look fast but I am now of the opinion that I greatly underestimated it's ability to make another machine shine. Today I used it in the cold, in the shade and to say it was slow is not doing it justice. I think glacial fits. So if anyone wants to rent a splitter to either use in a video or just to prolong your firewood processing to avoid the honeydo list, pm me.
Offline Al_Smith
Re: woodsplitter speed
« Reply #1 on: February 10, 2013, 07:34:40 AM »
 :D What are you using for hydraulic fluid ,gear oil ? Bite the bullit and let that stuff gurgle out into a bucket and refill it with dextron II and the problem will go away .
Offline jdtuttle
  • If it's worth doin, it's worth doin right
« Reply #2 on: February 10, 2013, 07:42:38 AM »
Now that's funny  :D
Have a great day
Offline Al_Smith
« Reply #3 on: February 10, 2013, 08:06:19 AM »
In real life it's a pain in the buttocks .Rambling on a couple of examples .
First was a splitter I made for my brother in laws father about 25-30 years ago .The cheap miser filled it with used crankcase oil .In cold weather it was slow as a snail .
I worked for an electrical contractor who was so cheap he squeecked .Blew a line on a line truck that had a 36 gallon per minute Commercial Shearing hydraulic pump .Blew 50 gallons of hydraulic fluid out in about a minute .It was type A fluid ,which is auto tranny fluid .
That tight wad had it filled with SAE 10wt and it took an hour before it would raise the boom in Jan .Well tight wad or no he soon figured out what he had saved in lower priced fluid was being gobbled up paying two journey man and a groundie an hour a day drinking coffee waiting for the system to warm up .
Offline muddstopper
« Reply #4 on: February 10, 2013, 01:05:50 PM »
At work, we used to run rando68 hydraulic fluid in everything. Wintertime operation was slow as molassas until the oil warmed up. Several years ago, we swapped everything over to Dextron3. This greatly improved warmup times in cold weather. One drawback was that if something would leak, the dextron would find it and ooze out. Another thing we noticed is we had less hydraulic failures. Pumps seem to last longer and  we have less sticking valve problems. I now use dextron in every one of my hydraulic projects whether its a splitter or a dump trailer.
Offline r.man
« Reply #5 on: February 10, 2013, 02:56:12 PM »
Today it was close to freezing which is as cold as I want to use the machine and it was back to its normal slow speed.
Offline Al_Smith
« Reply #6 on: February 10, 2013, 03:46:21 PM »
 :D Well I doubt it would speed up any up yonder in the land of ice and snow .About the only way to pep it up other than change the oil would be to put a kerosine salamander heater on the oil tank about an hour before you fire it up .
Well I suppose if you ever get it warmed up enough to gurgle out of the tank drain you could take the oil in the house to keep it warm .I'd imagine to the Mrs. that that would go over about as popular as a turd in a punch bowl .7 gallons of oil smelling up the house like it were a diesel repair bay in a truck stop .Not good .
Offline r.man
« Reply #7 on: February 10, 2013, 07:11:59 PM »
Al, read your post to my wife and she said that is exactly how popular that would be.
Offline justallan1
  • living and learning
« Reply #8 on: February 10, 2013, 09:47:16 PM »
My ranch truck has a hydrabed bale feeder on it and we use dextron 3, plus if it's going to be real cold or if it has to stay outside in the wind for some reason I put a magnetic Kats heater on the res.
Allan
Offline tyb525
  • Always learning.
« Reply #9 on: February 10, 2013, 09:53:45 PM »
What's your ram cycle speed? Mine seems too slow, it can't keep up with me so I end up having to wait for it. I don't have anything to compare it to though.
Offline Al_Smith
« Reply #10 on: February 11, 2013, 07:01:56 AM »
Oh yeah I know exactly how that would go over .As much as I would like to haul a smelly old chainsaw into the house to tinker with  in this cold weather my better senses cause me to refrain from such foolishness .Oh the repercussions would be unthinkable . :D
Offline r.man
« Reply #11 on: February 11, 2013, 07:04:07 AM »
I will time it by steamboats Tyb but I may have to wait for warmer weather because having both hands available may not do it. The good thing is that with the fairly wide wedge I very often only have to run the block about 4 inches in and it will pull apart easily.
Offline r.man
« Reply #12 on: February 11, 2013, 07:08:11 AM »
Married life Al. I saw a motorcycle in a living room two weeks ago. The fellow lives in his own apartment in his widowed mothers house and probably does his carburetor work on his kitchen table. Single.
Offline Al_Smith
« Reply #13 on: February 11, 2013, 07:16:06 AM »
About that oil in the house .Now this is no kidding in 1963 it got to around 30 below for around 10 days two weeks which is as cold as I ever remember in the buckeye state for an extended period of time .
My dad had a1938  Allis Chalmers model B that would start in any weather you could crank it over in .Key word crank no self commenser .
We would gurgle the aprox. 3 gallon of straight 30WT oil into a bucket which took about an hour and put it in the basement next to the coal furnace .The oil didn't smell any worse than oil treated stocker coal .
The old tractor would fire right up .Never ran anti freeze ,tarped off the radiator and never froze it up .--trivia from the "good old" days  in the big corn field --
Offline Logging logginglogging
« Reply #14 on: February 11, 2013, 08:43:47 AM »
In real cold weather they usta run Kareosean as coolant in the old tractors. The kareosean would eventially rot the rubber coolant lines so a lot of times they would replace them with metal tubing. Never froze up that way.
Offline thecfarm
« Reply #15 on: February 11, 2013, 09:07:37 AM »
I can remember my Father talking about kerosene in the old cars.He did not get a tractor on the farm until 1950.
I have a factory one that I brought. Just like many others out there. I do have to wait for it at times. But I don't mind the waiting. My speed record days are long over.  :D
Offline r.man
« Reply #16 on: February 11, 2013, 09:21:44 AM »
Cfarm, it didn't say this to Tyb but you will understand. Standing waiting for the block to split is both annoying and relaxing. It's a little rest before I have to pick up the next block. When the blocks are medium, say 50 pounds, it's mostly annoying but when I am doing the 120s it is a nice short breather.
Offline Al_Smith
« Reply #17 on: February 11, 2013, 12:03:07 PM »
Much ado about splitter cycle time .My homebuilt which does have dextron for fluid is not set up with the engine speed at max .It runs perhaps slightly slower at that engine speed than my bud's 4 inch cylinder ,mine is a 5 inch .Splitting out of a pile of 50 pounders once the cylinder returns via a detent valve I've got the next piece ready to go .So why run the dickens out of the engine then you can't keep up with it anyway .Oh sure a 21 year old could --for a while .
Offline muddstopper
« Reply #18 on: February 12, 2013, 06:27:47 PM »
Warmed my splitter up this past wkend splittng a trailer load of apple and pecan. Kept 2 busy feeding and 2 busy stacking while I just pulled the lever. We had about a cord split and stacked in about 30 min. I run at half throttle to, if they had been able to keep up, I would have liked to rev'ed it up just to of seen them sweat.
Offline tyb525
  • Always learning.
« Reply #19 on: February 12, 2013, 07:17:18 PM »
Man I wish mine went that fast
Woodsplitter OIL
Started by Woodhog on Forestry and Logging
Last post June 07, 2009, 06:14:44 PM
by mike_van
woodsplitter for big blocks
Started by wiam on General Board
Last post May 19, 2005, 04:24:22 PM
by maple flats
woodsplitter cradle
Started by CT Trapper on General Board
Last post July 20, 2011, 08:00:02 AM
by Magicman
log lifter for woodsplitter
Started by bitternut on General Board
Last post April 23, 2006, 11:45:56 PM
by bitternut
