Author Topic: Buying saw logs  (Read 2537 times)
Offline Qweaver
  • The cabin is done and we love it
Buying saw logs
« on: February 13, 2013, 03:59:35 PM »
I have a customer that wants boards for B&B siding.  Says that he wants 1"x8" x12' white oak.  I have no 12' white oak logs.  The local log yard is asking $1 BdFt for WO. I would need four 24" logs to fill this order.  Those four logs would cost $1300!  Poplar is about half that @$750.  I've used Poplar, Sycamore and white Pine for siding with good results if coated with a quality finish.
By the time I go pick-up and saw the logs I'll have 7 or 8 (or more) hours in the job.  So $1700 to make 150 boards and 150 battens.    That's about $9.50 per board and $1.90 per batten      I need to find a cheaper supplier for logs.
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
Re: Buying saw logs
« Reply #1 on: February 13, 2013, 04:41:07 PM »
Wow Q, since I don't live in your area, I don't know what to tell you.
Paying $1.00 / BF for a log is kinda steep down in S.C.
WO sells for around $250 a thousand / BF down here and sometimes less.
Check with a local Forester and see if he can point you toward a logger or if he has an idea.
Offline pyrocasto
Re: Buying saw logs
« Reply #2 on: February 13, 2013, 04:45:08 PM »
Yeah that's about double the highest price around here. Those better be some veneer grade logs!
Offline T Welsh
  • Woodmizer LT-40-HD http://www.welshtreeservice.com
    • Welsh Tree Service
Re: Buying saw logs
« Reply #3 on: February 13, 2013, 04:58:26 PM »
I resell all my White Oak for $1.00 a bf. Its hard to come by and the wood is the best oak for outside projects. If the customer wants White quote him a price for what he wants, then offer alternatives.In your area the prices will not change much between suppliers,but check other mills just to keep informed. Tim
Re: Buying saw logs
« Reply #4 on: February 13, 2013, 05:05:55 PM »
Good post Tim. Qweaver, you could also have the customer buy the logs from the log yard and all you have to do is charge him to saw. That way you don't tie up your $$$.
Offline SPD748
  • "Tuam Libera Mentem"
Re: Buying saw logs
« Reply #5 on: February 13, 2013, 05:12:28 PM »
I totally agree with David. Have the customer purchase the logs from whomever so your cash isn't tied up. Also, as David stated, white oak sells around here for $250-$300/thousand. I can't imagine it would be triple that elsewhere.
-lee
Frick 0 Handset - A continuing project dedicated to my Dad.
410 Deere, 240 Massey... I really need a rough terrain forklift :)
Sawing Since 1-19-2013 @ 3:30 pm
Serving Since 2002
"Some police officers give tickets, some gave all."
Offline drobertson
Re: Buying saw logs
« Reply #6 on: February 13, 2013, 06:24:35 PM »
I can kinda see why they are so high, being that big, most likely they can get a verneer price in that range, you should be able to get smaller ones at a lower cost, 1200 bdft of 1x8's   I''m thinking in the 15-20 log range, and you should be under 500 for a load, hope you get it,  david
Online stavebuyer
Re: Buying saw logs
« Reply #7 on: February 13, 2013, 07:35:53 PM »
The market for good quality butt white oak logs large enough to quartersaw (18'+) is $1.00 + in the Appalachain region. Any particular reason your wanting 24" diamter logs? The yield and price per mbf should be much less for smaller diameter second or third cut logs?
Offline Bibbyman
  • Pro-Sawyer Mary and Bibbyman
    • Warden Sawmill
Re: Buying saw logs
« Reply #8 on: February 13, 2013, 07:53:19 PM »
$1.00/bf is not what I'd call "sawlogs". We pay about .25/bf for upper cut white oak logs.  Most are plenty good for making siding.
Butt cut post oak logs will work just as well and cost much less. We can also buy burr oak for less than white oak.
We would use logs 12-14" diameter for 8" wide boards.
Sawing since '94
Offline hackberry jake
Re: Buying saw logs
« Reply #9 on: February 13, 2013, 08:05:54 PM »
I'd be a wealthy man if I could get $1 a bf for white oak in the log. Heck I can only get .65 a foot for 5/4 #1 lumber!
Offline mikeb1079
Re: Buying saw logs
« Reply #10 on: February 13, 2013, 09:01:53 PM »
i was thinking along the lines of bibbyman too.  does the mill have burr oak available?  it's in the white oak family and as far as i know has the same rot resistant characteristics.
that's why you must play di drum...to blow the big guys mind!
homebuilt 16hp mill
99 wm superhydraulic w/42hp kubota
Offline GeorgeK
Re: Buying saw logs
« Reply #11 on: February 13, 2013, 09:20:30 PM »
I have someone in Cinci looking for the same logger quoted me 30 cents but logs not that large.
George Kalbfleisch
Woodmizer LT40, twin blade edger, Bobcat A300, Kubota L48 and yes several logrites!
Offline drobertson
Re: Buying saw logs
« Reply #12 on: February 13, 2013, 09:34:02 PM »
The last several posts mentioned PO< it is a white oak we know, I have used it plenty for many folks around here, they even ask for it over the WO,(pretty) wood.  I have cut in the neighborhood of 10,000bdft alone for one hog farmer, PO is all he wants. It began around 4 years ago, and they are still as good as new, with a few exceptions you would expect with routy boars, ;D   This looks like a very doable solution for the fellow who needs his B&B siding. As a side note, I had to tear down our old barn several years back, after sanding and planing many of these, they were all PO, and really had the look!  And plenty solid after over 60 years, just the usual end rot from rain splash.
Offline sigidi
Re: Buying saw logs
« Reply #13 on: February 14, 2013, 04:44:57 AM »
Down here, may not be the best of help, but we pay $200 per cube for top quality sawlogs so thats about $47c/bft personally I don't care how good the log is at more than twice that price it would want to be square and self cutting  :o :o :o
Always willing to help - Allan
Offline WoodenHead
Re: Buying saw logs
« Reply #14 on: February 14, 2013, 09:29:29 PM »
I concur that White Pine makes good siding.  I can buy that for $400 per thousand delivered (when available).  That's mostly what I've been sawing and selling (1 x 8, 1 x10 and 1 x 12).  White Oak (or red) can be purchased around here for about $600 per thousand delivered or $500 per thousand picked up.  I thought oak around here was expensive!
I just looked at some oak this morning that I am purchasing - white oak from one of my logging friends and red oak from a local farmer.   :)
Some of the older folks around here claim that basswood was often used for siding on old barns about 100 years ago.  But go with what the customer wants.   ;)
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
Re: Buying saw logs
« Reply #15 on: February 14, 2013, 09:33:44 PM »
That's better than the $2/ft a friend of mine was quoted for white oak logs. ::) He checked another source and is getting the timbers he needs sawn for less than that.I haven't checked local prices lately, but white oak usually doesn't bring much around here.
Is it common to use WO for siding in other parts of the country? It's almost always white pine around here.
Wood-Mizer LT40HDD51-WR Wireless, Kubota L48, Honda Rincon 650, TJ208 G-S, and a 60"Logrite!
Offline tyb525
  • Always learning.
Re: Buying saw logs
« Reply #16 on: February 15, 2013, 12:23:58 AM »
Lots of tulip poplar used for siding around here. It won't rot if it's not too close to the ground.
Offline GeorgeK
Re: Buying saw logs
« Reply #17 on: February 18, 2013, 08:54:17 PM »
Around here good white Oak goes into Whiskey barrels and is big bucks the rest is as a logger told me 30 to 40 cents.
George Kalbfleisch
Buying logs
Started by Engineer on Forestry and Logging
Last post May 15, 2004, 04:03:21 AM
by SawDust_Studios
Buying logs
Started by Bub on Sawmills and Milling
Last post March 02, 2014, 04:46:40 PM
by red oaks lumber
Buying Logs
Started by Ga_Boy on Forestry and Logging
Last post October 12, 2004, 08:39:17 PM
by Ohio_Bill
buying logs?
Started by paul case on Sawmills and Milling
Last post January 06, 2013, 09:57:20 PM
by WDH
