Author Topic: manual log turner  (Read 6059 times)
Offline paul case
  • Original wearer of the PCM.
Re: manual log turner
« Reply #20 on: March 15, 2017, 07:16:39 PM »
Welcome to the forum, sdsherer.
I doubt if you will get an answer as bibbyman doesnt frequent here as much since retiring from sawing. BTW did you notice this thread was 4 years + old?
You can use the search function and put in manual log turner you will surely come up with some vids that would work and lots of new Ideas.
Here is the turner that was on my ez boardwalk 40.
PC
pc
Offline plantman
« Reply #21 on: March 15, 2017, 07:55:42 PM »
How do you like your ez boardwalk 40 ? Thinking about buying one.
Offline paul case
« Reply #22 on: March 15, 2017, 08:07:19 PM »
It worked real well for me. I had a 20 hp honda. I miss being able to cut a 36'' wide board.  I put a pineywoods turner/clamp on it and that worked real well too. Pictures of it are in my gallery. Boardwalk mills are tough and easy to learn on.
However I needed higher production so I bought a really used 94 LT40hd. and then another, now a 3rd.
PC
pc
Offline Slingshot
« Reply #23 on: March 15, 2017, 08:44:31 PM »
 sdsherer;  Here is a video I made of the LT30 I had with a 12 volt winch I used in place of the manual winch. Works great and fairly fast.
I have posted this before...
Charles   sling_shot
Offline plantman
« Reply #24 on: March 15, 2017, 11:16:02 PM »
Paul, couldn't you have just add some hydraulic or electric  log turning mechanism yourself ? I think they put a 24 hp Honda on them now with a 28 hp optional engine available.
Offline paul case
« Reply #25 on: March 15, 2017, 11:22:48 PM »
I did. I could have easily automated it to death, just didnt have the time, oh and I didnt want to be the guy trying to reinvent the wheel.
PC
pc
Offline woodweasel
  • I'm No Longer New, But Green As A Gord
« Reply #26 on: March 16, 2017, 11:58:16 AM »
 That was an old post of my from 2013.  The manual turner did just fine. My new Hydraulic tuner is THE BOMB as the young kids now  a days say  :D :D
Offline plantman
« Reply #27 on: March 16, 2017, 08:43:42 PM »
I guess those woodmizers hold up pretty well ? I'm a little skeptical about the cantilever design. Looks like the metal would fatigue and it would sag over time or simply not cut as true because it would be less ridged. The frame looks a little light when you compare it to a mill built with structural steel.
Offline Brucer
« Reply #28 on: March 16, 2017, 09:35:36 PM »
?? The frame is definitely not light, and it is definitely made from structural steel.
I've sawn close to half a million board feet on mine. It's 11 years old an has taken all the abuse I could throw at it. It cuts as true as the day I got it.
The pole mill down the road from me use a manual LT40 for years to salvage their oversized butt ends -- it had 6000 hours on it when they finally replaced it. It was still in good shape, but they couldn't keep up so they replaced it with an electric super hydraulic. That had over 8000 hours on it when they finally sold it. They'd have kept it but their market collapsed in 2008.
You'll find lots of people who have sawn over a million BF (and sometimes 2 or 3 million) on a Wood-Mizer mill.
Bruce    LT40HDG28 bandsaw with two 6' extensions.
Offline paul case
« Reply #29 on: March 16, 2017, 11:59:21 PM »
I know of 2 LT40 hyd that are still running and have over 10,000 hours on them. Each will still cut true and square and can cut an 1/8'' thick board if you want(I was gona say so thin it only has 1 side but....).
I think woodmizer has their mills figured out. They cut well and last a long time as well. Thats not to say they are the only one who has.
PC
pc
Offline bandmiller2
« Reply #30 on: March 17, 2017, 07:36:21 AM »
I break sawmilling down into two category's 1) hobby sawyers that cut for themselves occasionally and 2) guys that cut for hire. If you cut for hire you need a hydraulic turner, nothing less. If you cut for a hobby you still need a hydraulic turner but you can get by with various manual turners as your not after production, just ease of use. I think their would be a market for a compact after market hydraulic unit that could be easily added to manual mills. Two models battery and 115v. Could ether be Piney woods type or two plain. Chain is nice but too hungry for power and doesn't serve a secondary function as a clamp. Frank C.
Offline Brucer
« Reply #31 on: March 18, 2017, 06:34:28 PM »
... If you cut for hire you need a hydraulic turner, nothing less. ...
I didn't know that, so I cut for hire with a manual turner and it worked out OK :D :D. Mind you, I was a young 55 year old when I started ;D.
I was making enough money that after a year the bank was willing to lend me enough to upgrade to a hydraulic mill :).
lt30 manual turner
Started by trapper on Sawmills and Milling
Last post April 04, 2013, 01:29:40 PM
by Andries
Manual log turner on Woodmizer
Started by sawyerkirk on Sawmills and Milling
Last post September 13, 2002, 09:35:14 AM
by sawyerkirk
Video of WM manual toe board and turner??
Started by Brad_bb on Sawmills and Milling
Last post February 12, 2017, 08:05:14 PM
by Darrel
Using the Manual Log Turner Woodmizer LT40
Started by richhiway on Sawmills and Milling
Last post May 09, 2019, 08:47:17 AM
by Resonator
