Dancing with the Devil
Started by WDH, February 28, 2013, 09:59:36 PM
I cut pecan ( smiley_devil) today, so I am a little beat up and put out.  I cut one board today that even a PhD in geometry could not figure out  :).  I am going to either have to have a serious talk with the genus Carya, or either come to the conclusion that this genus cannot be rehabilitated  :-\.
I have 6 more logs to go and not as much appetite to saw them as I had when I started.  Anybody need any bowed, thick-n-thin, split, green pecan boards for a project?  I will make you a deal.  They are free  :D.
hackberry jake
I have some of the very same boards!
The temperature is about 30° here now. I can think of a project real fast.   :D
By the way,did someone mention PIE????
mikeb1079
Quotetell me kid....have you ever danced with the devil by the pale moonlight?
i'm sorry to hear that your dance turned so sour wdh.   :'(  however i believe i read that you're retired, live in georgia (where the temps are in the 70s?, and have a 200 acre woodlot.  now i don't feel so sorry for you anymore.   :D :) :laugh:
homebuilt 16hp mill
Quote from: mikeb1079 on February 28, 2013, 10:19:52 PM
I guess that if you put it like that, then things are not too bad at all.  What is a little pecan misery in the big scheme of things  ??? :D.
Ray, maybe we need to stick to the nuts  :).
mikeb1079
 :D :D :D
pecan is just there to remind you of how nice it is to saw anything else.   :)
homebuilt 16hp mill
The problem is that I also have three hackberry logs to saw, too  :)
POSTON WIDEHEAD
hackberry jake
Quote from: WDH on February 28, 2013, 10:37:27 PM
Oh, I see how it is, discriminating against the ole hackberry, and I thought I was welcome here  :(
Jake,
You have a tendency to twist and warp.  This can be overlooked  :D.
Po-Jo
so is there any hope for pecan wood? other than the smoker? I had always thought there must be something you can use/ build with that wood, even if its a barn / chicken coup , tho I was hoping more for flooring , interior wall, heck even some type of furniture,
5quarter
WDH...cut your 3 hackberrys, stack em up and pile those pecans on top to keep everything in order.  ;) :D
Blue Harbor Refinishing
bama20a
Quote from: Po-Jo on March 01, 2013, 08:06:36 AM
Yep,There is if you know how to work with it,Look here.https://forestryforum.com/board/index.php/topic,62883.0.html
It is better to ask forgiveness than permission
ND rancher
WDH,  I'm wondering, if you deliver I would take it of your hands.(just saying) I would like to meet this  smiley_devil wood you talk about. Remember I'm new and (like a teenager) nothing is impossible!     Keith
TimberKing B-20.  Have been bitten by the bug! Loving life !
CalebL
Why do you guys have such a problem with pecan?  Put a 10 degree blade on and crank your tensioner as far as it will go and have at it.  I also found a diesel/bar oil lube works really well.
2005 LT40 HDD34
2000 Cat 226 Skid Loader
mesquite buckeye
Quote from: WDH on February 28, 2013, 09:59:36 PM
Just keep flippin that log till they don't curl no mo.
WH_Conley
Do what I do with Hickory. Make 4 cuts, call it a cross tie and cut the slabs into firewood.
If anybody wants anything else out of Hickory, the price goes up enough to cover the nerve pills. ;D
Bill
mesquite buckeye
Quote from: CalebL on March 01, 2013, 09:45:21 AM
Or a 9, or maybe a 7. I don't get what all the hubub is about. Can't imagine the slabs curl up more than 6 or 8 inches during the cut. Big deal. Once you get the tension out, should be no problemo. Try some big, curvy lateral branches on a mesquite or a cottonwood if you want to see some drama.
OneWithWood
Danny, this is but a test from the wood god.
Your task, or trial if you prefer, is to accept the shenanigans of those logs and make something beautiful and useful out of them.
It can be done and you are just the man to do it  :D
I think those little sticks used to impart flavor to cooked meats are a true thing of beauty!  :)
One With Wood
dgdrls
For us northerners who only saw Pecan's cousin the Hickory as I understand,
is this true?
"Clever as the Devil and twice as pretty."
― Holly Black
anyone care to share some Pecan pics?
DGDrls
hackberry jake
CalebL
hahahah........Nice.  I have some pics of some 24" wide pecan slabs though......to be continued........
2005 LT40 HDD34
I had some 2" yellow birch sawed some time ago, just part of a whack that I wanted random thickness and width from some logs. There was 2 or 3 of those that twisted like a spiral staircase. I never looked close at them to see what was going on with the grain. But they came from nice logs. At least they was nice when I hauled them in to mill. Never know sometimes. Maybe I got traded. :D
Not a blade or a lube issue, but a tension in the log issue.  Did not matter if you flipped the log after each and every cut.  Nothing you can do about some logs except cut the lumber thick like was mentioned.  Maybe the other logs will behave better  :).
I have seen smaller Pecan logs that could/would not be sawed.  My experience has been that the larger the log is, better it behaves.
