Author Topic: EAB Prevention  (Read 878 times)
Offline southernilfarm
EAB Prevention
« on: March 03, 2013, 03:36:06 PM »
Hello all,
    We've got a very nice ash tree in our yard we don't want to lose.  In this effort, we have purchased a product made by Ferti Lome called "Tree and Shrub Systemic Insect Drench".  The nursery we purchased it from states it will prevent an EAB infestation, or kill EAB if they already are establised in a tree.
    We'll be using this product soon.  Anyone out there ever use this?  If so, what was the result?
Thanks,
Mike
Kioti DK40se HST with FEL and other cool attachments.
Offline ArborJake
Re: EAB Prevention
« Reply #1 on: March 03, 2013, 07:53:24 PM »
 Do you know what the active ingrediant is. Should be on the label. I have used a chemical called Meritt. Its a very effective systemic but the studies put out by the ISA show mixed results in treating for EAB. Havn't seen or heard alot else about treatments that work.
thick and thin lumber company. qaulity manufacturer of saw dust and slab wood.
Offline DonT
  • Lifes rough wear a helmet
Re: EAB Prevention
« Reply #2 on: March 03, 2013, 10:26:22 PM »
Treeazin is the treatment most used in Canada.It is a systemic approach as well.I am also curious to know if anyone has used the product you mention.How is it applied?  DonT
Re: EAB Prevention
« Reply #3 on: March 04, 2013, 10:39:50 PM »
Active Ingredients are
Imidacloprid, 1-{6-Chloro-3-pyridinyl} methyl - N-nitro-2 imidazolidinimine 1.47%
Thanks,
Mike
Offline celliott
Re: EAB Prevention
« Reply #4 on: March 04, 2013, 11:32:35 PM »
How is this applied? I was under the impression the only effective means to prevent EAB was to have pesticides injected into the tree.
Could be wrong though, wouldn't be the first time!
Chris Elliott
Clark 666C cable skidder
265rx clearing saw
Offline ohwc
    • Old Hat Wood Co.
Re: EAB Prevention
« Reply #5 on: March 05, 2013, 07:00:46 AM »
The Michigan DNR has some very good information and links on their site. What you are using should work for prevention from what I have been reading.
Re: EAB Prevention
« Reply #6 on: March 06, 2013, 10:36:29 AM »
This product is applied in amounts based on diameter of trunks, added to water, and poured around tree.  Follow application with same amount of plain water in same area.  Supposed to last 12 months and claims to stop any existing infestation while preventing any new activity.  It was not cheap - $106.00 for 2.5 gallons.
I'll be applying this in the next couple weeks.
Thanks,
Mike
honeysuckle prevention
Started by maple man on Forestry and Logging
Last post May 01, 2016, 10:10:26 PM
by killamplanes
An ounce of prevention
Started by terrifictimbersllc on Sawmills and Milling
Last post November 07, 2013, 09:20:51 PM
Poison Ivy Prevention
Started by Ford_man on Health and Safety
Last post February 20, 2015, 08:17:12 PM
by Glenn1
Fire prevention
Started by Exador on Forestry and Logging
Last post December 22, 2005, 01:15:15 PM
by Ron Scott
