Dynamic Green Products Inc.
Author Topic: Thank You Magicman  (Read 1333 times)
Offline paul case
  • Original wearer of the PCM.
Thank You Magicman
« on: March 05, 2013, 10:29:12 PM »
I am not totally set in my ways, but I have a certian way I like to do things. However I had been sawing some Biguns and today I had one oriented backwards, big end toward the saw, and since MM had told everyone that is how he likes to saw logs that are big enough to need a little whittlin, I tried it. It worked great. I only had to trim a little on one log out of 4 on the small end and once I started a cut there was no more whittlin neccesary.
3 of the 4 logs I cut today were 36'' on the butt end so they took some ''bibbying'' down to get them sawed. The mill wouldnt turn them the first time. I had to help with the forklift. The total of the 4 logs yeilded over 1600bdft.
So Thank you so much Magic. I appreciate your help today.
PC
pc
Offline JustinW_NZ
  • Just Hacking and stacking.
    • Logs2Lumber
Re: Thank You Magicman
« Reply #1 on: March 05, 2013, 11:40:33 PM »
Nice to see credit given where credit is due, seems rare now days?  :(
I like to saw the big end first on those big ones, means I don't misjudge when I get to the other end... (that's just me showing my newbie colours I thought...  :D)
Cheers
Justin
Gear I run;
Offline woodyone.john
« Reply #2 on: March 06, 2013, 02:52:24 AM »
same.
Saw millers are just carpenters with bigger bits of wood
Online Chuck White
  • Sawing Mobile since 2005
« Reply #3 on: March 06, 2013, 07:34:03 AM »
Glad things worked out for you Paul.
Sawing "big end first" can save a lot of headaches!
~Chuck~
Retired USAF 1989, Retired School Bus Driver 2012, now semi-retired Mobile Sawyer, 2018 Silverado 4X4
1995 Wood-Mizer LT40HDG25 Kohler - Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline Leigh Family Farm
  • Live life the way you want. You only get one.
    • Isagenix
« Reply #4 on: March 06, 2013, 07:37:15 AM »
And the FF comes through again! I'm just happy to have found this place and see that others are benefitting as much as me!  8)
There are no problems; only solutions we haven't found yet.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #5 on: March 08, 2013, 10:09:04 AM »
Say what  ???   I am glad that you had a good day Paul.   :)
Yup, I like the big ends first on the (too) biguns.  Small end first on the rest.
Offline dboyt
  • Log On!
« Reply #6 on: March 08, 2013, 11:34:57 AM »
Ought to take a poll here.  Everyone who figured it out BEFORE loading an oversized log for the first time, raise your hand.  About the third time I had to drive in wedges so I could back the blade out to make room for the chain saw to do a little trimming, it dawned on me smiley_dark_bulb.  I figure if I hang out on the forum enough, I'll get the hang of it.  Now, if I could just remember to lower the toe rollers when I've got a flat side down, and keep the clamps lower than the blade, I'd cut some lumber (I even cut into a toe roller once, but I don't want to talk about that).
Offline thecfarm
« Reply #7 on: March 08, 2013, 04:50:26 PM »
That's part of the secret handshake deal. never admit you saw into something on the mill that is not wood.  ;D  I have my hand out so you can shake it.  :D Everytime I do it,I feel so stupid too.
Thanks to Magicman
Started by pnyberg on Sawmills and Milling
Last post April 05, 2011, 12:11:29 AM
by captain_crunch
? for magicman and others
Started by albirk on General Board
Last post March 19, 2011, 08:36:37 AM
by miking
Hey Magicman...
Started by Ga Mtn Man on Sawmills and Milling
Last post February 26, 2012, 04:03:48 PM
by Magicman
Magicman's Get Together
Started by Magicman on Shows, Events and Places to meet
Last post April 04, 2010, 10:29:40 PM
by Magicman
