Author Topic: chainsaw modifacations  (Read 5880 times)
sawcrazy
  • Guest
« on: January 20, 2002, 11:44:35 AM »
i have a 066 that i ues to mill lumber . I'm wondering what I can do myself to get more power from it. I don't care much about loss of chaisaw life, just more power without geting new bigger saw yet.I have been milling mostly big maple and would like to go abit faster. Thanks for any input
Offline Kevin
Re: chainsaw modifacations
« Reply #1 on: January 20, 2002, 01:05:44 PM »
Welcome to the buyers club, what bar and chain combination are you using?
sawcrazy
  • Guest
« Reply #2 on: January 20, 2002, 01:44:02 PM »
I run a 36" bar and ripping chain to break down the big stuff then I switch to my 20" setup.It works pretty good, I just would like to go a little faster.
Offline Kevin
« Reply #3 on: January 20, 2002, 02:01:31 PM »
Which ripping chain?
sawcrazy
  • Guest
« Reply #4 on: January 20, 2002, 02:11:20 PM »
stihl chain cut to granberg specs.
Offline Kevin
« Reply #5 on: January 20, 2002, 02:15:44 PM »
Who modified the chain and how?
Does it now have both scoring and clearing cutters?
sawcrazy
  • Guest
« Reply #6 on: January 20, 2002, 02:18:29 PM »
My wing-nut dealer sold me some chain and cut it too Granberg specs and said this is the best chain for ripping.  I haven't tried anything else, but am open to suggestion.
sawcrazy
  • Guest
« Reply #7 on: January 20, 2002, 02:24:25 PM »
Why do most Stihl dealers try to sell you only this brand?  I know their are usually better aftermarket products available.
I'm not ranking on stihl there my bran of choice and always will be.
Offline Kevin
« Reply #8 on: January 20, 2002, 02:29:42 PM »
RSF is good full skip ripping chain other than the fact the top plate is ground to 30o.
If your dealer reground it chances are extremely good that he has taken the hardness out of the cutters.
This chain cuts well as is but the finish on the wood is a little on the coarse side.
Offline Kevin
« Reply #9 on: January 20, 2002, 02:40:39 PM »
Which mill are you using?
sawcrazy
  • Guest
« Reply #10 on: January 20, 2002, 02:44:18 PM »
the chain they made does not  cut any better than my other stihl chain.I sharpen my own chain and do a pretty good job at it .
sawcrazy
  • Guest
« Reply #11 on: January 20, 2002, 02:45:45 PM »
alaskan mk lll
sawcrazy
  • Guest
« Reply #12 on: January 20, 2002, 02:49:29 PM »
What do you think about the 088? Humm been lookin at that saw abit.Wore out the catalog.
Offline Kevin
« Reply #13 on: January 20, 2002, 02:53:42 PM »
It helps to have one end a little higher off the ground with the Alaskan.
Start on the high end and work your way down the log , gravity alone will speed things up.
Crank your oil supply on the saw wide open, I use one tank of gas to one tank of oil.
Only mill a square cant, if you continually mill a log with bark on it your chain will suffer.
I use the Alaskan and take the top off the log, switch to the mini mill and take both sides then back to the Alaskan and I`m milling a nice clean cant.
Check your raker height and let me know what they`re set at.
Offline Kevin
« Reply #14 on: January 20, 2002, 04:56:26 PM »
I think the 066 beats the 088 hands down for milling.
It seems anyone that has an 088 needs to modify it for milling.
Offline J Beyer
  • If there were no trees, we would not be board.
« Reply #15 on: July 06, 2002, 04:10:38 PM »
What pitch chain are you using?  .325 chain works the BEST for the 066 milling setup, even the 088 prefers .325 chain.  Write me and I'll get you in contact with a guy that is extremely knowledgeable on milling chain.
JB
"From my cold, dead, hands you dirty Liberals"
Offline rthomy
  • I'd rather be skiing powder
« Reply #16 on: July 15, 2002, 02:23:36 PM »
Have you thought of getting a tuned exhaust made up for the saw.  I've had it done with my 046 Magnum, its a bit noisier but definetely more powerful
Offline Timber_Tramp
« Reply #17 on: September 13, 2002, 11:21:18 PM »
 Hi there, the 066 can be easily modifide by opening up the restricted exaust port in the muffler and cutting out the bottom half of the perferated box inside the muffler, if you have one of the newer 066's. You can also order from Stihl the muffler face plate that has an additional port in it. These simple mods with give you an instant 25-30% gain in power, plus your saw will last longer and run cooler. Running 32:1 will give you extra lube and wont cause carbon if you run the saw at factory rpm. I have been using Maxima 927 lately as a mix.
  For a full rundown on modifided saws, talk to the Guru in Oroville Calif. Ken Dunn: kdhotsaw@hotmail.com
 John Lambert
Offline Gordon
  • smoke free growing trees  raising my 6 kids
    • JGforestry
« Reply #18 on: September 16, 2002, 06:23:52 PM »
What about an upgraded air filter? How much power to they add to a Stihl?
Gordon
Offline KiwiCharlie
  • Theres nuthin I like more than an UGLY log.......
« Reply #19 on: September 16, 2002, 11:19:46 PM »
G'day Gordon,
Such as a K&N filter??  Ive heard that they do allow the saw to breath easier, but they also allow crud into the engine.  Not good for a saw!! :D
The muffler mods arent too hard to do and from all accounts, work well.  Hope to do my 038 soon.  Now, where did I leave my muffs! :o :o  DanG!! ;)
Cheers
Charlie.
Walk tall and carry a big Stihl.
Offline KiwiCharlie
« Reply #20 on: September 22, 2002, 11:41:16 PM »
OK,
Just found the perfect smiley......  !!!
Cheers
Charlie.
question
Chainsaw Mortising What is the best chainsaw / bar and chain to use
Started by Billyboy on Timber Framing/Log construction
Last post September 14, 2013, 04:17:37 AM
by Satamax
chainsaw bar,,,
Started by jmouton on Wanted
Last post February 09, 2015, 10:05:01 PM
by sawguy21
Chainsaw gtg
Started by Cut4fun on Chainsaws
Last post May 09, 2008, 10:13:43 AM
by jokers
New Chainsaw
Started by Qweaver on Chainsaws
Last post October 07, 2013, 01:26:19 PM
by SawTroll
