Dynamic Green Products Inc.
Author Topic: swing slow on Valmet 646 in one direction(left)  (Read 1390 times)
Offline leeroyjd
« on: March 12, 2013, 04:50:18 PM »
I've changed primary shuttle valve but that was not it.Switched top and bottom lines on section and that just made the right side slow.Not sure what I was hoping to accomplish there.
It responds right away when joystick moved to the right,but hesitates for a second when moved to the left.
Offline snowstorm
Re: swing slow on Valmet 646 in one direction(left)
« Reply #1 on: March 12, 2013, 05:33:44 PM »
pack the steering cyls
Offline snowstorm
« Reply #2 on: March 12, 2013, 05:40:14 PM »
only half read it. you mean the crane? there are 4 swing cyl if the packing was leaking in just one of them it could cause it. did you replace the shuttle vavle with a new one? i never had much luck with just replacing the o rings and back up washers
Offline 1270d
« Reply #3 on: March 12, 2013, 06:05:44 PM »
Does this have pilot hyd controls or electric controls?
Offline leeroyjd
« Reply #4 on: March 12, 2013, 06:38:50 PM »
Snowstorm-yes new shuttle but they do not come w o rings on them,they are separate which I don t care for.If one of the slew cylinders was leaking would I end up w hyd oil in slew bath?
1270D- these are pilot controlled
Offline snowstorm
« Reply #5 on: March 12, 2013, 07:46:57 PM »
it could leak internal. past the packing on the gland but not past the rod packing. i havnt bought any shuttle valves in a while. they were around $65 and just the o rings were 20 or so. they also wear in the wobble joint. i have tried setting the new o ring in the sun getting it warm to get it on then putting it on ice hopping it would contract enough to go back in the hole. still didnt work well. these arent your common o rings. i would pull that shuttle out an look it over. the 2 orings are not the same part # so they have to be in the right spot. did it slid in easy or did you have to push it in?
Offline bushmechanic
  • Someone else has it worse than you.
« Reply #6 on: March 12, 2013, 08:43:47 PM »
Sounds like a pilot system or valve problem but don't rule out a collapsed line or a rubber hydraulic hose that the rubber is letting go on the inside.
Offline miketclew
« Reply #7 on: March 15, 2013, 02:28:17 PM »
If you haven't at least replaced the o-rings on the secondary shuttle, I would do that before I did anything else. Watch out for the little ball bearing. I have an old 546 and solved about 6 major problems by re o-ring/washer-ing these primary and secondary shuttles. Some of the o-ring kits I got were so tight I was concerned about cutting the rings when I re-installed the shuttles. There is a chance you damaged an o-ring during re-installation too. Good luck.
Offline snowstorm
« Reply #8 on: March 15, 2013, 08:38:04 PM »
miketclew what part of the state are you in?
Offline leeroyjd
« Reply #9 on: March 16, 2013, 05:48:52 AM »
I do have a new secondary around here but I thought that if the secondary's were bad both sides of a function would be effected?
Primary made no difference.
Left joystick gets warmer than right,emits noises and vibrations.
Some have asked if I could have air in system,is this possible? It's got a breather or is that just for the tank?
Offline snowstorm
« Reply #10 on: March 16, 2013, 07:52:36 AM »
they are tank vents. on my harvester the right joystick gets warmer than the left. on my 646 the joysticks only get hot on a hot summer day
Offline 1270d
« Reply #11 on: March 16, 2013, 09:14:44 AM »
Is it possible that a piece of debris got into the valve section and is impeding the main spool?
Offline snowstorm
« Reply #12 on: March 16, 2013, 10:18:34 AM »
i have seen something get in the cirert relief  when that happens it may not lift like it should or the cyl leak down
Valmet 546 havester slow feed wheels
Started by Angrybeaver94 on Forestry and Logging
Last post September 25, 2019, 07:04:13 AM
by Angrybeaver94
swing to the left, swing to the right...
Started by HORSELOGGER on Sawmills and Milling
Last post March 30, 2004, 02:25:36 PM
by Captain
Left Hand Remington, Left Hand HS Precision / McMillan Stock
Started by Warren on Wanted
Last post February 26, 2011, 09:11:48 PM
by Warren
looking for a valmet 644??
Started by VLACOSSE on Forestry and Logging
Last post January 27, 2014, 08:33:22 AM
by VLACOSSE
