Dynamic Green Products Inc.
Author Topic: Has anyone else had problems with the 16hp briggs and stratton?  (Read 4150 times)
Offline JSwigga
We got a Lucas dedicated slabber about 3 months ago.  It has the Briggs and Stratton Vanguard 16 hp.  We have about 42 hours on it and it's been back for warranty work twice already.  First time the oil sump gasket was leaking.  Today the whole motor just locked up.   We had the maintenance done on it and everything.   Anyone else experiencing problems like this or did I just a get a lemon motor?
60" Lucas Dedicated Slabber, TimberKing 2200 , 5 ton Nissan forklift, John Deere FEL
Offline JSwigga
Re: Has anyone else had problems with the 16hp briggs and stratton?
« Reply #1 on: March 19, 2013, 09:07:48 AM »
Matthew or Wayne.  Can you check your support emails.  I want to try to resolve this lemon motor issue.
Offline beenthere
« Reply #2 on: March 19, 2013, 10:57:31 AM »
Who are Mathew or Wayne?
Offline JSwigga
« Reply #3 on: March 19, 2013, 03:20:13 PM »
Lucas Mill Reps that responded to this post.  Haven't been able to get ahold them since last week.
Offline JSwigga
« Reply #4 on: March 19, 2013, 05:34:57 PM »
They got ahold of us!  Many thanks!
Offline sawguy21
« Reply #5 on: March 19, 2013, 10:16:27 PM »
First you need to determine what locked up and why. Is it a hydraulic lock from fuel pouring into the cylinders or something more serious?
We have seen problems with oil leaks at the crankcase cover, usually due the weight of a hydraulic pump distorting it. The usual fix is a second gasket and retorquing the bolts.
Offline JSwigga
« Reply #6 on: March 30, 2013, 10:43:15 PM »
UPDATE:   all problems have been resolved.  Lucas Mill reps were very helpful.  I even got a free tee shirt out of the deal. 8)
Offline logboy
« Reply #7 on: August 22, 2013, 11:15:16 AM »
I'm curious what the issue was on your engine. I just replaced the CARB compliant (California Air Resources Board) carburetor on mine since it never idled right. It was always starved for fuel and constantly died.  If it was cold then it was a bear to start. I lost an hour on a job one day trying to get it started.  No fault of Lucas, its the new regs we unfortunately have.
I like Lucas Mills and big wood.  www.logboy.com
Briggs & Stratton
Started by JBS 181 on Sawmills and Milling
Last post December 18, 2010, 07:42:19 PM
by Slabs
Briggs and Stratton won't run
Started by Tom on General Board
Last post November 26, 2007, 07:17:04 PM
by Polly
Help with 8 h.p. Briggs & stratton ?
Started by bama20a on General Board
Last post April 27, 2011, 01:05:37 PM
by red oaks lumber
35 HP Briggs & Stratton Vanguard
Started by woodbowl on Sawmills and Milling
Last post June 21, 2006, 01:24:35 PM
by tcsmpsi
