Author Topic: Thanks to Furby  (Read 2181 times)
Offline Jeff
  • Fearless Leader
  • Oh la di oh la da
    • Behind the  Forestry Forum YouTube channel
Thanks to Furby
« on: March 21, 2013, 09:58:16 PM »
About 4 years ago (I think, but I'm sure Furby will refresh my memory) Furby gave me some slabs of different stuff he had dried to use for wood burning projects or what ever. Yesterday, I was looking at one, which I'm pretty sure is cherry, and though, "Hey, that might make a shelf to go under that there picture"  So I thought about it a little bit, then pulled my boots on and grabbed a shovel and wandered out to my stash of cedar buried under a bunch of snow and dug a chunk out. I brought it in and put it in front of the fireplace over night to melt off the remaining bits of snow and dry it off.  Today I cut 2-6" chunks out of it and then put those in the microwave for 3 minutes on, 5 minutes off, for a series of 10 times. Each time with fresh paper towel under them By the 10th time, I was no longer getting moisture on the paper towel, and the wood seemed perfectly dry and quite a bit lighter. It also had been piled out on my little woodlot for at least 3 or 4 years.
Anyhow, with the slab Furby gave me, and two chunks of cedar, I made the shelf below.  I think it came out good.  :)
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
Re: Thanks to Furby
« Reply #1 on: March 21, 2013, 10:04:10 PM »
I like it!
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: Thanks to Furby
« Reply #2 on: March 21, 2013, 10:04:33 PM »
Perfect!  That turned out very good.  It is amazing how creative that you are  ;D.
Woodmizer LT40HDD35, John Deere 2155, Kubota M5-111, Nyle L53 Dehumidification Kiln, and a passion for all things with leafs, twigs, and bark.  hamsleyhardwood.com
Offline Warbird
Re: Thanks to Furby
« Reply #3 on: March 21, 2013, 10:29:17 PM »
Nice work, Jeff!
Offline fuzzybear
Re: Thanks to Furby
« Reply #4 on: March 21, 2013, 10:30:14 PM »
very nice!!!
I never met a tree I didn't like!!
Offline pasbuild
Re: Thanks to Furby
« Reply #5 on: March 21, 2013, 10:33:14 PM »
Jeff how did you anchor the cedar?
If it can't be nailed or glued then screw it
Offline clww
  • Oh yeah? Watch this!
Re: Thanks to Furby
« Reply #6 on: March 21, 2013, 10:34:02 PM »
That looks great, Jeff. I can't believe you ran out of room on the mantel! :D :D :) :)
Many Stihl Saws-16"-60"
18-Wheeler Driver for J&R Schugel
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Thanks to Furby
« Reply #7 on: March 21, 2013, 10:43:40 PM »
Yes.  Very nice.   smiley_thumbsup
Offline Jeff
  • Fearless Leader
  • Oh la di oh la da
Re: Thanks to Furby
« Reply #8 on: March 21, 2013, 10:53:03 PM »
I should of took a photo of that. I'll see if I can describe it. I had a small "L" bracket here. I cut it at the bend two give me to small steel rectangles, each with a hole in it. I drilled the holes out just big enough that the screw head for the molies I had here would fit through it. I then used the dremel to grind a slot at one end of the hole only large enough for the screw shaft, but not big enough for the head. This way the head of the screw passes through the hole, and when you slide the bracket down, it traps the head.  I marked out on the back of the cedar where I wanted the brackets, then used the dremel again to plow out a place for it. I then drilled out one end, so once the bracket was attached to the cedar, there would be a hollow for the screw head to fit into, and slide to lock the bracket on the screw.   I then used gorilla glue to glue the bracket into the cedar. Probably a better way would have been to have two holes, and screw them on, but I just worked with what I had.
So, all you have to do is put a molly in the drywall, put the screw in, and leave the head out just enough, that you can slip the head through the bracket as you push the cedar against the wall, then slide down the cedar to latch the bracket to the screw. Wah-lah. You have a small cedar log end hanging on the wall.  :)
This probably did not make any sense at all. :D
Offline clww
Re: Thanks to Furby
« Reply #9 on: March 21, 2013, 10:56:05 PM »
Made perfect sense to me.
Offline Okrafarmer
  • Location: upcountry SC-- Sweetgum capital of the world!
  • Back again....making multi-colored sawdust
Re: Thanks to Furby
« Reply #10 on: March 21, 2013, 11:41:29 PM »
Nicely done, Jeff. You didn't make it overly large, so it looks elegant in that setting.
Operating a 2020 Woodmizer LT35 hydraulic for Wagner Farms, Dacusville, SC
Looking for the return of the Lord!
Offline isawlogs
  • A smile is contagious ... Start an epidemic
Re: Thanks to Furby
« Reply #11 on: March 22, 2013, 07:40:20 AM »
  Sure it did, you made a keyway hole in a bracket and fitted it to your shelf and Wah-lah ( Voila....  correct spelling ) ;D
  It looks great Jeff, nice to have stock laying around for just those brilliant ideas we have from time to time .  smiley_lit_bulb smiley_smug01
   Marcel
Offline Norm
Re: Thanks to Furby
« Reply #12 on: March 22, 2013, 07:51:24 AM »
Nice work Jeff, something like that is always special when it's from a good friend like Jason.
Offline terrifictimbersllc
    • Terrific Timbers LLC
Re: Thanks to Furby
« Reply #13 on: March 22, 2013, 08:04:00 AM »
Looks great. Nice to take time to do something with your own wood rather than someone else's.
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
Re: Thanks to Furby
« Reply #14 on: March 22, 2013, 09:34:23 AM »
Like we say down here....."now that's country!" Very NICE.  smiley_thumbsup
Offline thecfarm
Re: Thanks to Furby
« Reply #15 on: March 22, 2013, 09:41:18 AM »
I think it came out nice too.
Offline WmFritz
Re: Thanks to Furby
« Reply #16 on: March 22, 2013, 10:18:24 AM »
I like that, too... alot. My wife has ideas for shelves like that but, I come up with some complicated mounting device in my head and give up on it. Thanks for the simple solution.
I also like the picture frames, the bench, the wood paneling... the whole wall looks great. smiley_thumbsup
~Bill
2012 Homebuilt Bandmill
1959 Detroit built Ferguson TO35
Offline ely
Re: Thanks to Furby
« Reply #17 on: March 22, 2013, 11:49:13 AM »
i also like the decor in your home.
Offline Jeff
  • Fearless Leader
  • Oh la di oh la da
Re: Thanks to Furby
« Reply #18 on: March 22, 2013, 01:03:20 PM »
We've been doing some little interior projects this winter, Actually, mostly in the last month or so. Being almost 50 lbs lighter is giving me pent up energy I have to get rid of some how. :D  We've even built a new wall in the house between our kitchen area and our office area. I'll have to post some photos soon of some of that.  The Mini Museum topic that Loggah posted a while back inspired me to go to the storage unit and bring home a bunch of stuff we moved out when we were trying to sell the house and move to the U.P.  We now have decided to stay right where we are. Before the stuff was just sitting around from room to room, sometimes in piles. We're trying to find pleasing ways to present things this time. We had a lot of stuff filed or tucked in closets that we have been framing as well.  An example would be the 1943 our America Lumber Industry print issued by Coca-Cola print above the new shelf.
Offline clww
Re: Thanks to Furby
« Reply #19 on: March 22, 2013, 01:16:50 PM »
Where did you find that print?
wink
Furby! You better run...and let us know if we can do anything to help!
Started by Paschale on General Board
Last post June 11, 2007, 04:42:25 PM
by SwampDonkey
Started by DR_Buck on General Board
Last post December 03, 2007, 04:55:20 PM
by Furby
Thanks Furby
Started by slidecreekdan on General Board
Last post December 26, 2007, 11:21:50 PM
by Mooseherder
wink
HBD Furby
Started by DanG on General Board
Last post October 13, 2004, 06:23:04 AM
by Frank_Pender
