I found a bolt on pintle ring for LT40 WM
Started by yellowrosefarm, March 23, 2013, 05:24:00 PM
yellowrosefarm
I got real tired real quick of hooking an unhooking a 2" ball coupler on my LT40. I saw this bolt on pintle from Croft trailer supply that looked like it would fit and it does. What an improvement! 8)
Chuck White
Looks like it would simplify hook-ups quite a bit!  smiley_thumbsup
SAWMILL BUDDY
First thing I did to my mill was change to pintle hitch.
Dave Shepard
Looks good to me! I don't really like ball hitches too much.
drobertson
Looks like a good thing to me,  I got use to the hitch, just a pain at times,
Dan_Shade
I made a receiver tube one for mine.  I use a removable ring.  I need to snap a picture.
I much prefer a ring and pintle hook to a ball.
lots of dull bands and chains
Ga Mtn Man
I've never used a pintle hook.  What are the advantages over a ball coupler?
Dan_Shade
it's easier to hook up, and I believe that the attachment is more secure (not as likely to jump off the hitch).
Dave Shepard
A pintle is also very easy to visually verify the connection. I've hooked on to ball couplers before and thought they were down all the way, only to see that the little finger was resting on top of the ball, not under. ::) I always either stick my finger under there, or get a visual of that little finger. I had a better ball coupler from Hammerblow that had a hinged coupler with a sliding collar that work well. Also, pintles give you a little more leeway in tower to towee alignment.  :D
drobertson
the main advantage is no more banging and bending the receiver,
Dan_Shade
mine also makes a dandy seat while turning logs.
yellowrosefarm
Much easier to hook up, no way to jump off and more flexibility on uneven surfaces. I move my lt40 around the farm with my tractor and crossing ditches or washouts in the road would bind the ball coupler against the side, tweaking it in the process and making it that much harder to get hooked up the next time. With the pintle ring, the trailer can be almost at a 90 with the tow vehicle with no binding of the hitch.  Nothing more frustrating than getting to where you want to saw only to have to jump, beat and cuss the coupler to let go.
drobertson
ten four on the banging and jumping!  nothing more frustrating than a stuck hitch,  good idea, sounds like your problems with this is bout over,
Larry
Things I have learned about trailers.
A 2" hitch will not fit on a 2 5/16" ball.
A 2 5/16 hitch will fit on a 2" ball and appear to lock. :o
Stout safety chains are good. :)
At 64, a backup camera that can see the hitch is not a luxury. ;D
That bolt on pintle ring appears to be a Croft exclusive.  At least I can not find anything like it anywhere else.  I was hoping that Tractor Supply would have it.
hamish
Quote from: Dan_Shade on March 23, 2013, 07:46:55 PM
That is the most secure set up.  Prevents alot of thefts, but those that cant figure out whats missing.  Additionally the pintle or lunette eye is usually rotateable 360 degrees independantly, meaning you can roll your truck and the mill wont roll (had to lose the truck in this example).
Norwood ML26, Jonsered 2152, Husqvarna 353, 346,555,372,576
yellowrosefarm
Quote from: Magicman on March 24, 2013, 04:54:52 PM
Yes, As far as I know it is exclusive to Croft. I looked and looked for a small bolt on pintle ring before I found this one. They're an easy company to deal with, though, I had it 2 days after I ordered it.
GDinMaine
Thanks for the explanation on why the pintle hitches are better then the ball mount.  I understand the reasons you guys gave, but that brings up one question.  If the the pintle is so much better, why aren't more trailers come with that setup?   It appears that only very large capacity commercial trailers use it and I have never seen it on anything in the 4-5 ton capacity.
It can't be difficulty of hookup because you said it is in fact no the case.
Is it the price?
ps: yes I'm considering it as well just to avoid a possible jammed hitch.
It's the going that counts not the distance!
WM LT-40HD-D42
Dan_Shade
GDinMaine
Dan,  Did you adapt one of these for your mill?  I assume you welded or bolted a receiver tube on the mill and have something like this for it?
Pictures - as you said - would be welcomed.
WM LT-40HD-D42
isawlogs
 I have hydraulic brakes on my mill, activated by the ball hook-up, so I would not be able to put a pintle hook on. I tried to go that way when I bought my mill but it was not an option, now with electric brakes it would be an easy it. I might just pull the axle off my mill and go with electric brakes on it and get a ring hook-up for it. I need to go over the brake lines and brake linings and probably drums too... might be cheaper in the long run to just go electric.
   Marcel
YellowHammer
Pintles hitches although very secure allow relative movement between the tow vehicle and the trailer.  They do the "bang and clang" as the tow vehicle accelerates and decelerates, or the trailer tongue bounces.  Somewhat annoying at stoplights, stop and go traffic, bumpy roads, etc.  Ball hitches fit securely, have very little slack and don't thump and bump.  Pintles are great for heavy equipment, farm implements, and large tow vehicles that are not affected by the backlash, not so much for smaller tow vehicles that react to the slack in the hitch.
Just my experiences with them, your mileage may vary
YH
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
rmack
Quote from: YellowHammer on March 24, 2013, 11:52:52 PM
YH
X2, only I wish mine would have come with a 2 5/16 like everything else I own.  ::)
the foundation for a successful life is being able to recognize what to least expect the most... (anonymous)
Welder Bob
2012 LT40HDSD35 Yanmar Diesel Triple
1972 Patrick AR-5
Massey Ferguson GC2410TLB Diesel Triple
Belsaw Boat Anchor
jcbrotz
Quote from: rmack on March 25, 2013, 12:33:51 AM
YH
When I bent mine I replace it with a 2 5/16 hammer lock, Never cared much for a pintle I always liked the goose but I cant finger out a way to put one on the mill. :o :D ::)
2004 woodmizer lt40hd 33hp kubota, Cat 262B skidsteer and way to many tractors to list. www.Brotzmanswoodworks.com and www.Brotzmanscenturyfarm.com
