We have contest winners!
I'm looking to cut my own wood this spring for next winter and
Welcome to the ForumYour profile does not list where you live. If you are in a hot area like mine, where summer temps are generally over 100 and humidity is less than 15%, then if you get the wood split down to a manageable size, it should season enough over the summer to give reasonable heat next winter. If you are in a cooler location or with a lot higher humidity, then your ability to dry the wood before next winter could certainly be in jeopardy. It will cost more and be more labor intensive, but one of the things you can do to accelerate the drying process is to use a "green house" type wood shed that doubles as a solar kiln. That will increase the heat, and you will likely have to have a fan running to remove the resulting moist air out of the kiln/shed. Splitting the pieces smaller also helps accelerate the drying process as it creates more surface area that will dry quicker.As to saws, I am also a confirmed Stihl fan. My first saw was a Stihl 024 with an 18" bar when I was 12 yrs old, (and probably about your size). It still runs and is now a backup saw. I cut hundreds of cords of oak with it over the years. Pound for pound, that was the best saw I have ever used. If you can find a good running, refurbished 024, I don't think you could go wrong.One of the things you really need to think about is the size of the trees you are going to be cutting. If they are 24" or smaller on average, then a 16 to 18" bar should be your best fit. If they are bigger, then you really probably want at least a 20" bar. Depending on your height, you may find one length does better for you, especially when cutting limbs sitting on the ground. Too short a bar, and you will be left having to lean over or squatting which will put more stress on your back and legs and tire you quicker. A longer bar than you need, is more weight you don't really need, and again, will tire you quicker. I find a 20" bar is perfect for me for most oak trees in my area, but you need to try some different length bars at your Stihl dealer to see what works best for you. Unlike probably many or most on this forum, I would not recommend spending the extra money on a "professional" Stihl chainsaw. You are going to be cutting a lot of wood, but nothing compared to a professional that is using their saw everyday. I would recommend one of the mid-grade, (ranch saws), that Stihl markets. Either the MS-271 or MS-290 would be my recommendation as a starting point. The MS-271 is almost a pound lighter, (8% difference) than the MS-291, which may make a big difference to your comfort level using it. The MS-290 has more power and higher torque, and is my personal preference, but again, you should try them both and see which feels better to you.Just a note about the length/size of firewood you will be cutting. While your stove may be able to handle a 10" width and 24" length, you have to figure out whether you can handle carrying, stacking and loading that length and weight of wood. You can also run into difficulties getting multiple long pieces in the stove at the same time. So I generally have found that cutting 16-18" lengths seems to be the sweet spot for most people. You will always end up with some shorter and longer pieces, but again, on average I would predict you will find 16-18" will best fit your needs. If you are using a hydraulic splitter, making the pieces 7-8" thick on average is also probably your best bet. Easier to load in the stove, and optimal for drying/seasoning.Hope that helps. Let us know when you make your final decision and what you chose.Dave
Started by H60 Hawk Pilot on Forestry and Logging
Started by Part_Timer on Sawmills and Milling
Started by Dieseln2stroke on Chainsaws
Started by Northwoods85 on Forestry and Logging
