Author Topic: Cut Throat Depth  (Read 2435 times)
Offline JimFX
  • This is a great forum....
Cut Throat Depth
« on: April 09, 2013, 11:31:48 PM »
How important is a really deep cut throat depth? For instance the Timber King seems massive when compared to the Norwood however, If my car had a top speed of 180 MPH that would give me bragging rights but how often would I actually use that ......?
Jim
Offline pineywoods
Re: Cut Throat Depth
« Reply #1 on: April 09, 2013, 11:43:26 PM »
Depends on your sawing technique..If you saw a board off the top of a cant and then off-bear it, throat depth is not a factor. However if you do like me, (I'm a bit lazy) I square up a cant and then saw through and through, leaving the boards on top of the cant, then use a fork lift to pick up the entire stack for removal. On a mizer lt40, I can saw 14 4/4 boards before hitting the throat depth limitation. I have to keep that limitation in mind when sawing larger logs.
Offline Ianab
« Reply #2 on: April 09, 2013, 11:46:25 PM »
Where it can count is quarter sawing, where you may start by splitting the whole log in 1/2, then into 1/4s. So if you only have a 10" depth of cut, and want to split a 24" log in 1/2.. you are kind of stuck.
Obviously there is a point where a greater depth of cut is not much benefit. Having a 30" depth of cut on a mill that only handles a 28" log is a bit pointless  :D
Offline JimFX
« Reply #3 on: April 09, 2013, 11:59:08 PM »
Quarter sawing ... yes of course.
and forgive the questions ... a "cant" is a log and "off bear it" is to remove it from the log after cutting?
Offline JustinW_NZ
  • Just Hacking and stacking.
    • Logs2Lumber
« Reply #4 on: April 10, 2013, 01:19:45 AM »
I'm sure there is an official description here somewhere, but in simple terms a cant is what you would call a log that has been squared up and ready to saw into boards.
i.e. its no longer a log its had some knawing on it  :D
Off bear is to take the boards cut from the cant and stack them aside..
and +1 for big throat depth while quarter sawing...
Cheers
Justin
Gear I run;
Woodmizer LT40 Super, Treefarmer C4D, CAT 528 swinging grapple, 10ton wheel loader.
Offline dboyt
  • Log On!
« Reply #5 on: April 10, 2013, 05:31:22 AM »
Good questions.  On a manual mill, there is just too much cranking to raise the head over more than three or four 1" boards.  An 8" throat will still let you quarter saw 18' diameter logs.  I have had to square off some cants to quarter saw them, but that still gives some good-sized boards.  Throat depth is one of many things to consider when looking at sawmills.  A rigid frame, solid carriage, user-friendly controls, and a good clamping system are more important to me.  Lots of terms to learn, and toys tools to think about.  FF is a great place to learn and get opinions!
Offline thecfarm
« Reply #6 on: April 10, 2013, 06:30:26 AM »
JimFX,we do have dictionary. Go to the Menu Bar,hover your mouse over Extras,click on to Forestry Forum Dictionary and you should be all set,
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #7 on: April 10, 2013, 07:26:54 AM »
I removed the board drag back option from my sawmill years ago to increase the throat depth.
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #8 on: April 10, 2013, 09:23:37 AM »
Me too, Lynn!
Mine took up about 3 inches of throat depth!
~Chuck~
1995 Wood-Mizer LT40HDG25 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline JimFX
« Reply #9 on: April 10, 2013, 09:27:15 AM »
A dictionary ... sweet. That helps us new people for sure, Thanks.
I thought Dave's point about doing a lot of cranking on a manual mill was good.
Something you don't necessarily think about until you have to do it.
Good feedback from all.
Thanks!
Offline KnotBB
  • Good gun control is being able to hit what you aim at!
« Reply #10 on: April 10, 2013, 10:19:24 AM »
Definition of cant should also include large sawn pieces of a log that are intended to be resawn.  As an example, larger logs might yield three or four cants.  Just need two flat and squared sides.
To forget one's purpose is the commonest form of stupidity.
Offline ladylake
« Reply #11 on: April 10, 2013, 07:05:34 PM »
 On a 4 post mill that has 16" above the blade you can turn a odd shaped log up and get some oversized ones though fairy easy. On a WM you can leave it hang out the side but it still has to be turned up on the next cut. Either way a large throat helps. My B20 only has 12" and I wish it had more sometimes.  steve
Timberking B20 14000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Suffolk  setter Volvo MCT125c skid loader
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #12 on: April 10, 2013, 09:38:13 PM »
Steve's description is spot on.  This is why we have to gun barrel, octagon or Bibby oversize logs.
Steve, what current TK does the B20 equate to?
Offline Tom the Sawyer
  • Converting your logs to lumber at my home or yours
    • Tom the Sawyer Portable Sawmill Service
« Reply #13 on: April 11, 2013, 01:52:59 AM »
The replacement for the B-20 is the Timberking 2000.  4 more horsepower, but the big deal is the 32" wide throat (8" wider), the head up/down is now hydraulic and extremely fast compared to the old 12v motor on the B-20.
07 Timberking B-20, Custom-made log arch, 20' trailer w/ log loading arch, F350 SD flatbed dump.  Princeton piggy-back forklift.  Bobcat S250, Stihl 025C 16" and a Husqvarna 372XP 24/30" bars, Grizzly 20" planer, Nyle L200M DH kiln.
If you call and my wife says "He's sawin logs", I ain't snorin'.
Offline ladylake
« Reply #14 on: April 11, 2013, 05:04:03 AM »
 Tom  My B20 came with a 27 hp Kohler, the early TK 2000 came with a 34 hp and might have a 38 hp now.  My brothers 34 hp has way more power than my 27 hp ever had which was underpowered in wide cuts in hard wood. While my B20 cuts lumber fast TK did a real good job with the 2000 with the larger capacity, bigger chain turner, better log loaders and really fast up-down. Steve
Offline Banjo picker
  • A goal without a plan is just a dream. Elbert H.
« Reply #15 on: April 11, 2013, 06:36:56 AM »
Jim good analogy on the 180 mph...its all about what you intend to do with it...and what you want....example being MM and Chuck have taken off their board drag back, there is no way I would run mine with out it...diff. manufacture and made different....
Since you are considering all these options...you need to open a topic on debarkers.  ;)  They are mights nice....Banjo
Cooks AC 36--Prentice 210C--Morgan edger--Kubota M7040 with loader--Case 580 K with extendahoe--Case 850C dozer--Int 1700 series twin cylinder dump/log/flatbed truck--logging arch--2 Logrite mill sp.--Cat claw sharpening system--And a bulldog to make sure it all stays here.
Offline Ga Mtn Man
  • Y'all can call me GMM
« Reply #16 on: April 11, 2013, 07:30:39 AM »
The cut throat on the 2000 is 33".  The throat depth (height above blade) is 16" which, surprisingly,  is the same for even their smallest mill.
2012 LT40HDG29 with "Superized" hydraulics,  2 Logrite cant hooks, home-built log arch.
« Reply #17 on: April 11, 2013, 02:00:43 PM »
Steve,  my B-20 was made in late 2007, it has the 30 hp engine.  It does fine with 20-24" wide cuts.  I could certainly see how the additional hp would help with slabs 33% wider than that.  Even so, I probably wouldn't mind slowing down a bit if I could mill boards that wide.
GaMtnMan,  it is not surprising that the throat actually measures 33".  I think they understate their capacity as they only 'claim' 32" for the TK 2000.  That is a much better approach than buying something that doesn't measure up to the claims.  smiley_thumbsup
I was very fortunate that, although I got my mill after I built my barn, I was able to fit my B-20 under the 'lean-to' portion of my barn.  Bad news is that the TK 2000 is taller and wider and I would have to build a new saw shed if I upgraded.  Good news is that the paint on the TK 2000 is apparently drool-proof. ;D
Offline Chuck White
« Reply #18 on: April 11, 2013, 08:25:03 PM »
I removed my dragback not so much for cutting depth, but it blocked a lot of visibility down through the throat!  ;)
~Chuck~
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #19 on: April 11, 2013, 09:45:18 PM »
I redid mine only down an inch now,I got it up tight :D
A&P saw Mill LLC.
License NH softwood grader.
Edger throat bar
Started by moodnacreek on Sawmills and Milling
Last post September 21, 2017, 12:06:46 AM
by JB Griffin
Just might put a lump in your throat.
Started by Kevin_H. on General Board
Last post January 22, 2005, 05:28:17 AM
by SwampDonkey
Cleaning the throat area of the sawmill
Started by Chuck White on Sawmills and Milling
Last post November 08, 2011, 07:45:27 AM
by zopi
Cooks HD3238 Throat size?
Started by JSwigga on Sawmills and Milling
Last post February 11, 2013, 08:43:51 AM
by CooksSaw
