Author Topic: Cut Throat Depth  (Read 2434 times)
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Cut Throat Depth
« Reply #20 on: April 12, 2013, 08:34:30 AM »
When I am sawing, I prefer all of the workers to be in front of me handling slabs and lumber.  That way, I can stop operations instantly if I see something unsafe, etc.  I never used the board drag back anyway.
I still have the roller tables, etc. that came with my sawmill that I could use if I was set up permanent but since I only saw portable, they are still in the barn where I unloaded them.
Offline Banjo picker
  • A goal without a plan is just a dream. Elbert H.
« Reply #21 on: April 12, 2013, 11:55:07 PM »
I wasn't gona commit any more on this, but I think I will...I am set up stationary...on a con. slab.  I have roller tables behind the mill...first stop...slabs...second and third ...product....I use the drag back for every thing...It slowes me down when people are out in front trying to get a slab or a piece of lumber....I have to stop to keep from putting them in danger....
My mill is equiped with a 15' control box that handles most operations of the cut ...so I can stand any where I want to see whats going on....Like I said before dif. machines set up different ways....to each his own...Banjo
Cooks AC 36--Prentice 210C--Morgan edger--Kubota M7040 with loader--Case 580 K with extendahoe--Case 850C dozer--Int 1700 series twin cylinder dump/log/flatbed truck--logging arch--2 Logrite mill sp.--Cat claw sharpening system--And a bulldog to make sure it all stays here.
Just might put a lump in your throat.
Started by Kevin_H. on General Board
Last post January 22, 2005, 05:28:17 AM
by SwampDonkey
Edger throat bar
Started by moodnacreek on Sawmills and Milling
Last post September 21, 2017, 12:06:46 AM
by JB Griffin
Portable Bandmill Throat capacity
Started by dad2nine on Sawmills and Milling
Last post August 14, 2007, 09:41:21 PM
by fencerowphil (Phil L.)
Cleaning the throat area of the sawmill
Started by Chuck White on Sawmills and Milling
Last post November 08, 2011, 07:45:27 AM
by zopi
