Dynamic Green Products Inc.
Author Topic: Band Mill Cutting Width  (Read 1365 times)
Offline JimFX
  • This is a great forum....
« on: April 15, 2013, 10:57:11 PM »
I am a bit confused and wondering if someone here can explain the details.
Different mills may say cuts a 32" log but then go on to say the max board cut is less.
For instance, the Cooks MP 32 says it will cut a 32" log but then lists a 24" wide board cut.
To look at the mill in the flyer it looks wider than 24" at the mouth. So is it simply that the visual is deceiving
and the distance between the wheels plus the roller guides etc only leaves 24" for the wood?
The Timber King 1220 and the Cooks MP32 look so similar yet the TK has at least 4 inches over the cooks.
Am I understanding this correct?
Thanks!
Offline hackberry jake
Re: Band Mill Cutting Width
« Reply #1 on: April 15, 2013, 11:45:30 PM »
Sounds like you answered your own question. The guides take some space. My boardwalk jr claims a max of 24" but I have removed one guide before and gotten 26" boards.
Offline JimFX
« Reply #2 on: April 15, 2013, 11:49:23 PM »
Thanks Jake,
It just didn't seem right that there would be that much difference .....
Offline bandmiller2
« Reply #3 on: April 16, 2013, 06:46:49 AM »
Jim,if you take a 32" dia. log and take several slab cuts your soon down to 24".It takes a big log to give you 24" boards. Frank C.
Offline JimFX
« Reply #4 on: April 16, 2013, 09:07:13 AM »
Got ya, thanks. It would probably be a good idea to actually go see a mill first hand, ( I never had a mill) it could only improve my newbie questions .....
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #5 on: April 16, 2013, 09:10:20 AM »
What you would be doing is actually cutting the "round part" off the log, and boards with bark on them (flitches), and by the time you get it squared down, the log would be considerably smaller that the original log size.
~Chuck~
1995 Wood-Mizer LT40HDG25 Kohler - Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline Fla._Deadheader
  • Linda Vista, Costa Rica
« Reply #6 on: April 16, 2013, 02:08:02 PM »
Quote
 This is exactly why we build an oversized woodmizer copy. I felt they have the best design, AND, the open side allows slipping a wider log on the mill with no problem.
 We have sawn a full 37" wide X 3" thick table slabs, on a mill that was still road width legal.
 Anyone thinking about buying-building a mill, should first figure out if they will ever consider cutting wide boards, then, proceed to the quest for the best mill.
 Too many guys try to buy the least expensive mill, then try to mod the thing to death, which ALWAYS costs more than buying the mill that will suit them best.
 In our case, we are fabricators-welders- half a$$ed designers, so, we built as near as possible to woodmizers specs as possible, and did it for MUCH less than buying even a used woodmizer LT40 hydraulic mill.
Offline cutterboy
  • Sometimes trees fall where they want to.
« Reply #7 on: April 16, 2013, 04:56:33 PM »
Jim, If you put a 32" log on a mill and cut a 2" slab and two one inch flitches, you will have taken 4 inches off the top of the log. Now you flip the log over so that the flat side is down. Now you do the same to the top of the log, saw a 2" slab and two one inch flitches. You have now removed 4" from the top of the log. The distance from the bottom to the top is now 24". Turn the log 90 degrees so the round parts of the log are at the top and bottom and the flat parts are on the sides. Your log is now 24" wide and will fit between the roller guides and now you can saw 24" wide boards.
Cutter
Offline Ga Mtn Man
  • Y'all can call me GMM
« Reply #8 on: April 16, 2013, 06:50:22 PM »
Or you could take that same 32" log and throw it on my TK 2000 and slice it right down to the bed.  Not that you'd want to, but you could.  Just sayin' ;D
The max log size rating of a sawmill has as much to do with the max clearance between the saw head frame and the mill bed (throat depth) as it does with the max space between the guide rollers (throat width).
« Reply #9 on: April 16, 2013, 08:19:38 PM »
Good point. My mill will swallow a 30" round log, but I have 40" in height so if I have a log that is oval and 40" across the long way then I can still saw it. I have split a couple 40" logs in half then stood each half up on the mill and sawn it that way.
Offline Ga Mtn Man
« Reply #10 on: April 16, 2013, 08:23:26 PM »
I might be wrong on the definition of "throat depth".  Someone please correct me if I am.
Offline dgdrls
  • Learning the Art of Milling Logs
« Reply #11 on: April 16, 2013, 09:26:34 PM »
Like a very good surveyor told me once "your just fooling yourself with the numbers"
Capacity is certainly a consideration as are many other factors.
 As you noted, go and see them first hand,
I believe there are at least two builders who are also FF
supporters that would only be a day trip away from you?
best
DGDrls
Offline JimFX
« Reply #12 on: April 16, 2013, 09:49:40 PM »
Quote
This makes perfect sense and I totally agree with the least expensive mill comment. Human nature I suppose.
I am determined to get the mill that will be just what I need as opposed to the cheapest mill. You usually get what you pay for.
Offline JimFX
« Reply #13 on: April 16, 2013, 09:58:27 PM »
Cutterboy -  nice explanation thanks ...
Ga Mtn man - I got a good chuckle from your comment - you know, I'm just sayin : )
DGDrls - you nailed it, many things to consider, not just capacity ... so much for me to learn that yall already know.  Now that I have a tiny bit of knowledge I must go see ....
Thanks all
Width of your band wheel, width of your blade?
Started by valley ranch on Sawmills and Milling
Last post March 09, 2015, 12:41:02 AM
by valley ranch
Blade Band Width
Started by MartyParsons on Sawmills and Milling
Last post May 21, 2007, 07:54:28 PM
by theorm
Band saw wheel width
Started by black on Sawmills and Milling
Last post August 24, 2015, 08:30:53 PM
by bandmiller2
Band width question?
Started by kenfrommaine on Sawmills and Milling
Last post April 23, 2016, 05:32:48 PM
by Ox
