Dynamic Green Products Inc.
Author Topic: 7.3 Ford Powerstroke *sold*  (Read 5535 times)
Offline shinnlinger
« on: May 01, 2013, 10:37:41 PM »
Sale or trade  7.3 powerstroke turbo diesel engine w/only 136,782 original miles.
Time  for some spring cleaning and make the wife happy
Engine currently in 1999 Ford E-350 1 ton, extended wheelbase, van, automatic. Runs and drives but needs wiring harness work (only runs on 4 cylinders) and batteries. Used to be able to jiggle wiring harness and get to run on all 8 for a bit but no longer. There was a tech bulletin on this and it is a known problem/easy fix but its rusted pretty good (won't pass NH inspection) but could be put back on road with wiring harness and body work if you are determined  (have rear patch panels).
If you want to hear it run bring two good batteries (but I do have video of it running) .
Engine is ideal repower/replacement setup. Bigger turbo, better exhaust (more power) and lower profile than truck version.
Will consider trades for  plow truck, name brand chainsaws, 3pt cat 1 implements (winch, box blade, york rake) woodsplitter, haywagon, log trailer, 220 volt welder, plasma cutter, firearms, tools, ???
Shinnlinger
Offline shinnlinger
Re: 7.3 Ford Powerstroke *SOLD*
« Reply #1 on: August 08, 2013, 09:35:38 PM »
Sold about two months ago private sale, but finally left the yard today.  Since there is no redeeming info in this posting, I won't be offended if the entire post is deleted.
Dave
Shinnlinger
Ford V-10 vs Powerstroke Diesel
Started by pappy19 on General Board
Last post November 10, 2009, 04:47:54 PM
by Toolman
Ford 7.3 Powerstroke Diesel
Started by RALFF on General Board
Last post September 01, 2008, 10:07:30 PM
by Lurcherman
FORD F-550 7.3 Powerstroke Auto or Stick????
Started by Ironwood on General Board
Last post October 22, 2005, 01:18:30 AM
by Ironwood
-SOLD-Ford F700 flatbed with Knuckle crane
Started by getoverit on For Sale
Last post June 03, 2017, 11:11:06 PM
by sawguy21
