Sale or trade 7.3 powerstroke turbo diesel engine w/only 136,782 original miles.
Time for some spring cleaning and make the wife happy
Engine currently in 1999 Ford E-350 1 ton, extended wheelbase, van, automatic. Runs and drives but needs wiring harness work (only runs on 4 cylinders) and batteries. Used to be able to jiggle wiring harness and get to run on all 8 for a bit but no longer. There was a tech bulletin on this and it is a known problem/easy fix but its rusted pretty good (won't pass NH inspection) but could be put back on road with wiring harness and body work if you are determined (have rear patch panels).
If you want to hear it run bring two good batteries (but I do have video of it running) .
Engine is ideal repower/replacement setup. Bigger turbo, better exhaust (more power) and lower profile than truck version.
Will consider trades for plow truck, name brand chainsaws, 3pt cat 1 implements (winch, box blade, york rake) woodsplitter, haywagon, log trailer, 220 volt welder, plasma cutter, firearms, tools,
