Author Topic: Never would have dreamed that roller guides could make such a difference!  (Read 2666 times)
Offline MSSawmill
Dad and I spent Saturday building new roller guides for the mill, and he was able to get them mounted on Sunday. The difference in cutting speed, accuracy, and even appearance are like night and day compared to before.
Both guides are running greasable cam follower bearings on top of the blade and small sealed bearings behind the blade. Each one is adjustable front to back, up and down, and angle of approach via bolts and slots. We also built some strength into the sliding guide by running a bar up to a slide above the throat. We're not sure how long the bearings will last, but we'll keep pumping grease to them until they give out. We've already got a stockpile of replacements!
Neither of us could believe the difference those guides made on the mill! All of the pics below are with a Woodmaster C Sharp blade on the mill, but to begin with, Dad ran a Woodmaster C blade we had been using for a while. It even ran straight and smooth and fast until he tried to cut through a log dog with it! I'm just blown away! He cut through a couple of small logs, by himself, in a fraction of the time it took before these guides. (I was hanging onto 2 kids and watching the work!) Just amazing... now we can seriously knock out some lumber and make some sawdust!
Small stack of some really knotty stuff, but it's straight, accurate, knotty stuff with gorgeous cutting faces! ;)
And yeah, the only complaint we have about the Woodmaster C blades is that they don't cut through metal very well! Or, more correctly, they don't cut through wood very well after cutting into a piece of metal!
Home-built bandsaw mill
2004 Kubota M110 with LA1301 loader
Offline Andy White
  • I'm not so new anymore!!
MSSawmill
I have been wanting to retrofit my mill with roller guides for some time. After reading and corresponding with HaroldSiefke on his conversion, and hearing your comments on the difference in cut quality,I will be converting my mill in May. Thanks for the inspiration to try better things.       Andy
Learning by day, aching by night, but loving every minute of it!! Running HM126 Woodland Mill, Stihl MS290, Homemade Log Arch, JD 5103/FEL and complete woodshop of American Delta tools.
Offline Chuck White
  • Sawing Mobile since 2005
Looks and sounds good!
Glad you got good results!
~Chuck~
Retired USAF 1989, Retired School Bus Driver 2012, now semi-retired Mobile Sawyer
1995 Wood-Mizer LT40HDG25 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Online GAB
Concerning the Comment: "And yeah, the only complaint we have about the Woodmaster C blades is that they don't cut through metal very well! Or, more correctly, they don't cut through wood very well after cutting into a piece of metal! "
DUH!!!!
Sawing 1/2" lag bolts also affects cutting quality and speed.  I sawed one that had been in a pine tree a long time.  Gerald
W-M LT40HDD34 w/6' ext & SLR, JD 420, JD 950w/loader and Woods backhoe, V3507 Fransguard winch, Cordwood Saw, 18' flat bed trailer, and other toys.
Offline highleadtimber16
  • Learning Everyday
Great Job! Looking good!
2011 Wood-Mizer LT 40 hyd w/ 12' Extension,
EG 200 Wood-Mizer
Cutting Old Growth Cedar from Queen Charlotte Islands.
Offline millwright
Nice job, they look very strong and easy to work on.
Offline drobertson
Ditto on the nice job, glad to see it working better for you, no doubt that had to have been an improvement,
Offline fishpharmer
Congratulations on your improved blade guides resulting in improved blade performance.  Very nice looking lumber!
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
Offline kelLOGg
  • More is better but enough is best
MSSawmill, what guides did you have before the new ones?
You have done a fine job on the mill!
Bob
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
DH kiln, CatClaw, setter, tandem trailer, log arches, tractor, thumb tacks
Offline bandmiller2
MS sawmill dad did a good job on the guides.I used pretty much the same thing on my mill for years with complete satisfaction.Last year I went to "store bought" guides from Cooks with the flange on the back some improvement but not a great one.I used two sealed bearings where you have the cam follower and an eccentric bolt for fine adjustment.You will find you have to replace the bearings quite often,I used to buy those bearings wholesale ten at a time so no great problem.You could easily convert to flanged guides when you want. Frank C.
Offline Fla._Deadheader
  • Linda Vista, Costa Rica
MSSawmill
 Now, to complete the package, buy a couple of "platers Brushes". They look like wire tooth brushes with wood or plastic handles. Fab up a small box tube with a set bolt. Position one on the INSIDE of the fixed roller guide, so the wire bristles rub on the INSIDE of the blade, to clean off the sawdust buildup.
 That stripe of dust on the blade will accumulate and cause the blade to wander some in the cut. Look at the sawdust mashed against the belt on the drive pulley. That little brush will make a world of difference, and, they are easily replaced when needed.
 It's one of the best ideas we came up with on our home built mill, especially sawing SYP.
Offline Ga Mtn Man
  • Y'all can call me GMM
Fla_Deadheader-  You got any pics of that?
 Solo una  :)
 I forgot that we had installed the brush AFTER the guide roller, BUT, we have the grooved guide wheels. Op might need it BEFORE the guide roller, to keep that smooth wheel clean.
Offline MSSawmill
Thanks for the comments! There were rollers in several spots on the mill when we got it, but nothing consistent and nothing providing down force on the blade.
I like the brush idea... there were some on the mill when we got it, but they were pulled off along the way and just never put back on. Would lubrication on the blade help with that, too?
 Using trailer tires as blade wheels, we tried Pinesol 1 time. Made things slimy. We just used whatever amount of water we needed on the blade, to keep things running smoothly.
Offline ladylake
  Yes the downforce is a big deal , I run 1/4" with good results.  Also your back beaing should run 3/16 to 1/4 behind the blade.  Too close, the blade will hit the bearing too soon cuasing the band to bend around the bearing some being real hard on the gullet side.   Steve
Timberking B20 15000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Suffolk  setter Volvo MCT125c skid loader
Offline bandmiller2
MS,I don't think cam followers are designed for high speed,of course I've been wrong before.A piece of felt or lamp wick makes a good applicator for diesel and oil used like the wire brush as above.If I notice something building up on the band I very carefully apply a wire brush to only the solid part of the band from behind as its running. Frank C.
Roller guides vs. Block guides
Started by mobile demensia on Sawmills and Milling
Last post June 09, 2013, 12:31:53 AM
by mobile demensia
roller guides
Started by staker on Sawmills and Milling
Last post June 05, 2013, 09:44:39 PM
by staker
Roller guides
Started by bandmiller2 on Sawmills and Milling
Last post July 29, 2012, 07:48:43 AM
by NMFP
roller guides
Started by AtLast on Sawmills and Milling
Last post June 17, 2003, 07:31:23 PM
by Neil_B
