Author Topic: Help with what year my 225 TJ is  (Read 695 times)
Offline shawn55
  • MN logger
« on: May 23, 2013, 06:06:16 AM »
The only serial numbers that i can make out is behind cab on the frame.588858 but those numbers dont make sence to me. I think its a 1970-1973 because it has the bigger opening in the cab. what does everybody think what year it is and i hope these pics work. looks a little rough but im caging in the cab and then its getting sand blasted and a new paint job.
Offline Mark K
Re: Help with what year my 225 TJ is
« Reply #1 on: May 23, 2013, 06:15:06 PM »
I had a 66. My reverser was in the transmission. Had a two levers, front lever was forward and reverse, back lever was a four speed. Had a high low in the transfer case. Is your reverser in the transfer case or the transmission? Might be a little newer than you think.
Husky 372's-385's,576, 2100
Treefarmer C7D
Franklin 405
Belsaw m-14 sawmill
Offline shawn55
  • MN logger
« Reply #2 on: May 23, 2013, 08:06:24 PM »
the forward and reverse linkage goes up between motor and transmission.  and the high and low is in the transfer case. also it has the square box air cleaner which I have not seen many of them or did they come standard in certain years.
Offline 240b
« Reply #3 on: May 23, 2013, 10:52:51 PM »
late 60's to 73-74
Offline Mark K
« Reply #4 on: May 24, 2013, 05:55:53 PM »
That square air box was aftermarket from what I've heard. Mine had that. Original equipment was an oil bath. Yours is newer than the one I had. My hydraulics were along side of the seat. I would say early to mid 70's. Not sure.
Treefarmer C7D
Franklin 405
Belsaw m-14 sawmill
Price Increases- Year To Year
Started by Bud Man on Sawmills and Milling
Last post January 28, 2002, 03:07:27 PM
by Bud Man
101 year old driving 81 year old car
Started by cornbread on General Board
Last post November 10, 2011, 10:28:04 AM
by JD350Cmark
WHO IS IN THIS YEAR? LET'S BEAT LAST YEAR!
Last post April 13, 2020, 07:54:17 AM
by Jeff
How much do you saw per year?
Started by Dan_Shade on Sawmills and Milling
Last post March 26, 2008, 10:42:33 PM
by Warren
