Author Topic: Is this hard maple?  (Read 1415 times)
Offline bakerhardwoods
Is this hard maple?
« on: June 01, 2013, 07:49:25 AM »
The bark is coming off a bit like elm, but the sapwood is white.  I don't have leaves.
Offline Autocar
Re: Is this hard maple?
« Reply #1 on: June 01, 2013, 08:08:22 AM »
No it's not hard maple my guess would be elm .
Bill
Offline Axe Handle Hound
« Reply #2 on: June 01, 2013, 09:06:44 AM »
Check the twigs if you can.  The leaf buds should be in opposite arrangement if it's a maple tree.  http://www.massmaple.org/treeid.php
« Reply #3 on: June 01, 2013, 10:16:54 AM »
I don't have twigs and would not be able to find exactly where it grew.  The bark does not have the flaky appearance that older hard maples have, so I was thinking elm, but hoping it was maple.  Hope does not buy much.
Offline beenthere
« Reply #4 on: June 01, 2013, 10:21:02 AM »
The first pic smacks of possibly hickory. Has it been ruled out?
But going by pics, and a blurry one, it makes it real hard to tell for sure. ;)
A clean, smooth cut showing the rings and some of the cell structure may be the best way to tell from what you have available.
Offline WDH
  • Forester
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #5 on: June 01, 2013, 09:55:45 PM »
From the info available, I would also say hickory.  But, if it is elm, the latewood pores will be arranged in distinct wavy bands that look like squiggly lines.  Not so with hickory.  Get a clean slice on the end grain with a razor blade.  If it is elm, you will certainly see the wavy bands of pores in the latewood.
Check out the pics on this site.  The wavy bands are very easy to see.
« Reply #6 on: June 02, 2013, 01:08:31 PM »
I had a reply ready and "poof" it was gone.  I'm trying to put up closer end grain pictures.  This log has the center with a ring of shake or something around it.  I did not have any luck cutting it with a razor blade
Offline mesquite buckeye
  • Trees are good- even ones with stickers
« Reply #7 on: June 02, 2013, 01:22:39 PM »
Looks rather elmish to me. If you can set the camera for digital macro, then zoom, you can make it bigger, which would help. Also need to make a clean cut with a razor blade to give a clean view. ;D
Offline beenthere
« Reply #8 on: June 02, 2013, 01:57:26 PM »
Looks like elm from here too.
Blowing up one of your pics, and shows what appears to be the wavy parenchyma cells, IMO
Mesquite's suggestion of a magnified pic would tie it down better.
Offline SwampDonkey
  • Forester
  • Large Tooth
« Reply #9 on: June 02, 2013, 02:16:24 PM »
Elm +++ ;)
Move'n on.
Offline WDH
  • Forester
« Reply #10 on: June 03, 2013, 07:46:13 AM »
There you go!  Wavy bands in the latewood  8).  Baker, you did good.
(You can never trust a hickory, anyway  :)).
« Reply #11 on: June 07, 2013, 09:41:55 AM »
Thank you very much for "naming that log."  I decided to put it into the "cut" pile rather than the "pallet mill" pile.  I'll have it sawn 6/4.  I'll be back later with another log that is a mystery to me.
Cheers, Tim
hard maple vs. soft maple
Started by redpowerd on General Board
Last post September 19, 2003, 02:05:58 PM
by redpowerd
Hard maple
Started by Firewoodjoe on Forestry and Logging
Last post August 25, 2018, 09:47:15 AM
by Ed_K
hard maple
Started by abooley on Sawmills and Milling
Last post July 06, 2010, 12:50:14 PM
by OneWithWood
hard maple
Started by Wyatt on Drying and Processing
Last post January 05, 2005, 09:46:27 AM
by Bill_B
