who's got the best Winch?
Started by arboristt, June 03, 2013, 01:34:34 PM
arboristt
Hello Everyone,
My name is James and this is my first time posting on this forum. And i am looking for some advice from you experts.
I am in the Market for a portable Winch. Right now i have it narrowed down to a website called www.westcoastwinch.com, more specifically the PCW5000.
Has anyone used this type of gas powered winch before? any comments on its quality? do you have any suggestions on different types of portable winches that you have and like?
thanks, i will post and wait for your responses.
Welcome to the forestry forum.
That capstan winch is the one I would go for and have come close to buying one like it, or the same. Usually manage to get by without the winch when pulling trees down or out of a tough place to get the tractor. So far, a long cable and the tractor have managed.
The capstan style gives a lot of control, and no need to worry about a cable getting twisted out of shape. IMO
giant splinter
I have been looking into the 5000 also, I like the specs better than its competition and the Honda motor is strong and quiet. I plan on using mine to yard trees off a slope. the capstan is a great way to go and you can use as much line as you need.
roll with it
Jay C. White Cloud
Have owned one of these for about 15 years.  Love it and use it often.  Most on the market are great tools to have around.
http://www.capstanropewinch.com/
"To posses an open mind, is to hold a key to many doors, and the ability to created doors where there were none before."
"When it is all said and done, they will have said they did it themselves."-teams response under a good leader.
arboristt
On the website, the work cycle says that it is continuous, but does anyone know how long that will actually last?
For my application, most uses will be in remote locations (where i wont have access to truck or chipper) and carrying gallons of gasoline with me will not be very efficient.
Does anyone know what kind of work load i would get out of one tank of gasoline?
Should be continuous, as long as the gas engine doesn't run out of fuel.
Not like a battery powered winch that might need cooling off.
arboristt
Just an update for those who are interested.
I purchased the PCW5000 from westcoastwinch.com. it is a sharp unit, i will follow up with pictures shortly.
Thanks for the feedback!
arboristt,welcome to the forum. Is this for your business or your own use?
arboristt
Hey thecfarm,
I have purchased it for personal use. My father in law has a property in Washington State and we are planning on doing some work to it to make it ready for sale (one day...), many trees and stumps along with much dead-fall needs to be removed, but it is so dense that bringing in any vehicles will be close to impossible.
Hopefully this equipment will give us a fighting chance!
DR Buck
HEY GUYS!    Our very own FF Sponsor Logrite offers that same winch.
http://www.logrite.com/store/Item/capstan-winch
I've had mine for a few years now and love it.  It's paid for it's self a couple times already.
Martha White Nelson
Hi James!!!  Welcome to the forum.  Contact Andy White on the forum.  He has lots of knowledge on this topic.
Have a great day!!!
Martha
arboristt
Ok, Thanks.
I will contact Andy, I could use some pointers on blocking/redirecting the line. I'm sure he would be a good guy to talk to.
Vance in AK
Quote from: arboristt on July 30, 2013, 12:09:33 PM
Ok, Thanks.
It would be great if you guys could have that discussion openly here on the forum.  I'm sure many of us would benefit.
Ed_K
If you can,back your tractor around to the side to keep the line as straight as possible. I have pulled the back tire off the ground ,pulling at a 15 deg offset.
I have used a pulley hung up in a tree to get more lift pulling up hill to keep from hanging on stumps.Make sure the tree is one that will be cut tho.
Ed K
arboristt
Martha,
I am having a tough time making contact Andy, what is his member name?
We have a member that has a user name of  Andy White.
https://forestryforum.com/board/index.php?action=profile;u=20359
I went to the menu bar and clicked onto members and find this name. good luck.
Andy White was on Monday around noon-ish. If you send him a PM, he will get notified it is there as soon as he signs on again.
I'm curious if Andy White has that capstan winch that you (arboristt) purchased. Maybe Martha knows he does, so suggested contacting him.
We'd be interested in how it is working for you. And we like pics...  ;D
Quebecnewf
I bought one of these a few years ago. Best money i ever spent.
Go to my gallery and I think there are some pics of it being used.
I log in winter and this unit starts up real easy in the cold. It has a small tank but most days you will not use a tank.
This unit works best if you have a good knowledge of rope and tackle work. I had this when I started but you can learn as you go.
Send me a PM  if you have any questions???
Quebecnewf
Aussie.firewood
Ive been looking at the 50cc models, anyone else think these are a little weak for pulling logs. I don't want to run pulleys, i would rather use the rope length for single set ups and tow longer distances.
what about making one out of an old generator? any idea about the gear ratios? or is this unrealistic?
my plan would be to attach it to the trailer and pull logs straight on, anyone foresee a problem with that.
(im still a newbie)
Carpenter so obsessed with wood, im becoming a forester/logger/mill-owner
arboristt
Hey Aussie.firewood,
I am a newbie too but i may be able to provide some insight as i recently went through the buying process.
The pulling power of the 50cc model is rated for 2200 lbs. on a single line and my experience with it so far is that it basically meets those rating. i have yet to see the unit struggle with any payload however i am not sure exactly how much weight i have been pulling, somewhere around 1000-1200 i think.
Not sure about you generator idea, but i know the gear ratio for the 50cc is 110:1.
The idea of attaching on to trailer is a good one in principal but to my knowledge there is no way to anchor this winch to the back of the trailer. The best you can do is anchor it to the ball hitch but that only gets you to the trailer, not on it. has anyone else ran into this issue?
arboristt
Hey all,
i thought i would add a photo to this thread of the a close up of the winch making a pull up an embankment.
i got it from that website a while ago and have some other photos that i could put up. if you like this i will add others.
thanks for the feedback.
More pics would be great, and a video even better.  8)
That you doing the "pulling" ?
Kevin
I built a shelf for my winch that straps to the tree and frees up your hands to operate the rope.
I use the skidding cone and when you add a little snow to skid on it really improves things.
You can tie one end around the tree below the winch and put a roving block at the load to double the pulling strength if you need it.
arboristt
i am holding the Camera,
Video coming. if i can figure out how to add it to this thread...
Quebecnewf
I see your getting the hang of it.
We use our winch mostly in winter. To keep the winch from drawing down in to the snow when the strain comes on we just use a 2x2 ft pc of plywood . Throw that down next to the tree , put the winch on top of the plywood ,strap around tree and your good to go.
We do most of our pulling with just a straight line. If we have a real big log or tree in a bad spot we will add a snatch block to double the pulling power.
Our system for winter logging
1. Find a bunch of logs to cut.
2. Select a tree in the middle of the logs you plan to cut.
3. Climb tree with spurs ,belt and axe to cut limbs on the way up.
4. Attach snatch block up 20 to 30 ft of the ground.
5. Attach second snatch block at base of  same tree.
6. position winch attached to another tree base approx 20 ft away from "yarding" tree.
7. Cut all the logs that your rope can reach from you "yarding tree"
8. Pull them and stack them next to the " yarding tree".
9. Cut a hauling path to the yarding tree and your ready to go.
10. after all the logs are hauled away cut down the yardin tree and recover your snatch blocks and move to the next location
This is what works for us. Kind of a different logging operation. Very small scale. Iwould not go in the woods now without the winch.
Quebecnewf
