BLUECREEPER Poster Award #4!
I reached out to Woodmizer when I was shopping for a mill. Asking for thickness of mill supports.Was told by "Archey", at woodmizer that the supports were 6" x 2" x 1/8 gauge, on the lt15. I would check with the larger steel yards. They are cheaper than the middleman. The one I priced at and went to was in Detroit around 6 mile. They sold in 20' lengths standard. And they would cut it down for you for a fee. If it was me I'd just cut it down with a cordless sawzall just enough to get it home. Is it just a couple bolts holding it together through the steel bar? Seems like it would shift?I would think you'd use the bolt idea and also have a custom fit steel insert welded up to fit inside the 2 tubes to keep it from shifting up or down.But, I've never seen a woodmizer in person, though I'd like to. Dave S...
hopefully they sell to the "little guy" and not just big businesses.
Just don't call me for help when you want to saw out that 36 footer
Started by dhp3228 on Sawmills and Milling
Started by Norwiscutter on Wanted
Started by rooster 58 on Sawmills and Milling
Started by woodhick on For Sale
