Author Topic: leaf blower  (Read 1109 times)
Offline SILVERTOOTH
leaf blower
« on: July 05, 2013, 12:12:58 PM »
Don't know if this has come up before, but figured out a good way to get rid of the sawdust from off mill after sawing with a leaf blower. Beats dragging compressor hose around and is a lot more portable.
Offline drobertson
Re: leaf blower
« Reply #1 on: July 05, 2013, 12:24:06 PM »
I've read a few other use one, seems to work well, don't have one, I just use a brush and broom,  sounds like you got the loader working, glad to hear!  david
Offline NCDiesel
  • Off-bearer extraordinaire
    • Tooth And Blade
Re: leaf blower
« Reply #2 on: July 05, 2013, 03:05:51 PM »
They work great IMHO.   I am not real experienced with band mills and maybe I am not familiar with an easier way to clean up, but I certainly can not think of one.
NCDiesel
Cooks MP-32, 2016 Ram 1500, 6K Kaufman Equip. Trailer, 1995 Bobcat 753 skidsteer 1958 Ford 861 Diesel,
Youth Conservation Corps, Clayton Ranger District, 1977.
I worked sawmills as a teenager and one fall morning I came to work and smelled walnut cutting.  I have loved sawmills ever sinc
Offline WH_Conley
  • I need to tide my profile!
    • Stone Hill Hardwoods
Re: leaf blower
« Reply #3 on: July 05, 2013, 05:07:34 PM »
If you sticker your lumber stack, when the sawdust dries just use the blower on it. You will be surprised how much sawdust you missed.
Bill
Offline Nomad
  • Member
    • Bill's Mill Portable Sawmill Service
Re: leaf blower
« Reply #4 on: July 05, 2013, 05:10:46 PM »
     A leaf blower lives on my truck whenever I do a mobile job.  I wouldn't be without it.  And as mentioned, it works well for lumber stacks too 8)
WoodMizer LT50HDD51-WR
Lucas DSM
Offline Chuck White
  • Sawing Mobile since 2005
Re: leaf blower
« Reply #5 on: July 05, 2013, 06:41:29 PM »
Leaf blowers have been discussed here a few times, and most seem to be in favor of them.
I have used a leaf blower on my mill since the first year I had the mill.
I can clean off my mill in less than 5 minutes, and more thoroughly too.
Also, as one of the posters on previous discussion mentioned and I for one use it quite often, is the fact that the leaf blower will speed up the cooling down of the engine and the muffler/s so the cover can be put on sooner.
Wouldn't be without mine, it's a Stihl BG55.
~Chuck~
1995 Wood-Mizer LT40HDG25 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline justallan1
  • living and learning
Re: leaf blower
« Reply #6 on: July 05, 2013, 08:18:26 PM »
I don't have one for my mill, but I've used them for farm equipment in the past and you just cant beat them.
Offline ancjr
  • Lost in the woods!
Re: leaf blower
« Reply #7 on: July 05, 2013, 08:26:33 PM »
I have a small big box store handheld, plus a Stihl BR600 for when I need to move piles of wet chips, rocks, small logs.   :D
Offline thecfarm
Re: leaf blower
« Reply #8 on: July 05, 2013, 09:42:18 PM »
I just might get me one of them. Helps out of brush fires too.
Offline John S
Re: leaf blower
« Reply #9 on: July 06, 2013, 08:02:28 AM »
I also use the Stihl BG55.  It only takes about 2 minutes to give the mill a thorough cleaning.  I was going to buy a larger model but luckily was talked out of it at the local Stihl dealer.  It is light-weight and easy to handle.
2018 LT40HDG38 Wide
Offline Peter Drouin
    • A&P Saw mill LLC
Re: leaf blower
« Reply #10 on: July 06, 2013, 12:56:45 PM »
I don't have one :(
A&P saw Mill LLC.
License NH softwood grader.
Online Al_Smith
Re: leaf blower
« Reply #11 on: July 06, 2013, 07:03:00 PM »
Blowers are pretty handy for a lot of things .I have four myself .two Stihls  BG 85 and back pack BR 400.
For about 35 bucks and change you can buy a deal where you can blow the eave spouting clear of leaves without resorting to using a ladder.Do the whole house in about 10-15 minutes or less from the ground .
The BR 400 will blow about 18 inchs of snow and makes a dandy garage floor sweeper.Just about like a mini tornado .
Every mill should come with a leaf blower
Started by WV Sawmiller on Sawmills and Milling
Last post August 06, 2015, 06:51:01 PM
by OneWithWood
Leaf Blower advice wanted
Started by whitepe on Chainsaws
Last post September 15, 2002, 01:34:17 PM
by Tom
Hey, all you leaf 'ers
Started by Kevin on Travel Guide
Last post November 01, 2002, 04:28:39 PM
by Corley5
leaf id's
Started by Dave H. on Tree, Plant and Wood I.D.
Last post September 26, 2016, 10:10:40 PM
by WDH
