Author Topic: An Overlooked Maintenance Item  (Read 2465 times)
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« on: July 09, 2013, 12:02:35 PM »
Overlooked, neglected, or simply did not realize that it was there.  Fine sawdust and ATF had compacted tightly between the Teflon pads on the mast.  So tightly that it took a screwdriver to pry and loosen and remove it.
The spaces between the pads were completely compacted with powdered sawdust.
I'll be sure to keep these overlooked spaces opened up.  Heck, I can even squirt ATF in there now.   ;D
Offline Slingshot
Re: An Overlooked Maintenance Item
« Reply #1 on: July 09, 2013, 03:54:16 PM »
   Better watch, the head might wobble around a little now without that extra padding.
____________________________________
Offline drobertson
« Reply #2 on: July 09, 2013, 04:27:57 PM »
No doubt that is a collection spot, I use short pieces of banding to keep it clean, air would work as well, I do allow a little to build up, kinda figure it works like a wiper when soaked with atf, might be a flawed concept, david
Offline Bibbyman
    • Warden Sawmill
« Reply #3 on: July 09, 2013, 05:17:54 PM »
I got an education from the school of hard knocks to use ATF.  I had a quantity of hydraulic fluid that had lost its label and was likely for a machine I no longer had so I used to oil the chain,  mast and anything else that needed oiling.  The head got to chattering as it went up or down. I figured the gearbox was going out or a bearing on the cog shaft. Talking it over with ElectricAl, he suggested I clean the mast and apply ATF.  I did and the chatter was reduced dramatically.
I don't know what else may work but I now know what won't work.
Sawing since '94
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #4 on: July 09, 2013, 05:26:07 PM »
Yup, I have figured out that the OEM's recommendations are for a reason.   ;D
Offline barbender
« Reply #5 on: July 09, 2013, 05:34:34 PM »
Magic, does your mill still have the middle row of pads on the mast, so 12 pads total instead of 8? WM told me to remove my middle row of pads, they were used on the earlier supers but were found to serve no purpose, only the top and bottom pads make contact with the mast anyhow.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #6 on: July 09, 2013, 06:37:56 PM »
Yes, I have the middle pads.   Actually the corner closest to the clutch lever has 4 pads that are spaced only about 4" apart.  This can be seen in the above picture and was the side with the heaviest and most compacted buildup.
I have not had any luck finding a clear picture in the Operator's Manual.
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
« Reply #7 on: July 09, 2013, 06:40:58 PM »
I'm taking notes.  :)
Offline barbender
« Reply #8 on: July 10, 2013, 12:19:16 AM »
I'd inquire about them to WM, I don't think they even put those ones on the new mills. I ordered new pads for mine, and WM told me at that time to remove the "extras". I did, and found I wouldn't have had to order new ones- the "in between" pads had never even touched the mast, they were in brand new condition. So I have extras now ;D
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #9 on: July 10, 2013, 10:33:53 PM »
OK, I thought that I knew the answer since I dug compacted sawdust out from between them, but I made sure today.  My front mast (toward the control box) has four smaller pads on each side.  The rear mast has two much larger pads on each side.
I am thinking that the front mast must carry more of the weight of the Diesel engine.
Offline ElectricAl
  • 1993 LT40HDE15 2012 LT50HDE25
« Reply #10 on: July 11, 2013, 07:58:34 PM »
We use a lot of ATF, enough that we buy in mini bulk containers.
2 gallon jugs are available at TSC  ( Tractor Supply Company ).
Linda and I custom saw NHLA Grade Lumber, do retail sales, and provide Kiln Services full time.
Online Peter Drouin
    • A&P Saw mill LLC
« Reply #11 on: July 11, 2013, 10:17:11 PM »
I use a lot too .I paint atf on the mills nut and bolts too'
I use a coffee can when the sawdust gets deep I get a new one :D
A&P saw Mill LLC.
License NH softwood grader.
Offline fishpimp
  • SawDawg
    • www.photobucket.com
« Reply #12 on: July 11, 2013, 10:35:21 PM »
Boyz I go to the local transmission shop... They gladly give used fluid away by the 5 gallon.
Online Peter Drouin
    • A&P Saw mill LLC
« Reply #13 on: July 11, 2013, 11:09:01 PM »
Not a bad idea if it; s not all burnt.
It still has to lube.Ill go look see thanks :)
A&P saw Mill LLC.
Offline woodweasel
  • I'm No Longer New, But Green As A Gord
« Reply #14 on: July 12, 2013, 10:48:13 AM »
By mast are youall talking about the post that the head raises and lowers on? 8)
Offline Bandmill Bandit
« Reply #15 on: July 12, 2013, 11:59:29 AM »
I was starting to get chatter in the raising of the head so talked to Garry about it at Woodmizer West in BC which is why I changed my daily application of ATF to dry graphite spray on the mast about 300 hours ago.
I first did a very through high pressure hot wash  of the entire mill with extra attention to the mast area to ensure it was very well cleaned as per Garry's recommendation.
The graphite works much better than the ATF. I won't go back to ATF on the mill any where. ALL other locations that I was using ATF on now get the Ams Oil metal protectant product instead. I find that I have a lot less cleaning to worry about and no more sticking saw dust or chatter in the head travel. Just over 300 hours total since I switched from ATF and very happy so far. Total hours on the meter are 1103.
If you ain't livin on the edge you are takin up way to much room. Of course at my age if I get too close to that edge any more theres a good chance I may fall off.
2001 Dodge 1500 4x4. 2018 F150
2007 Woodmizer LT40HDG28 almost Super
2 Logrite 36 inch cant hooks and a bunch of stuff I built myself
Online Peter Drouin
    • A&P Saw mill LLC
« Reply #16 on: July 12, 2013, 12:25:53 PM »
Do you spray every day ?
A&P saw Mill LLC.
Offline ElectricAl
« Reply #17 on: July 12, 2013, 06:27:16 PM »
Bandmill bandit,
Back in 1996 we tried some spray Dry Graphite. It went on like spray paint.
On the second day the Mast Tubes gummed up and the head stopped moving.
In places the Graphite balled up.
Sense you have had success with Graphic, we must have not gotten the good stuff you have.
Our experiment was a complete disaster.
How about sharing some produce information.
ElectricAl
« Reply #18 on: July 12, 2013, 07:43:55 PM »
ok will do but I am a bit tied up at the moment. Will get a pic of the cans too and post em.
Also Garry tole me that a very THROUGH cleaning was paramount to success with the dry graphite AFTER ATF use.
I used a hot foam acid wash at an oil Rig maintenance wash facility and then a high pressure high temp steam rinse.
Gary told me that the graphite would gum up if mixed with the ATF so I made sure to the tune of 150 bucks worth of high pressure, hot foam acid and steam cleaning to make SURE it was gone. My first can was CRC  "Dry Graphite Lubricant" but the one I am on now and prefer is the GUNK Liquid Wrench  version of the "Dry Graphite sec".
There is another product I MAY try soon. It is a dry lubricant that is used in tight tolerance applications   such as VERY large vault type doors and such. It is a bit expensive at 40 bucks a can but i am gona try it.
I sprayed daily for the first 3 or 4 days and let it dry while I was eating lunch. Now I spray a couple of times a week.
Offline ElectricAl
« Reply #19 on: July 12, 2013, 09:41:43 PM »
ALrighty then,
Mistake #1 Paper Towel wipe down with not good enough ! ::)
The most overlooked maintenance issue around the mill yard.
Started by DARRELL1972 on Sawmills and Milling
Last post July 11, 2019, 08:15:13 AM
by WV Sawmiller
really interesting ebay item...
Started by asy on General Board
Last post March 17, 2006, 08:00:21 PM
by rebocardo
Notice anything strange about this item?
Started by johncinquo on General Board
Last post February 07, 2007, 09:27:34 PM
by Furby
OK, how do I post for a wanted item?
Started by Texas Ranger on General Board
Last post May 06, 2005, 12:22:44 AM
by Texas Ranger
