Author Topic: An Overlooked Maintenance Item  (Read 2459 times)
Offline Bandmill Bandit
Re: An Overlooked Maintenance Item
« Reply #20 on: July 12, 2013, 10:10:27 PM »
ALrighty then,
Mistake #1 Paper Towel wipe down with not good enough ! ::)
Oh well we live and learn.  :P
I used about a gallon of ATF a month before the switch and was having chatter issues with head up down and minor chatter with the log clamp in out up down too some times. Took that apart and cleaned the bushings and had them knurled and then used the Ams Oil metal protectant there. No issues since. My mill will ONLY see ATF on the top rail Felt and if I can figure out a product that will eliminate it there it will be gone there too.
If you ain't livin on the edge you are takin up way to much room. Of course at my age if I get too close to that edge any more theres a good chance I may fall off.
2001 Dodge 1500 4x4. 2018 F150
2007 Woodmizer LT40HDG28 almost Super
2 Logrite 36 inch cant hooks and a bunch of stuff I built myself
Offline Migal
  • I'm new! But Old as Dirt!
« Reply #21 on: July 13, 2013, 06:09:09 PM »
ALrighty then,
Maybe you needed some alcohol with that paper towel JK  8)
Stihl learning and picked up my Log Master LM2 Cat 34hp 02 21 12! 230MF+ the toys that go with it! MS361 MS271 Stihl PB500 Echo 48" Logrite 16ft Bass Tracker Pro' Abua Garcia 5600 bait caster, Wood working equipment' Lake Lot never enough time! oh don't forget the fridge with ale! Loving Wife Rebeca
Offline Martha White Nelson
  • Gender: Female
  • I'm new! Not so new now!
« Reply #22 on: July 21, 2013, 12:46:16 PM »
Wow!!  Never thought about that happening!
Martha
The most overlooked maintenance issue around the mill yard.
Started by DARRELL1972 on Sawmills and Milling
Last post July 11, 2019, 08:15:13 AM
by WV Sawmiller
OK, how do I post for a wanted item?
Started by Texas Ranger on General Board
Last post May 06, 2005, 12:22:44 AM
by Texas Ranger
New item from Wood-Mizer
Started by MartyParsons on Sawmills and Milling
Last post September 01, 2005, 11:58:07 PM
by Bibbyman
Handy item to keep in the boat
Started by WV Sawmiller on The Outdoor Board
Last post June 17, 2019, 09:26:14 PM
by caveman
